Blockly script with event type Time dont fire
Hjalmarsson
Domoticz version: 3.8153
Post by Hjalmarsson »
On Raspberry Pi3
I have a blockly event that doesnt seem to work.
It is based on the event type time and should fire every minute.
I can see in the extended log file that Domoticz is running timed events every minute on the minute,
but nothing happens
Any ideas?
// Jörgen
jvdz
Domoticz version: 4.107
Re: Blockly script with event type Time dont fire
Post by jvdz »
You are testing for On in both tests. What is the value of TimerTest?
Jos
Hjalmarsson
Sorry it should bee off.
I have tried both on and off but no message in the log
This was another try at it, same result, nothing
// J
jvdz
Post by jvdz »
jvdz wrote: Friday 12 January 2018 22:16 What is the value of TimerTest?
So what does it show when you click "Show current states"?
Jos
Hjalmarsson
On
jvdz
Post by jvdz »
I realize again why I didn't like blockly from the start as I don't like programming when the code has it own mind. :)
Use DzEvent or LUA... much easier.
Either way, something in my mind told me that blockly needed a time test in there for it to work and this indeed does work:
It didn't without the OR Time test. I am not a blockly buff so maybe somebody can comment in case it should have worked.
Jos
Hjalmarsson
Thank you for your help. Appreciated
// J
