Confused about which device belong to which zwave-node Topic is solved
jvdz
Domoticz version: 4.107
Re: Confused about which device belong to which zwave-node
Post by jvdz »
datagutten wrote: Sunday 31 December 2017 14:14 You should send a pull request on this, it would be nice to have as a default feature.
Pull request is made: https://github.com/domoticz/domoticz/pull/2033
datagutten wrote: Sunday 31 December 2017 14:14 Edit:
When using whitespace the search does not work, so the underscore must be there.
I see you changed your post, but I have implemented it in the same was as displayed in the Zwave hardware devices list.
It now displays like this:
What I do to check things is just type the name of the ZWave hardware "ZWAVE" and then sort on the Hardware column so the display has the same sequence as the ZWave hardware devices list.
Jos
mischa
Domoticz version: 3.8872
Post by mischa »
First of all, thank you for this addition. Makes life a lot easier, switching from PI to Synology and have to include 30 nodes.
As some of the devices only appear after a while or for example when clicked on like the triple click of Fibaro devices.
this could take a while.
Not sure if possible but would it be a nice addition if the table could be grouped
Something like this.
Hardware
NodeID
Devices
Perhaps there is other hardware that could also benefit from this approach, like evohome, rfxcomm, ect ect
Mischa
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
SchattenMann
Post by SchattenMann »
thank you @jvdz - this is the single best add to Domoticz since I can remember :D
As a suggestion, add a "link" on the device ID to filter the devices' table. This is how I'm doing it now (added to my themes custom.js)
$("#devices tbody tr").each(function() {
			var html = $(this).children()[2].innerHTML;
			var className = $(this)[0].className;
			var res = html.match(/(\s[0-9]{3}\s[\(][0-9]x[a-zA-Z0-9]{2}[\)])$/g);
			var css = "";
			if(className == "odd") {
				css = 'style="color: #FFF"';
			if(res){
				$(this).children()[2].innerHTML = $(this).children()[2].innerHTML.replace(res,'<a href="#/Devices" '+css+' onClick="filter(\''+res+'\')">'+res+'</a>');
		function filter (idx) {
			$("#devices_filter input").val(idx);
			$("#devices_filter input").trigger( "keyup" );
mischa
Post by mischa »
@SchattenMann
where to put it, if you use the default theme?
SchattenMann
just create a custom.js file on /domoticz/www/styles/your_theme and paste
jQuery(window).load(function() {
	setTimeout(function () {
			var css = "";
			if(res){
	},2500);
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
jvdz wrote: Sunday 07 January 2018 11:11
It now displays like this: Knipsel.PNG
Jos
Hello Jos,
I've adjusted the file /app/DevicesController.js but i don't see any changes in list.
Do i need to chage the database also as in your previous post ? or should changing the file be enough ?
jvdz
Post by jvdz »
This patch is part for the current release & beta, but it should appear right away after you clear the browser cache and refresh the page.
No other changes required. ;)
Jos
madpatrick
I'm currently still on v.3.8153, so that must the case ;-)
I did not make any changes to the database, but only adjusted the file.
After clearing the cache and refresh nothing is changed.
jvdz
Post by jvdz »
Check with F12 in Chrome whether the source looks correct as it is really a pretty simple change to the page generation for the Zwave devices.
Jos
madpatrick
jvdz wrote: Wednesday 01 August 2018 17:13 Check with F12 in Chrome whether the source looks correct as it is really a pretty simple change to the page generation for the Zwave devices.
Jos
That was the problem :roll:
Thanks for the help
vinisz
Post by vinisz »
Hmm, I had it like this in the previous domoticz version. Now, updated and running Version: 4.10730 , I do no longer see the node-id , next to the controller (I want it to show as mentioned in this thread)
Am I doing something wrong or what do I need to change in the version I am running now... ?
jeecee
Post by jeecee »
I have the same problem...
Plantje
Post by Plantje »
jvdz wrote: Friday 29 December 2017 22:16 Guess I have too much time on my hands. :)
...so was playing with file /www/app/DevicesController.js, which generates the Domoticz devices webpage.
Added a few lines of code to extract the ZWave DeviceID from the DeviceID and concatenated that to the Hardware name to allow for sorting in the Hardware name to group all devices by ZWave device. This is actually a pretty simple modification to accomplish what is wanted here.
This is the diff for the file in case you are interested to play and comment on this:
+++ b/www/app/DevicesController.js
@@ -384,6 +384,13 @@ define(['app'], function (app) {
                 itemSubIcons += '&nbsp;<img src="images/empty16.png">';
              var ID = item.ID;
+             if (item.HardwareTypeVal != undefined && item.HardwareTypeVal == 21) {
+                var ZWID = item.ID.substr(-4, 2);
+                if (ZWID == '00') {
+                  ZWID = item.ID.substr(-2, 2);
+                item.HardwareName = item.HardwareName + ' ' + ZWID;
              if (item.Type == "Lighting 1") {
                ID = String.fromCharCode(item.ID);
Jos
Hmmm, I tried just adding this piece of code. That didn't work. Now I replaced a part that looks like this with this part and if still doesn't seem to do anything.
Can you tell me exactly where this goes?
jvdz
Post by jvdz »
Did you clear your browser cache to ensure it did load the updated DevicesController.js?
You can check it also in developer mode (F12), to see whether you have the modified code loaded.
EDIT: I don't see DevicesController.js in the current version anymore so which file did you change?
Jos
Plantje
Post by Plantje »
jvdz wrote: Wednesday 29 May 2019 10:04 Did you clear your browser cache to ensure it did load the updated DevicesController.js?
Did a full reboot of my Domoticz server
jvdz wrote: Wednesday 29 May 2019 10:04 You can check it also in developer mode (F12), to see whether you have the modified code loaded.
Will do. Didn't really recognize the code in the developer mode.
jvdz wrote: Wednesday 29 May 2019 10:04 EDIT: I don't see DevicesController.js in the current version anymore so which file did you change?
Jos
I did change that file. Perhaps it is still in there from previous installs and my update doesn't change a thing
jvdz
Post by jvdz »
Plantje wrote: Wednesday 29 May 2019 10:43
Clearing the cache is a PC side thing, nothing to do with the Domoticz server itself! ;)
It looks like the last modification I made should still be in there, which is the highlighting of the Hardware id part in the deviceId.
Jos
jvdz
Post by jvdz »
I did some more checking on what we did at the time and remembered we found a "compromise" to highlight the ZWAVEID part in the DeviceID.
see: https://github.com/domoticz/domoticz/pull/2664 and made a comment about that here https://github.com/domoticz/domoticz/co ... t-33717380 .
So isn't that still the case in your version?
Jos
Plantje
Post by Plantje »
Altering the .js file like you suggested didn't work or I am doing it wrong... the latter is most likely the case.
I don't see any highlighting in the ID when searching.
puls8
Post by puls8 »
vinisz wrote: Sunday 12 May 2019 9:55 Hmm, I had it like this in the previous domoticz version. Now, updated and running Version: 4.10730 , I do no longer see the node-id , next to the controller (I want it to show as mentioned in this thread)
I am running version 4.10717; is this already added? (I did not modify the domoticz code)
Plantje
Post by Plantje »
It will not be added anymore. If you want it, you need to add it yourself.
Currently I'm having a hard time altering the files as TeamViewer has for some reason flagged my usage as commercial
