Madgeni, please leave the thermostat control it works fine!
I know! I don't know what the problem Google has with me, but i'm trying very hard to get this into live.
Dear Madgeni! Can you enable my account? I subscribed in your website with email jonasarts at gmail. thank you!
Its appears a very good project!
Dear Madgeni,
Could you enable my account? I subscribed to your website with email tracingetn at gmail.
Thank you
Eager to try it.
Thank you
Eager to try it.
Hello, same for me, 404 when trying to associate
404: Not Found
Error: Not Found
at /opt/bitnami/apps/Controlicz/app.js:77:11
at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:310:13)
at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:280:7
at Function.process_params (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:330:12)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:271:10)
at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:618:15
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:256:14)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:121:14)
at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:67:12)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:129:13)
at loaded (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/middleware/transactionLoader.js:36:25)
at SessionStore.load (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/txn/session.js:27:22)
at transactionLoader (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/middleware/transactionLoader.js:42:24)
Home
404: Not Found
Error: Not Found
Home
I've just unlinked and relinked my account fine - i'm going to guess that it's either a timing issue, or that the google request is occasionally wrong
Hello madgeni, for information i had the same sync problem, i had to unlink/link my account and just before the link, i had to go to the link you provided on your mail (the [test]controlicz was not in the list of all boxes on google home after the unlink)
- gijsje
- Domoticz version: Stable
Is there an issue with changing the dim level to ...%?
It is not doing what it should do for my mi-light bulbs anymore
If i ask 100% i do get 14%
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
- DewGew
- Domoticz version: V4.10618
I have the same issue..phtinix wrote: ↑Sunday 04 February 2018 20:07 Hello madgeni, for information i had the same sync problem, i had to unlink/link my account and just before the link, i had to go to the link you provided on your mail (the [test]controlicz was not in the list of all boxes on google home after the unlink)
EDIT: I had to go to actions on Google and start test again. It has stopped for some reason. Now I can link controlicz again.
I'll take a look - i've not made any changes in a couple of weeks to lights
If you requested access via your profile on Controlicz, you'll receive an email with instructions
eww! Delete that message, don't post your email address on forums! If you'd requested access via your profile, you would have access to GH
oh, and "Email addresses and domains must be associated with an active Google Account or Google Apps account."
you should have an email with instructions now - any problems, email me
had a really good call with Google earlier - i've asked them to retest (against Hue and LIFX bulbs as well as Nest thermostat).
But they also wanted another thermostat - what do you guys use?
Hi Madgeni,
I'm using the Danfoss RS (zwave device)
http://smartheating.danfoss.com/en/a-so ... hermostat/
Thanks Fred - and it works fine with Controlicz? You can set/query temperature? Does it need a hub, or can it connect directly to Domoticz?
Hi Madgeni,
It works fine with Controlicz.
- I can query the value (I still have the "thermostat xxxxx is off" bug, but I guess it's normal for the moment)
- I can set the value (still have Google's bug about comma and decimals here in France)
It's recognized perfectly by domoticz. You don't need a hub. Just the zwave controler. The thermostat shows up two devices: a thermometer sensor and a thermostat setpoint.
I am still having issues, is there someone who could help me, i would be grateful
Kim
Kim
kimhaak wrote: ↑Thursday 01 February 2018 21:13 Hi!
Thank you for adding me to the google-test. However, the instructions is a bit unclear, as i do not know what we are trying to achieve, and how conversions.com are related.
I received one link : https://console.actions.google.com/proj ... atorcreate which just says "There was an error completing your request, try again". (Link is censored, in case there was an unique ID in it)
If i follow the conversions guide, i kind of end up with my own project, which i don't think is correct.
Could someone explain to med what the link (https://console.actions.google.com/proj ... atorcreate) is for?
Am i supposed to import this in my actions.google.com account somehow?
Sorry if this is comes of as negativity, i just did not understand what to do, and why. (And i am generally not a n00b in these kind of things)
If this project works and is good, i will definately donate to support the work.
Kim
PM sent
Hello, today, no 404
l have blinds defined in domoticz. What should I say to open them ?
When I say "ouvre le velux" (open the blind called velux in french) Google says "ok J'allume la lumière velux" (ok I turn on the light velux" ans the blind .... Closes.
