Domoticz Beta from source OZW fails to update Topic is solved
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Don't want to ask this on Github as it aint related to any commit there.
But still can't find the culprit or cause.
Question:
Since a two weeks i run Domoticz from source to debug something and compiled it as per wiki.
So far so good no issues on that matter.
But what does bother me is that if i'm correct i can update OZM when i do a git pull on OZW and after that recompile Domoticz, right?
Well if there are new commits in the OZW and i pull them from (https://github.com/OpenZWave/open-zwave open-zwave-read-only)
They are merged but when i try to recompile Domoticz it doesn't mention any OZW updates.
Nor is the version number updated in Domoticz or such.
I do need the update as there are new updates for my Coolcam doorsensors and those i have are acting up at the moment, but still it has to work as i think it should, right.
At the moment Domoticz say i run OpenZWave USB Version: 1.4-2871-g68e8a02-dirty
But when i look when i (re)compile open-zwave-read-only i see "Building OpenZWave Version 1.4-2881-g58a271a-dirty"
Then when i try to recompile Domoticz nothing is changed.
Is there something i overlook?
System specs:
Schermafdruk 2018-01-08 10.17.09.png (64.33 KiB) Viewed 523 times
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
SweetPants
Re: Domoticz Beta from source OZW fails to update
Post by SweetPants »
Siewert308SW wrote: Monday 08 January 2018 10:25
Did you do a make also in the open-zwave directory?
Siewert308SW
Yep... i did forgot to mention, sorry
Setup:
- DS923+ Docker
