Same here unfortunately.gijsje wrote: Friday 05 January 2018 17:38 I am not able anymore to sync my devices.
Any issue with that at the moment??
Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Failure404
- gijsje
- Domoticz version: Stable
Because i did change some lights in domoticz and sync is not working i did remove Controlicz from the google home setup to set it up again and now it does not chow up in the list anymore
Thats very strange as this was no issue in the past
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
pabloalcantara
- Target OS: -
Does exist any command for timer ex: ok google, turn on wattering for 10 minutes.
Madgeni
Failure404 wrote: Friday 05 January 2018 18:08Same here unfortunately.gijsje wrote: Friday 05 January 2018 17:38 I am not able anymore to sync my devices.
Hey - Controlicz is up and working. Can you try again?
- gijsje
i can not find controlicz anymore in home app
alanlsmith
- Domoticz version: Latest β
@gijsjealanlsmith wrote: Sunday 31 December 2017 12:59 Re: Controlicz not appearing in Home app list of new services.
So, I went to the Google simulator console and changed the language from US English to UK English, I don't think this in itself is of any significance but what it did do, was to effectively re-initialise the hometest. So I could then go back to the Home app and test Controlicz appeared in the new services list.
Now all is fine again. Sorry again for raising this as a problem but you never know it could be useful for someone.
Maybe try the above, or similar, as it worked for me. I think it's a 'Google thing'.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
- gijsje
US English or UK English does not make a difference on my phone
Dont know what the simulator is
alanlsmith
No, not to change the language on the phone but in the google console, using the link to 'https://console.actions.google.com' that madgeni sent you when you joined Controlicz.gijsje wrote: Friday 05 January 2018 21:26 US English or UK English does not make a difference on my phone
I'm not saying that this is the correct way or even a sensible way to get Controlicz bacck in the list but it worked for me.
- gijsje
It works now i had to start the simulator again i think i have not been on there for some time
pssimon
Hello Madgeni,
Could you add me also at your list to test your solution : i am registered as pierresamuel[dot]simon[at]gm....com on controlicz.com.
Thanks a lot
PS SIMON
Thanks a lot
PS SIMON
- gijsje
Is there an issue now with controlling the color of the lights?
With any color they change to some kind of blue
Madgeni
hey - how about now?gijsje wrote: Saturday 06 January 2018 0:03 Is there an issue now with controlling the color of the lights?
- gijsje
YES it back again
Madgeni
ok, and can someone try 'white' now?
- gijsje
If i ask for white it gives me "cold" white
If i ask for "warm white" is gives me between cold and warm white
If i change it to warm white on the remote on the milight remote it gives me warm white
Ask you can see there a different leds for warm and cold light on the lamp
alanlsmith
- s
@madgeni
Excellent, works perfectly with my RGB + white ( single colour temperature ) lamps.
No more need for bodges! Much better. Well done, I knew that you would sort it.
Although maybe the is still a bit of fiddling required for the variable colour temperature lamps.
Madgeni
great! "Dim <device> by x%" should now work also.
will look at warmth now
alanlsmith
Seems a bit variable, sometimes I get the response 'It looks like these lights haven't been set up yet......' but also:
Me: dim the lights by 20% , Google: Sure, dimming the lights by 20%, lights: dim by 20% (I was pleased, then...
Me: dim the lights by 20% , Google: Sure, dimming the lights by 20%, lights: turn off.
Me: dim the lights by 20%, Google: Sure, setting the lights to 20%, lights: set to 20%.
Me: brighten the lights by 20%, Google: Sure, brightening the lights by 20%, lights: not changed.
Of course a lot of this could be me, as you start to stutter a bit after repeatedly saying variations of the same phrase, or it could be that Google just got ticked off with me for endlessly adjusting the same lamp.
I think 'set to nn%' doesn't work now but ' dim to' and 'brighten to' does.
So not very conclusive at the moment I'm afraid.
Routernl
Hello Madgeni I have registered and tested connection OK, can you add me tot the Beta programme ?
Drij*****t@gm***.com thnx !
Madgeni
ok, so you can set a light's percentage. You can dim a light by a percentage. What you can't currently do is either set/dim the percentage on a light that has already had one of those things done (due to Domoticz setting the state to 'Set Level' - grrr). Will look at it.
I'm worrying, as i've finally, FINALLY, got Google to test it - they'll be doing it on Monday.
