Exists a way to know if the day is holiday or business day?
bigpea
Post by bigpea »
I need to know if [today] is an holiday or business day because I want to change the behavior of my scripts in base of it.
I know that in DzVents doesn't exists a way (something like "domoticz.isHoliday", it's correct?), but exists an API (like google maps, WU, etc) or any other way?
Obviously, i'd like to have the holiday in my local calendar (italian).
Thanks.
emme
Domoticz version: latest
Re: Exists a way to know if the day is holiday or business day?
Post by emme »
as a workaround... what about a table like:
isHoliday = {}
isHoliday['0101'] = 'New Year'
isHoliday['0104'] = 'Easter'
isHoliday['0105'] = 'Labour Day'
(maybe into an external file so all scripts can use it)
then, in your code
if isHoliday[<today's date formatted as DDMM>] ~= nil  then
    domoticz.log('Hey... no rush...today is '..isHoliday[<today's date formatted as DDMM>]..'!!!!!')
    domoticz.log('Come on Men... wake up!!')
end if
of course you will need to update it every year :P
it would be nice to include this into domoticz :P
"We always done this way"
bigpea
Post by bigpea »
yes, nice, but inconvenient to do this job every year..
I use a bash script (triggered daily by cron) to do this.
relevant parts of the script:
today=$(date --date="0 days ago " +"%-d-%-m-%Y")
json_return=$(curl -s http://www.kayaposoft.com/enrico/json/v1.0/?action=isPublicHoliday\&date=$today\&country=ita )
if $(echo $json_return | jq '.[]') ;then
	curl -i -s -H "Accept: application/json" "http://domoticz-IP:domoticz-port/json.htm?type=command&param=updateuservariable&vname=MyVarName&vtype=0&vvalue=1"
fi
you can change the json to domoticz to do other stuff eg change state of a virtual switch or change to a different timerplan as well
bigpea
Post by bigpea »
I like this, I will try it! Thanks.
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
There are so many ways to get this job done.
I know some countries have variable days which are called as (bank) holiday.
Haven't took a look at that for my own country but some days are a easy calculation as they for example occur on a fixed day after some other day like Easter.
For fixed days i use a function which can be called like below:
edit: @waaren didn't know that url, thx
	function IsHoliday()
		local monthNow 	= tonumber(os.date("%m"));
		local dayNow 	= tonumber(os.date("%d"));
			local holiday
				if (dayNow == 27 and monthNow == 04) -- Koningsdag
					or (dayNow == 04 and monthNow == 05) -- Bevrijdingdag
					or (dayNow == 05 and monthNow == 05) -- Doden Herdenking
					or (dayNow == 11 and monthNow == 11) -- Sint Maarten
					or (dayNow == 05 and monthNow == 12) -- Sinterklaas
					or (dayNow == 25 and monthNow == 12) -- 1e Kerstdag
					or (dayNow == 26 and monthNow == 12) -- 2e kerstdag
					or (dayNow == 31 and monthNow == 12) -- Oud jaarsdag
					or (dayNow == 01 and monthNow == 01) -- Nieuw jaarsdag
				then
					holiday = 1
					holiday = 0
		return holiday
-- Call function holiday
	holiday = IsHoliday()
	if devicedchanged['someonehome'] == 'On'
		and otherdevices['light']  == 'Off'
		and otherdevices['holidaylight']  == 'Off'
		and holiday == 0
	then
		commandArray['light']='On'
		and holiday == 1
	then
		commandArray['holidaylight']='On'
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
emme
Post by emme »
also found this:
https://holidayapi.com/
which require a registration :P
elmortero
Domoticz version: 3.9639
Post by elmortero »
I have been looking into that a bit. Haven't found a LUA way yet but came up with this in Python
Based on https://pypi.python.org/pypi/holidays
This looks up if the current date is a Public Holiday and prints the result to screen.
Following Python libraries need to be installed : datetime, calendar and holidays
from datetime import date
#library datetime has to be installed
import holidays
#set your country
festivos = holidays.ES()
#get today's date (YYYY-MM-DD)
hoy = str(date.today())
dia = datetime.weekday(hoy)
#look up today
fiesta = str((festivos.get(hoy)))
msg = "Hoy es " + dia + hoy
print(msg)
if fiesta == "None":
        print("No es festivo")
else:
        print(fiesta)
After the weekend I will finish the rest:
The print command have to be replaced with a curl command to update a switch
And in the else-part I will include a nested IF to check if the current day of week is not a Saturday or Sunday because that might of course influence if we want to activate a virtual switch.
elmortero
Post by elmortero »
Update.
This is what I came up with.
You will also need the urllib2 so required are
* from Python: datetime, holidays, calendar and urllib2
* a virtual switch that will reflect if current day is a holiday or not
* optional, a virtual text device that will show what Holiday it is (if current day is a holiday)
* have crontab run the script once a day
I had a look at holiday.py to see if I could convert it to LUA (dzvents) but 2227 lines does not make me very eager :D
import holidays
import calendar
import urllib2
#set your country here. In this example ES for Spain
Hswitch=1127
Hname=1128
domoticzserver="192.168.1.6:8080"
hoy = date.today() #Comment this line when testing with following line Uncommented
#hoy = date(2018, 3, 30) #uncomment this line and put date that is a holiday (format = YYYY, M, D) to check if switch is updated
dia = calendar.day_name[hoy.weekday()]
#look up today in holidays
fiesta = fiesta.replace(" ", "%20") #if holday name contains a space replace it with %20
	fiesta = ""
	print("No es festivo") #only visible in command line, for testing
	urllib2.urlopen("http://" + str(domoticzserver) + "/json.htm?type=command&param=switchlight&idx=" + str(Hswitch) + "&switchcmd=Off")
	urllib2.urlopen("http://" + str(domoticzserver) + "/json.htm?type=command&param=udevice&idx=" + str(Hname) + "&nvalue=0&svalue=" + str(fiesta))
else:
	urllib2.urlopen("http://" + str(domoticzserver) + "/json.htm?type=command&param=switchlight&idx=" + str(Hswitch) + "&switchcmd=On")
	print(fiesta) #only visible in command line, for testing
bigpea
Post by bigpea »
This is fantastic! I have to try it as soon as possible! Thanks.
TheCondor
Post by TheCondor »
Very nice plugin! I adapted for python 3.5 and for update a variable (string) instead a switch. Only holidays module is necessary, the other are already built with python35:
pip3.5 install holidays
#!/usr/local/bin/python3.5
import holidays
import calendar
import urllib.request, urllib.error, urllib.parse
festivos = holidays.IT()
 fiesta = ""
 urllib.request.urlopen("http://192.168.99.51:8080/json.htm?type=command&param=updateuservariable&vname=Giorno&vtype=2&vvalue=Feriale")
else:
 urllib.request.urlopen("http://192.168.99.51:8080/json.htm?type=command&param=updateuservariable&vname=Giorno&vtype=2&vvalue=Festivo")
sion
Post by sion »
I’m sure I read aboit (some time ago) a way to do this with ifttt - linked to google calendar.
Basically, if the day contains holiday, then switch a switch in domoticz. So it would also work if you had your own holidays / annual leave etc..
not looked into it further yet but it’s on my list ;)
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
TheCondor
Post by TheCondor »
Changed to default english and added a check. Now also if it's a normal sunday it appear as holiday.
import holidays
import calendar
holiday = holidays.IT()
today = date.today()
day = calendar.day_name[today.weekday()]
bankholiday = str((holiday.get(today)))
bankholiday = bankholiday.replace(" ", "%20") #if holday name contains a space replace it with %20
if bankholiday == "None":
 bankholiday = ""
 if day == "Sunday":
   urllib.request.urlopen("http://192.168.99.51:8080/json.htm?type=command&param=updateuservariable&vname=Giorno_Festivo&vtype=2&vvalue=Si")
 else:
  urllib.request.urlopen("http://192.168.99.51:8080/json.htm?type=command&param=updateuservariable&vname=Giorno_Festivo&vtype=2&vvalue=No")
else:
EdwinK
Post by EdwinK »
Can it update a text-box with the name of the holiday? Something like 'Today is Easter'.
EdwinK wrote: Thursday 19 July 2018 17:02 Can it update a text-box with the name of the holiday? Something like 'Today is Easter'.
Please find an answer on your question In this topic
EdwinK
Post by EdwinK »
Found it, did it, and works ;)
zak45
Domoticz version: V2024.4
Post by zak45 »
ryanc9c
Post by ryanc9c »
Calendarific allows you to get bank and public holidays information for over 230 countries via a simple json api. I think for what you want to do, you should be able to use it.
https://calendarific.com
https://calendarific.com/api-documentation
