Xiaomi Thermostat (with display)
mhko
Post by mhko »
Is there support for this device in domoticz?
https://m.gearbest.com/robot-vacuum-acc ... 06883.html
mikejclark
Re: Xiaomi Thermostat (with display)
Post by mikejclark »
Also interested in this
mayyam
Domoticz version: 4.11333
Post by mayyam »
I don't think, that's thermostat. It is just thermometer and humi with display and BT.
____
may
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
mikejclark
mayyam wrote: Saturday 16 December 2017 20:59 I don't think, that's thermostat. It is just thermometer and humi with display and BT.
____
may
had a closer look, and yes, you're right!
mhko
Post by mhko »
It does say that is has WiFi... And I controlled from the MI app.
mayyam
Post by mayyam »
WiFi, with one AAA Battery?
I quess, that it's closer to Mi Plant, also MiHome App, also BT.
As thermostat unusable with Domoticz.
_______________
- 2x Xiaomi Gateway
Slokoavac
Domoticz version: 3.8153
Post by Slokoavac »
It is def not a thermostat. It is plain thermometer and humidity meter sending data over Bluetooth (no wifi! it's a reseller typo) to mobile phone to Mi Home app. Using single AAA battery with a nice large display (lasting up to a year).
When the price hits <10$ i wouldn't mind buying it then use it in Domoticz via BT. Much easier to replace AAA battery than button one on Xiaomi zigbee devices (thermometer, PIR, etc).
Pi 2 (raspbian stretch) w. Conrad VOC USB, Xiaomi PM 2.5 detector , Xiaomi/Philips bulbs, Mi Flora BT, Xiaomi GW (w. temp/humidity/pir)
Pi Zero W (raspbian stretch) w. - Xiaomi GW (temp/hum/door)
salvacalatayud
Post by salvacalatayud »
Slokoavac wrote:It is def not a thermostat. It is plain thermometer and humidity meter sending data over Bluetooth (no wifi! it's a reseller typo) to mobile phone to Mi Home app. Using single AAA battery with a nice large display (lasting up to a year).
Can we use it via Bluetooth in domoticz?
Enviado desde mi Redmi 4X mediante Tapatalk
Slokoavac
Post by Slokoavac »
i hope so. Has anyone purchased it yet? Price is a bit high at the moment imho...
RadiQal
Post by RadiQal »
Slokoavac wrote: Wednesday 20 December 2017 0:03 i hope so. Has anyone purchased it yet? Price is a bit high at the moment imho...
Yes, and it a pretty neat device! Very accurate and sensitive. However, I haven't been able to connect it to Domoticz (either through Mijia Bedside Lamp as gateway or directly by BT).
Any 1?
Slokoavac
Post by Slokoavac »
How does it connects to Mi Home app? BT via phone? Mijia Bedside Lamp has BT too?
I will order one when price hits 10$
Eligos
Domoticz version: 3.8914
Post by Eligos »
Slokoavac wrote:How does it connects to Mi Home app? BT via phone? Mijia Bedside Lamp has BT too?
The new bedside lamp has Wifi+BT. You connect with Wi-Fi the new bedside lamp in the mi-home app(for full ecosystem integration) or yeelight app (for only lightning option). This lamp is a BT Gateway for all your Xiaomi BT sensors (flower sensor and this new display sensors for temp/humi)I have also this new lamp version but waiting for the new BT sensors with display. The lamp is nice. For more Infos look at this "promo" video:
https://youtu.be/rKK-hF64IHE
micontije
Post by micontije »
I have only xiaomi mi hygrothermograph (that is the name of the product) sensor with LCD. It works only with mi home app over bluetooth, but I havn't trends and any log. Just shows values of temp and hum.
Is it possible to connect with Domoticz just over bluetooth and achieve that function?
RadiQal
Post by RadiQal »
micontije wrote: Friday 12 January 2018 12:39 I have only xiaomi mi hygrothermograph (that is the name of the product) sensor with LCD. It works only with mi home app over bluetooth, but I havn't trends and any log. Just shows values of temp and hum.
So I've tried, however due to lacking bluetooth + Python skills, I haven't got it working yet.
I'd rather see see data passage through Xiaomi Thermograph BT --> BT Xiami Bedside Lamp Wifi --> Wifi Router Eth --> Eth Domoticz (RPI)
Slokoavac
Post by Slokoavac »
Eligos wrote: Friday 12 January 2018 11:12
Oh cool, i thought it only had WiFi. Does miio lib supports it? You can check miio here:
https://github.com/aholstenson/miio
install miio lib, then scan for devices, if the lamp shows up, maybe there is a chance to get data out from it?
There is a brand new Xiaomi thermo/hydrometer, with e-ink display, but w/o any wireless connection, useless :(
http://barcamp.cr/new-xiaomi-mijia-e-in ... ygrometer/
PaulFen
Post by PaulFen »
Check out https://github.com/pFenners/mijia-sensor-domoticz
I got my 3 Xiaomi Mijia Bluetooth Temperature Humidity Sensors linked up to Domoticz using the built-in bluetooth on Raspberry Pi3
freibeuter
Post by freibeuter »
PaulFen wrote: Tuesday 30 January 2018 14:40 Check out https://github.com/pFenners/mijia-sensor-domoticz
Thanks for sharing! Did something very similar (see viewtopic.php?f=56&t=21904), unfortunately with my script values aren´t displayed on the sensors themselfs in Domoticz although the URL I´m calling is the same (even if I add the comfort part) - crazy!
PaulFen
Post by PaulFen »
freibeuter wrote: Tuesday 30 January 2018 17:36
You're welcome.
I had the same issue, it was caused by a null character at the end of the temp& humidity string received from the sensor. After stripping out the null it all worked.
freibeuter
PaulFen wrote: Tuesday 30 January 2018 19:36 After stripping out the null it all worked.
gosh - you were right about this - totally missed the hex 00 in ascii string. Added fix to my script, too.
RadiQal
Post by RadiQal »
Works pretty well, however I need to set my Mijia BLE Temp + Humidity sensor in 'pairing' (flasing BT icon) mode before I get any readouts. When the RPI sets up the connection, the script updates Domoticz flawless though...
Maybe the sensor needs to be unpaired with any devices?
Else I receive connect error: Transport endpoint is not connected (107)
