Xiaomi Thermostat (with display)
Is there support for this device in domoticz?
https://m.gearbest.com/robot-vacuum-acc ... 06883.html
Re: Xiaomi Thermostat (with display)
Also interested in this
- Domoticz version: 4.11333
I don't think, that's thermostat. It is just thermometer and humi with display and BT.
____
may
____
may
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
- 2x Xiaomi Gateway
It does say that is has WiFi... And I controlled from the MI app.
WiFi, with one AAA Battery?
I quess, that it's closer to Mi Plant, also MiHome App, also BT.
As thermostat unusable with Domoticz.
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
- Domoticz version: 3.8153
It is def not a thermostat. It is plain thermometer and humidity meter sending data over Bluetooth (no wifi! it's a reseller typo) to mobile phone to Mi Home app. Using single AAA battery with a nice large display (lasting up to a year).
When the price hits <10$ i wouldn't mind buying it then use it in Domoticz via BT. Much easier to replace AAA battery than button one on Xiaomi zigbee devices (thermometer, PIR, etc).
Pi 2 (raspbian stretch) w. Conrad VOC USB, Xiaomi PM 2.5 detector , Xiaomi/Philips bulbs, Mi Flora BT, Xiaomi GW (w. temp/humidity/pir)
Pi Zero W (raspbian stretch) w. - Xiaomi GW (temp/hum/door)
Can we use it via Bluetooth in domoticz?Slokoavac wrote:It is def not a thermostat. It is plain thermometer and humidity meter sending data over Bluetooth (no wifi! it's a reseller typo) to mobile phone to Mi Home app. Using single AAA battery with a nice large display (lasting up to a year).
Enviado desde mi Redmi 4X mediante Tapatalk
i hope so. Has anyone purchased it yet? Price is a bit high at the moment imho...
Yes, and it a pretty neat device! Very accurate and sensitive. However, I haven't been able to connect it to Domoticz (either through Mijia Bedside Lamp as gateway or directly by BT).
Any 1?
How does it connects to Mi Home app? BT via phone? Mijia Bedside Lamp has BT too?
I will order one when price hits 10$
- Eligos
- Domoticz version: 3.8914
The new bedside lamp has Wifi+BT. You connect with Wi-Fi the new bedside lamp in the mi-home app(for full ecosystem integration) or yeelight app (for only lightning option). This lamp is a BT Gateway for all your Xiaomi BT sensors (flower sensor and this new display sensors for temp/humi)I have also this new lamp version but waiting for the new BT sensors with display. The lamp is nice. For more Infos look at this "promo" video:Slokoavac wrote:How does it connects to Mi Home app? BT via phone? Mijia Bedside Lamp has BT too?
https://youtu.be/rKK-hF64IHE
I have only xiaomi mi hygrothermograph (that is the name of the product) sensor with LCD. It works only with mi home app over bluetooth, but I havn't trends and any log. Just shows values of temp and hum.
Is it possible to connect with Domoticz just over bluetooth and achieve that function?
So I've tried, however due to lacking bluetooth + Python skills, I haven't got it working yet.micontije wrote: ↑Friday 12 January 2018 12:39 I have only xiaomi mi hygrothermograph (that is the name of the product) sensor with LCD. It works only with mi home app over bluetooth, but I havn't trends and any log. Just shows values of temp and hum.
I'd rather see see data passage through Xiaomi Thermograph BT --> BT Xiami Bedside Lamp Wifi --> Wifi Router Eth --> Eth Domoticz (RPI)
Oh cool, i thought it only had WiFi. Does miio lib supports it? You can check miio here:Eligos wrote: ↑Friday 12 January 2018 11:12The new bedside lamp has Wifi+BT. You connect with Wi-Fi the new bedside lamp in the mi-home app(for full ecosystem integration) or yeelight app (for only lightning option). This lamp is a BT Gateway for all your Xiaomi BT sensors (flower sensor and this new display sensors for temp/humi)I have also this new lamp version but waiting for the new BT sensors with display. The lamp is nice. For more Infos look at this "promo" video:Slokoavac wrote:How does it connects to Mi Home app? BT via phone? Mijia Bedside Lamp has BT too?
https://github.com/aholstenson/miio
install miio lib, then scan for devices, if the lamp shows up, maybe there is a chance to get data out from it?
There is a brand new Xiaomi thermo/hydrometer, with e-ink display, but w/o any wireless connection, useless
http://barcamp.cr/new-xiaomi-mijia-e-in ... ygrometer/
Check out https://github.com/pFenners/mijia-sensor-domoticz
I got my 3 Xiaomi Mijia Bluetooth Temperature Humidity Sensors linked up to Domoticz using the built-in bluetooth on Raspberry Pi3
Thanks for sharing! Did something very similar (see viewtopic.php?f=56&t=21904), unfortunately with my script values aren´t displayed on the sensors themselfs in Domoticz although the URL I´m calling is the same (even if I add the comfort part) - crazy!PaulFen wrote: ↑Tuesday 30 January 2018 14:40 Check out https://github.com/pFenners/mijia-sensor-domoticz
You're welcome.freibeuter wrote: ↑Tuesday 30 January 2018 17:36Thanks for sharing! Did something very similar (see viewtopic.php?f=56&t=21904), unfortunately with my script values aren´t displayed on the sensors themselfs in Domoticz although the URL I´m calling is the same (even if I add the comfort part) - crazy!PaulFen wrote: ↑Tuesday 30 January 2018 14:40 Check out https://github.com/pFenners/mijia-sensor-domoticz
I had the same issue, it was caused by a null character at the end of the temp& humidity string received from the sensor. After stripping out the null it all worked.
Works pretty well, however I need to set my Mijia BLE Temp + Humidity sensor in 'pairing' (flasing BT icon) mode before I get any readouts. When the RPI sets up the connection, the script updates Domoticz flawless though...PaulFen wrote: ↑Tuesday 30 January 2018 14:40 Check out https://github.com/pFenners/mijia-sensor-domoticz
Maybe the sensor needs to be unpaired with any devices?
Else I receive connect error: Transport endpoint is not connected (107)
