Upgrade LUA 5.1 ==> 5.3
emme
Domoticz version: latest
Post by emme »
Ciao,
on a PI based system is it possibile to upgrade LUA from actual 5.1 to 5.3?
The main reason of this is the posibility to use the UTF8 support now included in LUA...
I'v seen that the upgrade procedure is quite simple: install and symlink the executible as /usr/bin/lua but is this enogh for Domoticz or does it need to be recompiled?
ciao
M
"We always done this way"
Siewert308SW
Domoticz version: Stable
Re: Upgrade LUA 5.1 ==> 5.3
Post by Siewert308SW »
Doesn't work that way.
Domoticz needs to be recompiled, Domoticz uses a compiled Lua version internally.
At the moment we are testing if Lua 5.3 is compatible.
https://github.com/domoticz/domoticz/pull/2061
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
emme
Post by emme »
thank you!
Siewert308SW
btw:
Doesn't mean it will be implanted or not.
Two years ago Gizmocuz also tried to update Lua but there where major complications.
Setup:
- DS923+ Docker
