Thanks, great work!jumbotroll wrote: ↑Tuesday 02 January 2018 9:15 Sorry, but I deleted the stable version because of a driver bug.
Compiled new version for you with fixed driver here:
http://www.jadahl.com/domoticz_stable_6.1/?arch=rtd1296
Beta:
http://www.jadahl.com/domoticz_beta_6.1 ... 8797-7.spk
Manual download and install.
domoticz in synology as package! Available now.
Hello jumbotroll
Congratulations for your work.
Can you make a package available for DSM 6.2 Braswell ? ( I use a DS216+II)
What are the differences between the 6.1 and 6.2 packages ?
Do 6.1 packages work well on DSM 6.2 ? (That's what I do)
How do you make these packages ?
Thank you in advance
Sorry for my english, I use the Google translation from french
- jumbotroll
You can use domoticz DSM6.1 arch-braswell (DS216+II) version on DSM6.2 it's using the same linux kernel 3.10.102.nobruu wrote: ↑Friday 12 January 2018 13:28 Hello jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
Jumbotroll
I got a NetCat Problem on my DS216J with DSM 6.1 & Domoticz 3.8153
Somehow i got Netcat to Work when i loggin with Putty on my NAS.
But triggering Netcat within Lua Domoticz.
I found this error in de log file within DSM6.1.
More details are here; To stay ontopic:
viewtopic.php?f=31&t=10050&start=20#p166850
SH: NC Command not found
- Domoticz version: 3.8872
Can anybody tell me if it is possible en howto to upgrade from stable to beta on a Synology?
and if I look on http://www.jadahl.com/domoticz_beta_6.1_python/ I see a lot of packages which one do I need?
I use a Synology 1515+
Thanks,
Mischa
Thanks,
Mischa
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
- jumbotroll
DS1515+ use arch-avoton.mischa wrote: ↑Wednesday 24 January 2018 21:27 Can anybody tell me if it is possible en howto to upgrade from stable to beta on a Synology?
Thanks,
Mischa
Take backup of database and scripts if you have any and uninstall the stable domoticz package.
The download beta package you want to test and manually install from package center and restore your database and you are good to go.
If you install Python plugin packages, you also have to install Python first!
From here:http://ukdl.synology.com/download/Packa ... 1-0105.spk
Jumbotroll
Jumbotroll
Thanks for you quick answer, is DZVents 2.4 already in the lasted synology beta?
- jumbotroll
Yes In domoticz beta 3.0.8837 or newer.
If not your version is compiled yet, it will be updated soon.
Jumbotroll
Jumbotroll
What is the normal process of updating?
Always deinstall package and then reinstall new package or does this only apply to the beta packages?
- jumbotroll
Only If you have and very old version or you change from non python version to a python version.
Jumbotroll
Jumbotroll
But the latest beta version on your site is 3.0.8836 ??jumbotroll wrote: ↑Wednesday 24 January 2018 21:52Yes In domoticz beta 3.0.8837 or newer.
Hi!
This is probably a very basic question, but I am almost going crazy since I still have not been able to find where the installation folder of Domotics on my NAS.
I have installed the latest Domoticz package on a Synology NAS with the Jadahl package. Everything is working well, I have already added several sensors/switches and added some logic/events.
Now I want to try to upload a floor plan image of my house, but I can not find the Domoticz installation folder anywhere in my NAS! I see that several people say the installation path is /usr/local/domoticz? I have looked in my entire NAS folders (manually and I have also searched) and did not find any domotics folder anywhere! :-/
I would appreciate any guidance on where it could be.... :-/
- waaren
On my system (916+, DSM 6.2 , domoticz 3.8805)
cd /var/packages/domoticz
ls -l
target -> /volume1/@appstore/domoticz
cd /volume1/@appstore/domoticz
ls -l
drwxrwsrwx 1 domoticz root 1718 Jan 15 23:00 var
cd var
ls -l domo*
-rwxrwxrwx 1 domoticz root 360 Jan 26 09:10 domocookie.txt
-rwxr-xr-x 1 domoticz root 10015488 Sep 19 17:28 domoticz
-rwxrwxrwx 1 domoticz root 14182400 Jan 26 09:10 domoticz.db
-rwxrwxrwx 1 domoticz root 163840 Jan 26 09:11 domoticz.db-shm
-rwxrwxrwx 1 domoticz root 17286792 Jan 26 09:11 domoticz.db-wal
-rwxrwxrwx 1 domoticz root 2497480 Jan 26 09:10 domoticz.log
-rw-r--r-- 1 domoticz root 9 Jan 26 09:10 domoticz.mem
-rw-r--r-- 1 root root 6 Jan 15 23:00 domoticz.pid
-rw-r--r-- 1 domoticz root 4347 Dec 18 2016 domoticz.sh
It is in the @apps folder, notvisible with the Windows explorer of Mac Finder.
Now atwork but tonight a Will make a wiki how to make a softlink to that folder and mount it as an sharered folder.
You van then access it trough Windows explorer or Mac Finder.
Mischa
Mischa
A wiki would be really awesome mischa, Big Thanks!
Wiki page created. https://www.domoticz.com/wiki/Synology_ ... ion_folder
Working on some images. but the text should get you there.
If anyone wants to contribute or make changes to the wiki page be my guest todo so.
Mischa
Mischa
- Domoticz version: Stable
First thanks for all the effort you put in the Domoticz synology packages!
Can you confirm if by any means the follwing z-wave patch is added in stable DSM6.1 package ?
https://github.com/OpenZWave/open-zwave/pull/1125.patch
viewtopic.php?f=31&t=12539&start=20#p135154
If not, would be nice if it is possible, so i can use my scene controller again.
- jumbotroll
This patch is not added in the stable packages for DSM6.1.SystemLord wrote: ↑Saturday 27 January 2018 16:40 First thanks for all the effort you put in the Domoticz synology packages!
If you want to test, I can build a beta package for you with this 1125.patch, but what NAS do you want me to build this for?
Edit: I have build some test packages with 1125.patch for DSM6.1
You can download from here: http://www.jadahl.com/domoticz_beta_6.1/
The test packages is located in folder /OpenZwave_1125.patch/
Last edited by jumbotroll on Saturday 27 January 2018 20:27, edited 1 time in total.
Jumbotroll
Jumbotroll
- gijsje
If i want to update to the beta version can i do this over the update Domoticz button or do i need to download the latest version for Synology and install it on the DS218+ nas?
I did look but i guess the latest version is not yet done yet for my system!??
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
- jumbotroll
Beta packages, you have to manually download and install in package center on your NAS.gijsje wrote: ↑Saturday 27 January 2018 20:19 If i want to update to the beta version can i do this over the update Domoticz button or do i need to download the latest version for Synology and install it on the DS218+ nas?
DS218+ use arch-apollolake
DSM6.1 version:
DSM6.2 Beta:
http://www.jadahl.com/domoticz_beta_6.2/
Jumbotroll
Jumbotroll
