Xiaomi Motion Sensors and Blockly... activating the lights does not work
martijnm
Domoticz version: 3.530
Post by martijnm »
Hi guys,
I'm trying to set up some Xiaomi "Human Body" Sensors. They register movement just fine in Domoticz but with a 2 second delay.
I've created a blockly script to start up some of my lights when movement is detected. The grouped lights work fine when I switch them on myself in Domoticz.
When using the motion sensor with Blockly, nothing happens:
I also tried:
Both scripts do not work as expected.. Should I use a different selector than "on" or "motion"?
I'm hoping someone can maybe give some suggestions on how to make this work..
jjnj
Re: Xiaomi Motion Sensors and Blockly... activating the lights does not work
Post by jjnj »
Set group should be on instead of active I believe
martijnm
Post by martijnm »
Sorry never mind. I feel stupid.... Fixed this by setting group to On instead of Active.
Schorschi
Post by Schorschi »
i also try to implement an motion sensor. I use an aquara motion sensor.
But this sensor is not listed inside the device list.
Maybe only the stock xiaomi motion sensor is suported by domoticz??
Any one with more informations?
thx.
Andree
Post by Andree »
Schorschi wrote:Hello,
thx.
Yes but do you have a Xiaomi Gateway.
All the Xiaomi sensor need the gateway.
Schorschi
Post by Schorschi »
yes i have. Now i tested current beta version which support the aquara motion sensor.
compile
Post by compile »
I have version v3.8796 but I don't get any switches. I added the motion sensor but it only appears as a utlity.
In Blockly I can't add it from switches.
Any idea?
