Ok then:
So i've posted updates on my thread but let me past it there.
It seems to problem is the same for all thoses frontpage: the following concern because it's the only frontpage i've been able to get working (with flazt tho)
I've make some progress: i have been able to:
- Make Flatz connect and interract.
- Dashticz connect and interract by 2 way:
I have been able to get Dashticz connected folowing:
viewtopic.php?f=8&t=5166&start=140
robgeerts wrote: Wednesday 02 August 2017 20:14
Do you use the regular (master) version or the beta?
If you use the original version, try the CONFIG.JS I've added as an attachment first..
BUT: it doesent use this config.js: if i do any modifications: They are sotred in local storage: config.js dont get any modifications.
I can edit the settings correcty and they're applied correctly:
I'm not able to add tiles and save.
I was able to get my Dashticz connected using the original config. JS BUT i had to modify it folowing:
miesjel wrote: Wednesday 06 September 2017 20:21
miesjel wrote: Wednesday 06 September 2017 15:50
I have a problem getting Dashticz to work after the latest update, before that it worked like you would expect (showing my favourits from Domoticz).
Since i've updated Dashticz i'm having problems getting information, it is stuck at saying Domoticz offline. I even removed Dashticz and reinstalled it but that didnt help either
After the reinstalled i didnt configure the CONFIG.js so i could see the default page (like before) with example data. This wasnt showing up, after that i entered the IP and port number, saved the config and rebooted the Domoticz server, problem still not solved.
I've tested it on two different devices, and with 3 different browsers. Firefox says Domoticz Offline, Edge and Chrome say connection refused. I dont use authentication.
any ideas?
Solved the problem! After a few reboots I got the Dashticz example page, i used the gear to make a config and copied the data to a blanc config.js file. After that, it worked! After some troubleshooting it became clear that the problem was with the columns part in the example config file. After removing those lines, the problem was solved.
So my config file looked like:
var config = {}
config['domoticz_ip'] = 'https://10.0.0.13:8900';
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
Instead of:
var config = {}
config['domoticz_ip'] = 'http://192.168.1.3:8084';
var trashnames = {}
var tvguide = {}
var buttons = {}
var blocks = {}
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather','garbage']
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise','streamplayer',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
For this method: no changes can be made and the config.js got no changes.
So the problem seems to be in the config files. Am i wrong?
