Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Failure404
Post by Failure404 »
gijsje wrote: Friday 05 January 2018 17:38 I am not able anymore to sync my devices.
Any issue with that at the moment??
Same here unfortunately.
gijsje
Domoticz version: Stable
Post by gijsje »
Because i did change some lights in domoticz and sync is not working i did remove Controlicz from the google home setup to set it up again and now it does not chow up in the list anymore :( :(
Thats very strange as this was no issue in the past
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
pabloalcantara
Post by pabloalcantara »
Does exist any command for timer ex: ok google, turn on wattering for 10 minutes.
Madgeni
Post by Madgeni »
Failure404 wrote: Friday 05 January 2018 18:08
Hey - Controlicz is up and working. Can you try again?
gijsje
Post by gijsje »
i can not find controlicz anymore in home app
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
alanlsmith wrote: Sunday 31 December 2017 12:59 Re: Controlicz not appearing in Home app list of new services.
So, I went to the Google simulator console and changed the language from US English to UK English, I don't think this in itself is of any significance but what it did do, was to effectively re-initialise the hometest. So I could then go back to the Home app and test Controlicz appeared in the new services list.
Now all is fine again. Sorry again for raising this as a problem but you never know it could be useful for someone.
@gijsje
Maybe try the above, or similar, as it worked for me. I think it's a 'Google thing'.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
gijsje
Post by gijsje »
US English or UK English does not make a difference on my phone
Dont know what the simulator is
alanlsmith
gijsje wrote: Friday 05 January 2018 21:26 US English or UK English does not make a difference on my phone
No, not to change the language on the phone but in the google console, using the link to 'https://console.actions.google.com' that madgeni sent you when you joined Controlicz.
I'm not saying that this is the correct way or even a sensible way to get Controlicz bacck in the list but it worked for me.
gijsje
Post by gijsje »
It works now i had to start the simulator again i think i have not been on there for some time
pssimon
Post by pssimon »
Hello Madgeni,
Could you add me also at your list to test your solution : i am registered as pierresamuel[dot]simon[at]gm....com on controlicz.com.
Thanks a lot
PS SIMON
gijsje
Post by gijsje »
Is there an issue now with controlling the color of the lights?
With any color they change to some kind of blue
Madgeni
Post by Madgeni »
gijsje wrote: Saturday 06 January 2018 0:03 Is there an issue now with controlling the color of the lights?
hey - how about now?
gijsje
Post by gijsje »
YES it back again :)
Madgeni
Post by Madgeni »
ok, and can someone try 'white' now?
gijsje
Post by gijsje »
If i ask for white it gives me "cold" white
If i ask for "warm white" is gives me between cold and warm white
If i change it to warm white on the remote on the milight remote it gives me warm white
Ask you can see there a different leds for warm and cold light on the lamp
alanlsmith
  • s
Madgeni wrote: Saturday 06 January 2018 10:07 ok, and can someone try 'white' now?
@madgeni
Excellent, works perfectly with my RGB + white ( single colour temperature ) lamps.
No more need for bodges! Much better. Well done, I knew that you would sort it.
Although maybe the is still a bit of fiddling required for the variable colour temperature lamps.
Madgeni
Post by Madgeni »
great! "Dim <device> by x%" should now work also.
will look at warmth now
alanlsmith
Madgeni wrote: Saturday 06 January 2018 11:21 great! "Dim <device> by x%" should now work also.
Seems a bit variable, sometimes I get the response 'It looks like these lights haven't been set up yet......' but also:
Me: dim the lights by 20% , Google: Sure, dimming the lights by 20%, lights: dim by 20% (I was pleased, then...
Me: dim the lights by 20% , Google: Sure, dimming the lights by 20%, lights: turn off.
Me: dim the lights by 20%, Google: Sure, setting the lights to 20%, lights: set to 20%.
Me: brighten the lights by 20%, Google: Sure, brightening the lights by 20%, lights: not changed.
Of course a lot of this could be me, as you start to stutter a bit after repeatedly saying variations of the same phrase, or it could be that Google just got ticked off with me for endlessly adjusting the same lamp.
I think 'set to nn%' doesn't work now but ' dim to' and 'brighten to' does.
So not very conclusive at the moment I'm afraid.
Routernl
Post by Routernl »
Hello Madgeni I have registered and tested connection OK, can you add me tot the Beta programme ?
Drij*****t@gm***.com thnx !
Madgeni
Post by Madgeni »
ok, so you can set a light's percentage. You can dim a light by a percentage. What you can't currently do is either set/dim the percentage on a light that has already had one of those things done (due to Domoticz setting the state to 'Set Level' - grrr). Will look at it.
I'm worrying, as i've finally, FINALLY, got Google to test it - they'll be doing it on Monday.
