Buienradar Weather Lookup Plugin
rjblake
Re: Buienradar Weather Lookup Plugin
Post by rjblake »
waaren wrote: Wednesday 06 December 2017 8:46 Still the same problem with version Domoticz V3.8771 and one or more active plugins.
I use buienradar, homewizard, NUT_UPS and Sonos. If I make any or all of these plugins active, domoticz crashes with:
2017-12-06 08:38:18.481 PluginSystem: Entering work loop.
2017-12-06 08:38:18.650 Error: Domoticz received fatal signal 11 !...
2017-12-06 08:38:18.651 Error: /opt/domoticz/domoticz() [0x236254]
2017-12-06 08:38:18.652 Error: /opt/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x23630c]
2017-12-06 08:38:18.652 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c7e6b0]
on my RPI3 latest working Beta is domoticz.v3.8627
Still causes Domoticz to crash/fail to start on Raspberry Pi v3.8793 in my case. I have another Python plugin (Denon AVR) that is working just fine
AndreFR
Post by AndreFR »
I noticed that the buienrader plugin is giving some errors:
2017-12-20 08:08:38.909 Error: (Buienradar ) Error: URL: http://xml.buienradar.nl/
2017-12-20 08:08:38.913 Error: (Buienradar ) Error: URL: https://api.buienradar.nl/
2017-12-20 08:19:08.951 Error: (Buienradar ) 'onHeartbeat' failed 'TypeError':'type NoneType doesn't define __round__ method'.
2017-12-20 08:19:08.951 Error: (Buienradar ) ----> Line 143 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-12-20 08:19:08.951 Error: (Buienradar ) ----> Line 133 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function onHeartbeat
2017-12-20 08:19:08.951 Error: (Buienradar ) ----> Line 277 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function fillDevices
(above is repeating xx minutes).
I've nothing changed on my Raspberry Pi, even after reboot of the Pi the errors are occurin. Any solution???
Derik
Post by Derik »
Dear developer....
Is there perhaps a option to use the wind chill separate as 1 device?
I think this a extra option in the winter...
The data is in the list:
2018-01-07 23:10:58.332 (D.M.: Buienradar) Wind Speed: 5.19 | Wind Bearing: 60.0 | Wind Direction: ENE | Wind Speed Gusts: 10.0 | Wind Chill: -6.4
Or can you make this in your plugin like the text funtion etc etc
2018-01-07 23:10:58.333 (D.M.: Buienradar) Weather prediction today: Wind maakt het extra koud (Opgesteld op zondag 7 jan 2018 om 10:15)
Thanks from my kids... when they get a mail how cold it feels when they have to go school..:-)
EddyG
Post by EddyG »
If you want, you can do it manually by adding device 13 in the file plugin.py. It works for me.
@ffes This could be a choice in the setup. ;)
    # Add the wind (and wind chill?) device
    if Parameters["Mode5"] == "True":
        if 6 not in Devices:
            Domoticz.Device(Name="Wind", Unit=6, TypeName="Wind+Temp+Chill", Used=1).Create()
    else:
        if 5 not in Devices:
            Domoticz.Device(Name="Wind", Unit=5, TypeName="Wind", Used=1).Create()
        if 13 not in Devices:
            Domoticz.Device(Name="Wind Chill", Unit=13, TypeName="Temperature", Used=1).Create()
and
        # Wind
        if br.windBearing != None and br.windSpeed != None and br.windSpeedGusts != None:
            UpdateDevice(5, 0, str(br.windBearing)
                    + ";" + br.getWindDirection()
                    + ";" + str(round(br.windSpeed * 10))
                    + ";" + str(round(br.windSpeedGusts * 10))
                    + ";0;0")
            # Wind and Wind Chill
            UpdateDevice(6, 0, str(br.windBearing)
                    + ";" + str(round(br.temperature, 1))
                    + ";" + str(br.getWindChill()))
            # Wind Chill
            UpdateDevice(13, 0, str(br.getWindChill()))
Derik
Post by Derik »
@ Eddy...
Thanks looks great...
Make no different where in the plugin.py?
And is there then a new device visible in domoticz?
Please some more info..
EddyG
Post by EddyG »
Put it in the place where I put it. It the code with unit 13.
You can see by the code where.
Yes there will be a new device in the Temperature tab with 'Buienrader Wind Chill'
The parts to be added are:
and
# Wind Chill
Derik
Post by Derik »
mmm Get an error:
2018-01-08 16:13:32.751 Error: D.M.: Buienradar hardware (76) thread seems to have ended unexpectedly
Did use 1 of the first version and never did a update..
Perhaps there is a pr in github possible?
To make this standard...
Edit:
Start again everything removed..
New plugin install latest version...
Copy paste your latest code
Only error in the log:
2018-01-08 16:37:25.382 (Solar: Dummy) Started.
2018-01-08 16:37:25.455 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/root/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5/:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-01-08 16:37:25.455 Error: (Solar: Dummy) Module Import failed, exception: 'IndentationError'
2018-01-08 16:37:25.456 Error: (Solar: Dummy) Import detail: File: /home/root/domoticz/plugins/domoticz-buienradar/plugin.py, Line: -1239619133, offset: 232
2018-01-08 16:37:25.456 Error: (Solar: Dummy) Error Line ' if 13 not in Devices:
Perhaps you can share your plugin.py code?
EddyG
Post by EddyG »
This my plugin.py (I had to upload with py changed in txt)
The "exception: 'IndentationError'" explains why.
plugin.txt
(12.39 KiB) Downloaded 152 times
Derik
Post by Derik »
@ Edy THANKS!!!
this did the tric :-)
Got him:
And the thing i mis i think:
Thanks for the support!!
EddyG
Post by EddyG »
Not completely the same:
In the Temperature tab 2 Temperature device like below.
Derik
Post by Derik »
mmm
I did a new install because there was something wrong...
Only now i get an error in the wget step:
root@odroidxu4:/home/root/domoticz/plugins# git clone https://github.com/ffes/domoticz-buienradar.git
Cloning into 'domoticz-buienradar'...
fatal: unable to access 'https://github.com/ffes/domoticz-buienradar.git/': Could not resolve host: github.com
Perhaps something changed???
EdwinK
Post by EdwinK »
I just tried this myself a couple of minutes ago, and no errors cloning this plugin.
(still can't get it to work though)
 sudo git clone https://github.com/ffes/domoticz-buienradar.git Buienradar
Cloning into 'Buienradar'...
remote: Counting objects: 154, done.
remote: Compressing objects: 100% (8/8), done.
remote: Total 154 (delta 2), reused 8 (delta 2), pack-reused 143
Receiving objects: 100% (154/154), 51.65 KiB | 38.00 KiB/s, done.
Resolving deltas: 100% (85/85), done.
tezzlicious
Post by tezzlicious »
Following happens on beta 3.8862 (removed and readded Buienradar hardware):
2018-01-20 18:36:23.075  (Buienradar) Found Meetstation Heino (ID: 6278) at 23.6 km from your home location
2018-01-20 18:36:23.076  (Buienradar) No Barometer and Visibility info found in your weather station, getting info from weather station De Bilt
2018-01-20 18:36:23.077  (Buienradar) Temperature: 2.8
2018-01-20 18:36:23.077  (Buienradar) Wind Speed: 0.92 | Wind Bearing: 95.0 | Wind Direction: E | Wind Speed Gusts: 1.2 | Wind Chill: 2.8
2018-01-20 18:36:23.077  (Buienradar) Barometer: 1000.44 | Barometer Forecast: 2
2018-01-20 18:36:23.077  (Buienradar) Humidity: 97 | Humidity status: 3
2018-01-20 18:36:23.077  (Buienradar) Visibility: 15600.0
2018-01-20 18:36:23.077  (Buienradar) Solar Irradiance: None
2018-01-20 18:36:23.077  (Buienradar) Rain rate: None
2018-01-20 18:36:23.078  (Buienradar) Weather prediction today: Af en toe nog winters (Opgesteld op zaterdag 20 jan 2018 om 05:45)
2018-01-20 18:36:23.079  Error: Domoticz received fatal signal 11 !...
2018-01-20 18:36:23.081  Error:   /home/pi/domoticz/domoticz() [0x209a84]
2018-01-20 18:36:23.081  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x209b3c]
2018-01-20 18:36:23.081  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76bf3180]
dutchy
Post by dutchy »
Dear members,
I'm trying to install buienradar in my Windows setup, but I'm unable to find the plugins folder. I've been trying to use the manual on the github page, but it seems that I'm missing something.
Can someone help me out?
htilburgs
Post by htilburgs »
Domoticz v3.8833 (Fresh install by compile)
After installing this plugin, I received an error
Other plugins work fine. Disable this plugin and everything is fine again. Any ideas?
Hardware:
Derik
Post by Derik »
mmmm There is something more going wrong...
When i set the [old] plugin in the plugin area..
Reboot ..
Domoticz crash: [ Active: active (exited) ]
 domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh; bad; vendor preset: enabled)
   Active: active (exited) since Sun 2018-01-21 22:37:23 CET; 43s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 688 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Jan 21 22:37:22 odroid systemd[1]: Starting LSB: Home Automation System...
Jan 21 22:37:23 odroid domoticz.sh[688]: 2018-01-21 22:37:23.381  Domoticz V3.8833 (c)2012-2018 GizMoCuz
Jan 21 22:37:23 odroid domoticz.sh[688]: 2018-01-21 22:37:23.381  Build Hash: 60050638, Date: 2018-01-19 13:22:13
Jan 21 22:37:23 odroid domoticz.sh[688]: 2018-01-21 22:37:23.382  Startup Path: /home/root/domoticz/
Jan 21 22:37:23 odroid domoticz.sh[688]: domoticz: Domoticz is starting up....
Jan 21 22:37:23 odroid domoticz[700]: Domoticz is starting up....
Jan 21 22:37:23 odroid domoticz[703]: Domoticz running...
Jan 21 22:37:23 odroid systemd[1]: Started LSB: Home Automation System.
root@odroid:~# shutdown -r now
login as: root
[email protected]'s password:
Welcome to Ubuntu 16.04.3 LTS (GNU/Linux 4.14.13-100 armv7l)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
Last login: Sun Jan 21 22:38:05 2018 from 192.168.5.5
root@odroid:~# service domoticz.sh status
● domoticz.service - LSB: Home Automation System
   Active: active (running) since Sun 2018-01-21 22:39:01 CET; 43s ago
  Process: 690 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Jan 21 22:39:00 odroid systemd[1]: Starting LSB: Home Automation System...
Jan 21 22:39:01 odroid domoticz.sh[690]: 2018-01-21 22:39:01.571  Domoticz V3.8833 (c)2012-2018 GizMoCuz
Jan 21 22:39:01 odroid domoticz.sh[690]: 2018-01-21 22:39:01.571  Build Hash: 60050638, Date: 2018-01-19 13:22:13
Jan 21 22:39:01 odroid domoticz.sh[690]: 2018-01-21 22:39:01.571  Startup Path: /home/root/domoticz/
Jan 21 22:39:01 odroid domoticz.sh[690]: domoticz: Domoticz is starting up....
Jan 21 22:39:01 odroid domoticz[696]: Domoticz is starting up....
Jan 21 22:39:01 odroid domoticz[701]: Domoticz running...
Jan 21 22:39:01 odroid systemd[1]: Started LSB: Home Automation System
First with, and second without plugin..?
Perhaps a solution?
My director love the weather on the tablet.. :-)
Snowtiger
Domoticz version: 4.10915
Post by Snowtiger »
I have the same problem with Beta V3.8833, Raspberry Pi 3 -
Part of the log file
  (Buienradar) Entering work loop.
2018-01-22 11:55:38.485  (Buienradar) Initialized version 1.1.0, author 'ffes'
2018-01-22 11:55:40.101  Error: Domoticz received fatal signal 11 !...
2018-01-22 11:55:40.112  Error:   /home/pi/domoticz/domoticz() [0x238be8]
2018-01-22 11:55:40.112  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x238ca0]
2018-01-22 11:55:40.112  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76c991
I am still using the default ffes Buienradar but that should make no difference Image
Edit - that made a difference - now at Gerard33 version - no problems anymore but also no Buienradar present in the Hardware tab - let's see what's going wrong :)
Derik
Post by Derik »
Mmmm think it is in the python versions..
I did upgrade tot latest python and then all my plugin fuckup.
EdwinK
Post by EdwinK »
I think it's Python too. There are too many versions going around, some scripts needs python2 others python3 It's getting difficult to get things running.
Snowtiger
Post by Snowtiger »
Got Gerard33 version of Buienradar active - same error in Domoticz log
 OpenZWave: Driver Ready
2018-01-22 12:54:01.671  (Buienradar (gerard33)) Entering work loop.
2018-01-22 12:54:01.672  (Buienradar (gerard33)) Initialized version 2.0, author 'ffes'
2018-01-22 12:54:01.750  MQTT: Connecting to localhost:1883
2018-01-22 12:54:01.852  MQTT: connected to: localhost:1883
2018-01-22 12:54:01.953  MQTT: Subscribed
2018-01-22 12:54:02.073  Error: Domoticz received fatal signal 11 !...
2018-01-22 12:54:02.077  Error:   /home/pi/domoticz/domoticz() [0x238be8]
2018-01-22 12:54:02.077  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x238ca0]
2018-01-22 12:54:02.077  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76c74180]
now I am out of options.....
Raspberry Pi 3
Running Debian Jessy
Python 3.4
Domoticz V3.8833 (Bèta)
