Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
superustas
Post by superustas »
Madgeni, please leave the thermostat control :) it works fine!
Madgeni
Post by Madgeni »
I know! I don't know what the problem Google has with me, but i'm trying very hard to get this into live.
jonaslo
Post by jonaslo »
Dear Madgeni! Can you enable my account? I subscribed in your website with email jonasarts at gmail. thank you!
Its appears a very good project!
TracingETn
Post by TracingETn »
Dear Madgeni,
Could you enable my account? I subscribed to your website with email tracingetn at gmail.
Thank you
Eager to try it.
getget
Post by getget »
Hello, same for me, 404 when trying to associate :(
404: Not Found
Error: Not Found
at /opt/bitnami/apps/Controlicz/app.js:77:11
at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:310:13)
at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:280:7
at Function.process_params (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:330:12)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:271:10)
at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:618:15
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:256:14)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:121:14)
at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:67:12)
at next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/route.js:129:13)
at loaded (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/middleware/transactionLoader.js:36:25)
at SessionStore.load (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/txn/session.js:27:22)
at transactionLoader (/opt/bitnami/apps/Controlicz/node_modules/oauth2orize/lib/middleware/transactionLoader.js:42:24)
Home
Madgeni
Post by Madgeni »
I've just unlinked and relinked my account fine - i'm going to guess that it's either a timing issue, or that the google request is occasionally wrong
phtinix
Post by phtinix »
Hello madgeni, for information i had the same sync problem, i had to unlink/link my account and just before the link, i had to go to the link you provided on your mail (the [test]controlicz was not in the list of all boxes on google home after the unlink)
gijsje
Domoticz version: Stable
Post by gijsje »
Is there an issue with changing the dim level to ...%?
It is not doing what it should do for my mi-light bulbs anymore
If i ask 100% i do get 14%
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
DewGew
Domoticz version: V4.10618
Post by DewGew »
phtinix wrote: Sunday 04 February 2018 20:07 Hello madgeni, for information i had the same sync problem, i had to unlink/link my account and just before the link, i had to go to the link you provided on your mail (the [test]controlicz was not in the list of all boxes on google home after the unlink)
I have the same issue..
EDIT: I had to go to actions on Google and start test again. It has stopped for some reason. Now I can link controlicz again.
Madgeni
Post by Madgeni »
gijsje wrote: Sunday 04 February 2018 23:29 Is there an issue with changing the dim level to ...%?
I'll take a look - i've not made any changes in a couple of weeks to lights
Madgeni
Post by Madgeni »
Smith wrote: Monday 05 February 2018 8:45 Hello
how am I going to know if my account is active ?
thank you
If you requested access via your profile on Controlicz, you'll receive an email with instructions
Madgeni
Post by Madgeni »
eww! Delete that message, don't post your email address on forums! If you'd requested access via your profile, you would have access to GH :)
oh, and "Email addresses and domains must be associated with an active Google Account or Google Apps account."
Madgeni
Post by Madgeni »
Hi :)
you should have an email with instructions now - any problems, email me :)
Madgeni
Post by Madgeni »
had a really good call with Google earlier - i've asked them to retest (against Hue and LIFX bulbs as well as Nest thermostat).
But they also wanted another thermostat - what do you guys use?
Fred78
Post by Fred78 »
Hi Madgeni,
I'm using the Danfoss RS (zwave device)
http://smartheating.danfoss.com/en/a-so ... hermostat/
Madgeni
Post by Madgeni »
Thanks Fred - and it works fine with Controlicz? You can set/query temperature? Does it need a hub, or can it connect directly to Domoticz?
Fred78
Post by Fred78 »
Hi Madgeni,
It works fine with Controlicz.
- I can query the value (I still have the "thermostat xxxxx is off" bug, but I guess it's normal for the moment)
- I can set the value (still have Google's bug about comma and decimals here in France)
It's recognized perfectly by domoticz. You don't need a hub. Just the zwave controler. The thermostat shows up two devices: a thermometer sensor and a thermostat setpoint.
kimhaak
Post by kimhaak »
I am still having issues, is there someone who could help me, i would be grateful :)
Kim
kimhaak wrote: Thursday 01 February 2018 21:13 Hi!
Thank you for adding me to the google-test. However, the instructions is a bit unclear, as i do not know what we are trying to achieve, and how conversions.com are related.
I received one link : https://console.actions.google.com/proj ... atorcreate which just says "There was an error completing your request, try again". (Link is censored, in case there was an unique ID in it)
If i follow the conversions guide, i kind of end up with my own project, which i don't think is correct.
Could someone explain to med what the link (https://console.actions.google.com/proj ... atorcreate) is for?
Am i supposed to import this in my actions.google.com account somehow?
Sorry if this is comes of as negativity, i just did not understand what to do, and why. (And i am generally not a n00b in these kind of things)
If this project works and is good, i will definately donate to support the work.
Kim
Madgeni
Post by Madgeni »
PM sent :)
getget
Post by getget »
Hello, today, no 404 :D
l have blinds defined in domoticz. What should I say to open them ?
When I say "ouvre le velux" (open the blind called velux in french) Google says "ok J'allume la lumière velux" (ok I turn on the light velux" ans the blind .... Closes.
