Is it gonna rain within the next X minutes?
quilae
Re: Is it gonna rain within the next X minutes?
Post by quilae »
All right, I see the problem. I thought the term "rain device" in the script was just descriptive, but it's not. It needs to be a device of type 'rain" not just a "text" device. So now it's working.
Brutus
Post by Brutus »
Does anyone else experience that there rain.tmp file is empty?
The link:
url='http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon..''
gives me output in any browser. The rain.tmp file gets refreshed every minute but it's empty.
So the rain prediction gives now the output: -nan(ind)
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
DutchHans
Post by DutchHans »
Yes, I have the same...
jvdz
Domoticz version: 4.107
Post by jvdz »
Works fine here scheduled with crontab.
How are you running the script ? Did it ever work and stopped?
Jos
DutchHans
Post by DutchHans »
Hi Jos...
It worked flawlessly for years but suddenly it stopped. I see no reason why. The URL shows in the browser the correct data but the tempfile is not written. I've tried to write it under a different name but its not written.
I have no idea why...
I am running the script as a lua time file, fired every 15 minutes
Regards,Hans
Brutus
Post by Brutus »
jvdz wrote: Wednesday 27 December 2017 11:53 Works fine here scheduled with crontab.
Jos
Hi Jos,
I have implemented this script in my LUA screens time script and runs every minute. But as DutchHans says it has run for years. I did not change anything suddently it stopped working.
I'm running: Windows 7 64 Bits with Domoticz V3.8721
Greetings
28x Fibaro Modules
SMA Solar System
DutchHans
Post by DutchHans »
Solved!
The URL is converted from http in https in the browser.
When you change http into https in the script it works again.
Cheers, Hans
DutchHans
Post by DutchHans »
Solved!
Cheers, Hans
EdwinK
Post by EdwinK »
This line?
-- url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon  -- old link
url='https://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon
DutchHans
Post by DutchHans »
The first line is commented (because of the -- at the beginning) that one doesn't matter. The line that matters is:
url='https://gadgets.buienradar.nl/data/raintext/?lat='..lat..'&lon='..lon
Regards,Hans
EdwinK
Post by EdwinK »
Okay, then I have the correct one. Knew that the first line was commented, copy/paste and too lazy to remove it.
Brutus
Post by Brutus »
DutchHans wrote: Wednesday 27 December 2017 13:04 Solved!
Cheers, Hans
Thnx, This solved it for me to.
28x Fibaro Modules
SMA Solar System
mvroosmalen
Post by mvroosmalen »
after being unable to get info from the regular site, I decide to search for a website that would do the trick again and.. :-) its working again. Still not fully satisfied I made some changes to the original code. If you appreciate the changes, enjoy !!!
I pasted the full code in this message :-)
-- IsItGonnaRain( int minutesinfuture)
-- returns: int avarage rainfall for the next minutesinfuture
-- Function to get rain prediction from Buienradar.nl (dutch)
-- http://gratisweerdata.buienradar.nl/#Buienradar You may use their free service for non-commercial purposes.
-- rewriten by mvroosmalen @ gmx net
-- 30-12-2017 v0.6 modified by MvR removed temp file etc. changed website (default was not working for me)
-- Written in LUA by Hans van der Heijden (h4nsie @ gmail.com)
-- 03-03-2017 v0.5 function removed and start and end time included
--                 text output included which shows first rain period and duration
-- 14-11-2016 v0.4 changed lat/lon to max 2 decmals after comma
-- 28-03-2015 v0.3 bug: quotes around url added.
-- 27-03-2015 v0.2 return value is now average for next time
-- 26-03-2015 v0.1 Initial release
-- todo: some error checking on http and file handling (tmp file)
-- config ------------------------------------------------------------------------------------------------------
   lat='51.11'                         -- example lat/lon for Tilburg
   lon='5.13'                          -- NOTE: lat and lon should have max 2 decimals after dot to function (requirement Buienradar)
   debug=false                         -- True to log all changes
   minuten=10                          -- Rain check periode
   text_sensor='regeninfo'
   IDX_txt_sensor='395'                -- IDx text sensor for perminent rain notifications
   regen_sensor='Rain expected'        -- Rain sensor switch (on/off)
   http = require("socket.http")
   domoticzurl='192.168.1.xxx:yyy'    -- domoticz website
   Rain_alert=0.2                     -- Alert when maxrain is exceeding .... mm/hour .
-- functions ---------------------------------------------------------------------------------------------------
function Round(num, idp)
    local mult = 10^(idp or 0)
    return math.floor(num * mult + 0.5) / mult
function lines(str)
  local t = {}
  local function helper(line) table.insert(t, line) return "" end
  helper((str:gsub("(.-)\r?\n", helper)))
  return t
-- Main code ----------------------------------------------------------------------------------------------------
-- check if variable geenregen is present, if not create it to store rain status
if (uservariables['geenregen'] == nil) then
    commandArray['OpenURL']=domoticzurl..'/json.htm?type=command&param=saveuservariable&vname='..UrlEncode('geenregen')..'&vtype=2&vvalue=0'
time = os.date("*t")
if ((time.min % minuten)==0) then
   ----- check REGEN ------
   -- use
   -- url='http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon
   -- or
   -- url='http://br-gpsgadget-new.azurewebsites.net/data/raintext?lat='..lat..'&lon='..lon
   -- isn't working sice 2016/08/29: url is changed in:
   body = http.request(url)
   if debug then print(url) end
   -- if nothing received then exit
   if body == nil then
       if debug then print ("rain: no data recieved") end
    row=lines(body)
    if debug then print (body) end
    -- check only if more the 4 lines of data are captured
    if #row>4 then
        starttijd=nil
        eindtijd=nil
        totalrain=0
        gevonden=false
        rainlines=0
        maxrain=0
        -- now analyse the received lines, format is like 000|15:30 per line.
        for t=1,#row do
            if string.find(row[t],'|')==nil then break end
            if debug then print('Line:'..row[t]) end
            linetime=string.sub(row[t], 5, 9)
            if debug then print('Linetime: '..linetime) end
            rain=tonumber(string.sub(row[t], 0, 3))
            totalrain = totalrain+rain
            if gevonden then rainlines=rainlines+1 end
            if debug then print('Rain in timerange: '..rain) end
            if debug then print('Total rain now: '..totalrain) end
            if ((not gevonden) and (rain>0)) then
                starttijd=linetime
                gevonden=true
                if debug then print('Rain starts at: '..starttijd) end
            if (gevonden and (rain>maxrain)) then maxrain=rain end
            if ((gevonden) and (rain==0)) then
                eindtijd=linetime
                if debug then print('Rain ends at: '..eindtijd) end
                gevonden=false
                break
        if gevonden then eindtijd=">"..linetime end
        -- Returned value is average rain fall for next time
        -- 0 is no rain, 255 is very heavy rain
        -- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
        if (totalrain>0) then
            regen=totalrain/rainlines
            regen=Round(10^((regen -109)/32),2)
            maxrain=Round(10^((maxrain -109)/32),2)
            regen=0
        if debug then print('regen = '..regen) end
        if (starttijd==nil) then
            --print('Geen regen verwacht over '..minuten)
            if debug then print('starttijd is empty: geen regen verwacht') end
            if tonumber(uservariables['geenregen'])==0 then
                commandArray['UpdateDevice']=IDX_txt_sensor..'|0|'..'geen regen verwacht'
                commandArray['Variable:geenregen']="1";
            starttijd=0
            if eindtijd==nil then eindtijd=0 end
            commandArray['UpdateDevice']=IDX_txt_sensor..'|0|'..regen..'mm/h om '..starttijd..' tot '..eindtijd..' Max=' .. maxrain..'mm/h'
            if debug then print('Regen verwachting: '..regen..' mm/h om '..starttijd..' tot '..eindtijd) end
            commandArray['Variable:geenregen']="0";
            if debug then print('starttijd = '..starttijd) end
        -- Linetime2 holds the full date calculated from the time on a line
        linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(starttijd,1,2), min=string.sub(starttijd,4,5), sec=os.date('%S')}
        difference = os.difftime (linetime2,os.time())
        -- When a line entry has a time in the future AND is in the given range, then report the rainfall
        if ((difference >= 0) and (difference<=minuten*60)) then
            if debug then print('Line in time range found') end
            if maxrain > Rain_alert and otherdevices[regen_sensor]=='Off' then
                commandArray['SendNotification']='Regen verwacht: '..regen..'mm/h om '..starttijd..' tot '..eindtijd..' Max=' .. maxrain..'mm/h'
            if maxrain > Rain_alert then commandArray['Rain expected']='On' end
        if regen == 0 and otherdevices[regen_sensor]=='On' then
            if debug then print('No rain expected') end
            commandArray['SendNotification']='Geen regen meer verwacht'
        if regen == 0 then commandArray['Rain expected']='Off' end
Thanks for the tip EdwinK :-)
Last edited by mvroosmalen on Sunday 31 December 2017 15:05, edited 6 times in total.
EdwinK
Post by EdwinK »
You can post your code here, instead of adding files.
Just use [ code ] and [/ code ] tags (remove spaces from the tags.
Mace
Domoticz version: 3.8153
Post by Mace »
I get bombarded with notifications raging from email thru pushbullet....How can I limit the notifications to 1 medium?
mvroosmalen
Change the Rain_alert=0.2 to a higher value.
Mark
Mace
Post by Mace »
He Mark. I'd like to get notifications only thru one channel. Now it's everything (mail, pushbullet, ...). So it's not the frequency.
mvroosmalen
He mace,
In that case change then commandArray['SendNotification']=....... to code to only send to for example pushbullet or change settings.
s6
Mark
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
no matter what i do i get a error
2018-01-24 12:31:00.305  LUA: http://gadgets.buienradar.nl/data/raintext/?lat=52.06&lon=4.39
2018-01-24 12:31:00.420  Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_raintext.lua: /home/pi/domoticz/scripts/lua/script_time_raintext.lua:14: attempt to index global 'file' (a nil value)
How can i solve this?
output of the http link:
000|12:30
000|12:35
000|12:40
000|12:45
000|12:50
000|12:55
000|13:00
000|13:05
000|13:10
000|13:15
000|13:20
000|13:25
000|13:30
000|13:35
000|13:40
000|13:45
000|13:50
000|13:55
000|14:00
000|14:05
000|14:10
000|14:15
000|14:20
000|14:25
Mace
Post by Mace »
mvroosmalen wrote: Tuesday 23 January 2018 7:51 He mace,
s6
Mark
Thanks Mark, I however have no clue on how to doe that... ;)
