Ciao,
on a PI based system is it possibile to upgrade LUA from actual 5.1 to 5.3?
The main reason of this is the posibility to use the UTF8 support now included in LUA...
I'v seen that the upgrade procedure is quite simple: install and symlink the executible as /usr/bin/lua but is this enogh for Domoticz or does it need to be recompiled?
ciao
M
Upgrade LUA 5.1 ==> 5.3
- emme
- Domoticz version: latest
"We always done this way"
- Siewert308SW
- Domoticz version: Stable
Re: Upgrade LUA 5.1 ==> 5.3
Doesn't work that way.
Domoticz needs to be recompiled, Domoticz uses a compiled Lua version internally.
At the moment we are testing if Lua 5.3 is compatible.
https://github.com/domoticz/domoticz/pull/2061
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
- emme
thank you!
- Siewert308SW
btw:
Doesn't mean it will be implanted or not.
Two years ago Gizmocuz also tried to update Lua but there where major complications.
Setup:
- DS923+ Docker
- DS923+ Docker
