Exists a way to know if the day is holiday or business day?
I need to know if [today] is an holiday or business day because I want to change the behavior of my scripts in base of it.
I know that in DzVents doesn't exists a way (something like "domoticz.isHoliday", it's correct?), but exists an API (like google maps, WU, etc) or any other way?
Obviously, i'd like to have the holiday in my local calendar (italian).
Thanks.
Thanks.
- emme
- Domoticz version: latest
Re: Exists a way to know if the day is holiday or business day?
as a workaround... what about a table like:
(maybe into an external file so all scripts can use it)
then, in your code
of course you will need to update it every year
it would be nice to include this into domoticz
isHoliday = {}
isHoliday['0101'] = 'New Year'
isHoliday['0104'] = 'Easter'
isHoliday['0105'] = 'Labour Day'
then, in your code
if isHoliday[<today's date formatted as DDMM>] ~= nil then
domoticz.log('Hey... no rush...today is '..isHoliday[<today's date formatted as DDMM>]..'!!!!!')
domoticz.log('Come on Men... wake up!!')
end if
"We always done this way"
yes, nice, but inconvenient to do this job every year..
- waaren
I use a bash script (triggered daily by cron) to do this.
relevant parts of the script:
you can change the json to domoticz to do other stuff eg change state of a virtual switch or change to a different timerplan as well
today=$(date --date="0 days ago " +"%-d-%-m-%Y")
json_return=$(curl -s http://www.kayaposoft.com/enrico/json/v1.0/?action=isPublicHoliday\&date=$today\&country=ita )
if $(echo $json_return | jq '.[]') ;then
curl -i -s -H "Accept: application/json" "http://domoticz-IP:domoticz-port/json.htm?type=command¶m=updateuservariable&vname=MyVarName&vtype=0&vvalue=1"
fi
I like this, I will try it! Thanks.
- Siewert308SW
- Domoticz version: Stable
There are so many ways to get this job done.
I know some countries have variable days which are called as (bank) holiday.
Haven't took a look at that for my own country but some days are a easy calculation as they for example occur on a fixed day after some other day like Easter.
For fixed days i use a function which can be called like below:
edit: @waaren didn't know that url, thx
function IsHoliday()
local monthNow = tonumber(os.date("%m"));
local dayNow = tonumber(os.date("%d"));
local holiday
if (dayNow == 27 and monthNow == 04) -- Koningsdag
or (dayNow == 04 and monthNow == 05) -- Bevrijdingdag
or (dayNow == 05 and monthNow == 05) -- Doden Herdenking
or (dayNow == 11 and monthNow == 11) -- Sint Maarten
or (dayNow == 05 and monthNow == 12) -- Sinterklaas
or (dayNow == 25 and monthNow == 12) -- 1e Kerstdag
or (dayNow == 26 and monthNow == 12) -- 2e kerstdag
or (dayNow == 31 and monthNow == 12) -- Oud jaarsdag
or (dayNow == 01 and monthNow == 01) -- Nieuw jaarsdag
then
holiday = 1
holiday = 0
return holiday
-- Call function holiday
holiday = IsHoliday()
if devicedchanged['someonehome'] == 'On'
and otherdevices['light'] == 'Off'
and otherdevices['holidaylight'] == 'Off'
and holiday == 0
then
commandArray['light']='On'
and holiday == 1
then
commandArray['holidaylight']='On'
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
- rootfs @ USB HDD
- emme
- Domoticz version: 3.9639
I have been looking into that a bit. Haven't found a LUA way yet but came up with this in Python
Based on https://pypi.python.org/pypi/holidays
This looks up if the current date is a Public Holiday and prints the result to screen.
Following Python libraries need to be installed : datetime, calendar and holidays
After the weekend I will finish the rest:
The print command have to be replaced with a curl command to update a switch
And in the else-part I will include a nested IF to check if the current day of week is not a Saturday or Sunday because that might of course influence if we want to activate a virtual switch.
from datetime import date
#library datetime has to be installed
import holidays
#set your country
festivos = holidays.ES()
#get today's date (YYYY-MM-DD)
hoy = str(date.today())
dia = datetime.weekday(hoy)
#look up today
fiesta = str((festivos.get(hoy)))
msg = "Hoy es " + dia + hoy
print(msg)
if fiesta == "None":
print("No es festivo")
else:
print(fiesta)
Update.
This is what I came up with.
You will also need the urllib2 so required are
* from Python: datetime, holidays, calendar and urllib2
* a virtual switch that will reflect if current day is a holiday or not
* optional, a virtual text device that will show what Holiday it is (if current day is a holiday)
* have crontab run the script once a day
I had a look at holiday.py to see if I could convert it to LUA (dzvents) but 2227 lines does not make me very eager
import holidays
import calendar
import urllib2
#set your country here. In this example ES for Spain
Hswitch=1127
Hname=1128
domoticzserver="192.168.1.6:8080"
hoy = date.today() #Comment this line when testing with following line Uncommented
#hoy = date(2018, 3, 30) #uncomment this line and put date that is a holiday (format = YYYY, M, D) to check if switch is updated
dia = calendar.day_name[hoy.weekday()]
#look up today in holidays
fiesta = fiesta.replace(" ", "%20") #if holday name contains a space replace it with %20
fiesta = ""
print("No es festivo") #only visible in command line, for testing
urllib2.urlopen("http://" + str(domoticzserver) + "/json.htm?type=command¶m=switchlight&idx=" + str(Hswitch) + "&switchcmd=Off")
urllib2.urlopen("http://" + str(domoticzserver) + "/json.htm?type=command¶m=udevice&idx=" + str(Hname) + "&nvalue=0&svalue=" + str(fiesta))
else:
urllib2.urlopen("http://" + str(domoticzserver) + "/json.htm?type=command¶m=switchlight&idx=" + str(Hswitch) + "&switchcmd=On")
print(fiesta) #only visible in command line, for testing
This is fantastic! I have to try it as soon as possible! Thanks.
Very nice plugin! I adapted for python 3.5 and for update a variable (string) instead a switch. Only holidays module is necessary, the other are already built with python35:
pip3.5 install holidays
#!/usr/local/bin/python3.5
import holidays
import calendar
import urllib.request, urllib.error, urllib.parse
festivos = holidays.IT()
fiesta = ""
urllib.request.urlopen("http://192.168.99.51:8080/json.htm?type=command¶m=updateuservariable&vname=Giorno&vtype=2&vvalue=Feriale")
else:
urllib.request.urlopen("http://192.168.99.51:8080/json.htm?type=command¶m=updateuservariable&vname=Giorno&vtype=2&vvalue=Festivo")
I’m sure I read aboit (some time ago) a way to do this with ifttt - linked to google calendar.
Basically, if the day contains holiday, then switch a switch in domoticz. So it would also work if you had your own holidays / annual leave etc..
not looked into it further yet but it’s on my list
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
Changed to default english and added a check. Now also if it's a normal sunday it appear as holiday.
import holidays
import calendar
holiday = holidays.IT()
today = date.today()
day = calendar.day_name[today.weekday()]
bankholiday = str((holiday.get(today)))
bankholiday = bankholiday.replace(" ", "%20") #if holday name contains a space replace it with %20
if bankholiday == "None":
bankholiday = ""
if day == "Sunday":
urllib.request.urlopen("http://192.168.99.51:8080/json.htm?type=command¶m=updateuservariable&vname=Giorno_Festivo&vtype=2&vvalue=Si")
else:
urllib.request.urlopen("http://192.168.99.51:8080/json.htm?type=command¶m=updateuservariable&vname=Giorno_Festivo&vtype=2&vvalue=No")
else:
- EdwinK
- Domoticz version: BETA
Can it update a text-box with the name of the holiday? Something like 'Today is Easter'.
- waaren
Please find an answer on your question In this topic
- EdwinK
Found it, did it, and works
Calendarific allows you to get bank and public holidays information for over 230 countries via a simple json api. I think for what you want to do, you should be able to use it.
https://calendarific.com
https://calendarific.com/api-documentation
