I change the heatmode of my Spirit Plus Thermostats using a dzVents Script.
You may try something like:
domoticz.devices('Thermostat Mode').updateMode('Off')Best regards Dirk
domoticz.devices('Thermostat Mode').updateMode('Off')Code: Select all
<Product type="0003" id="0003" name="EUR_SPIRITZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_spiritz.xml"/>Thanks, I will try this (when I find the timeStockfisch wrote: Monday 15 January 2018 10:18 Hi ryen,
You may try something like:See the Spirit Plus user manual chapter 6.8 for the Heat Mode Parameters.Code: Select all
Best regards Dirk
Toon Thermostat | Mi-Light | Z-Wave Thermostat valves and CO2 / fire detection units | KiKa | Heat-IT Zwave thermostat |Code: Select all
--- Config/manufacturer_specific.xml 2018-01-26 15:11:27.000000000 +0100
+++ Config/manufacturer_specific.xml 2018-01-01 16:19:46.000000000 +0100
@@ -371,6 +371,7 @@
<Manufacturer id="0148" name="EUROtronic">
<Product type="0001" id="0001" name="EUR_STELLAZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_stellaz.xml"/>
<Product type="0002" id="0001" name="EUR_COMETZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_cometz.xml"/>
+ <Product type="0003" id="0001" name="EUR_SPIRITZ Wall Radiator Thermostat" config="eurotronic/eur_spiritz.xml"/>
</Manufacturer>
<Manufacturer id="0128" name="Eneco">
<Product type="0000" id="0000" name="ED2.0 Meter Adapter"/>
Hi pipiche,pipiche wrote: Friday 15 June 2018 16:33 I'm using Tobias' repository in reference to this issue : https://github.com/OpenZWave/open-zwave/pull/1341
But still I don't have conclusive status
- Fibaro FGT-001 doesn't report thermostat temperature. If I set a temperature on the Thermostat itself I don't see this setpoint coming back to Domoticz .
- SPIRIT : Looks like the setpoint value is not displayed on the Thermostat screen ? Is that expected ? And if I set a temperature on the Thermostat itself I don't see this setpoint coming back to Domoticz .
