Hi guys,
I'm trying to set up some Xiaomi "Human Body" Sensors. They register movement just fine in Domoticz but with a 2 second delay.
I've created a blockly script to start up some of my lights when movement is detected. The grouped lights work fine when I switch them on myself in Domoticz.
When using the motion sensor with Blockly, nothing happens:
I also tried:
Both scripts do not work as expected.. Should I use a different selector than "on" or "motion"?
I'm hoping someone can maybe give some suggestions on how to make this work..
Xiaomi Motion Sensors and Blockly... activating the lights does not work
Re: Xiaomi Motion Sensors and Blockly... activating the lights does not work
Set group should be on instead of active I believe
- Domoticz version: 3.530
Sorry never mind. I feel stupid.... Fixed this by setting group to On instead of Active.
i also try to implement an motion sensor. I use an aquara motion sensor.
But this sensor is not listed inside the device list.
Maybe only the stock xiaomi motion sensor is suported by domoticz??
Any one with more informations?
thx.
thx.
Yes but do you have a Xiaomi Gateway.Schorschi wrote:Hello,
thx.
All the Xiaomi sensor need the gateway.
yes i have. Now i tested current beta version which support the aquara motion sensor.
I have version v3.8796 but I don't get any switches. I added the motion sensor but it only appears as a utlity.
In Blockly I can't add it from switches.
Any idea?
Any idea?
