Aurora theme
welby
Re: Aurora theme
Anyone know how to go back to the default theme after using aurora? I installed it to have a look then deciced to go back and now everything looks terrible, all borders are missing and heaps of things are unaligned.
- remb0
Re: Aurora theme
is it possible to place a filter above the pages where you can type (like filtering in log) or select on/off devices?
the android app does this already and it is great because I have so much devices
and yes offcouse you can devide them in rooms.
but some devices are multiple rooms.
is this a nice feature for aurora?
Eoreh
Re: Aurora theme
As always when the topics change, You need to always clear the browser cache, for example Aurora -> Default and even Aurora -> another Aurorewelby wrote: Saturday 03 February 2018 2:12 Anyone know how to go back to the default theme after using aurora? I installed it to have a look then deciced to go back and now everything looks terrible, all borders are missing and heaps of things are unaligned.
I've done it many times and it works.
- htilburgs
Re: Aurora theme
I've an issue with the combining of items. I've several blocks that combine nicely, but 1 block behaves strange.
As you can see, the icons get placed behind the line.
Strange thing is, when I remove the PIR from the list, than it's Ok.
- aurora1.png (56.84 KiB) Viewed 2906 times
- aurora2.png (41.56 KiB) Viewed 2906 times
Hardware:
welby
Re: Aurora theme
Yep your right i thought i had tried that but obviously notEoreh wrote: Saturday 03 February 2018 9:13As always when the topics change, You need to always clear the browser cache, for example Aurora -> Default and even Aurora -> another Aurorewelby wrote: Saturday 03 February 2018 2:12 Anyone know how to go back to the default theme after using aurora? I installed it to have a look then deciced to go back and now everything looks terrible, all borders are missing and heaps of things are unaligned.
Re: Aurora theme
Noticed one thing in aurora theme ligt blue info in protocol isn't displayed.... thats quite confusing...
Re: Aurora theme
Installed this nice Aurora theme, but unfortunately it gives the following (cleaned cache, used various browsers) anyone a suggestion, I cannot get back to the default theme...
Re: Aurora theme
Try remove Cookies...
Re: Aurora theme
in firefox its ok after removing cache/cookies etc.. have the default theme working. Safari en google are showing the Aurora theme (incorrectly)..
blauwebuis
- Domoticz version: current
Re: Aurora theme
@josimd: looks like a permissions problem. Install the theme from the Domoticz device itself. But also check the console to see if you have javascript errors.
CLEMENT99
- Domoticz version: BETA
Re: Aurora theme
@josimd: With Chrome, press F12 to open the developer menu.
1. click Network in the toolbar to open the network pane.
Check the Disable cache checkbox at the top.
2. click Application in the toolbar to open the application pane.
Click Clear storage on the left menu
Click Clear Site Data button.
Re: Aurora theme
How to do that? Im running domoticz (non-beta version) on a synology NAS, I just copied the files to the domoticz directory as indicated..blauwebuis wrote: Sunday 04 February 2018 11:27 @josimd: looks like a permissions problem. Install the theme from the Domoticz device itself. But also check the console to see if you have javascript errors.
blauwebuis
Re: Aurora theme
Do you have access to a shell terminal?
If so, you could
- Download the theme from on the Synology itself. This way the synology account is the owner of the files.
- Change the file permissions (chmod) and ownership (chown) so that the files can be read by anyone ( = people visiting via a web browser )
Ah wait, non-beta? This theme only works on beta. It says so in the first post of this thread.
If so, you could
blauwebuis
Re: Aurora theme
@devros: where is this protocol issue exactly?
Re: Aurora theme
yes you are right.. non-beta.. im running on V3.8153blauwebuis wrote: Sunday 04 February 2018 16:06 Do you have access to a shell terminal?
If so, you could
Re: Aurora theme
Default theme log protocol are black, red and cyan (Shows hardware protocol infos) messages, in aurora only black and red are visible... at least on my machine...
Eoreh
Re: Aurora theme
I do quick test for color in Aurora theme and default theme on my computer. I have the same operation.devros wrote: Sunday 04 February 2018 17:50Default theme log protocol are black, red and cyan (Shows hardware protocol infos) messages, in aurora only black and red are visible... at least on my machine...
I never saw "cyan" in my log, so I wrote quick test. Test make by dzVents script with library for compact syntex "plansModule" (from here -> viewtopic.php?f=59&t=21914)
All code in spoiler below.
- Spoiler: show
Re: Aurora theme
Dunno why but status Bar isnt visible in aurora theme, in other themes looks all OKEoreh wrote: Sunday 04 February 2018 18:50I do quick test for color in Aurora theme and default theme on my computer. I have the same operation.devros wrote: Sunday 04 February 2018 17:50Default theme log protocol are black, red and cyan (Shows hardware protocol infos) messages, in aurora only black and red are visible... at least on my machine...
- Spoiler: show
im using latest beta with latest git version
blauwebuis
Re: Aurora theme
@devros: please read the about section on the theme settings page. If you have the privacy settings to medium, then it hides this log tab.
Re: Aurora theme
ouch, sorry I missed that feature..., should be located in Prefeneces/Logs, but i know that its not possible in current way how is integrated in domoticzblauwebuis wrote: Sunday 04 February 2018 22:06 @devros: please read the about section on the theme settings page. If you have the privacy settings to medium, then it hides this log tab.
