Hi all, I have received a wifi switch from broadlink and wanted to control it as I am doing with the Orvibo S20 from domoticz... the problem is I can not find anything outside Android to control them... HAve found the SDK for IOS and Android and some githubs projects... but nothing I can use from the raspberry pi... Any ideas?? any intention to integrate broadlink products?? they are quality and cheap and seems to me there will be plenty of people using them.
Thanks a lot
Broadlink SP mini switch
Jonkerfrisjes
- Domoticz version: V3.5877
Re: Broadlink SP mini switch
I have the same question for a TC2 switch from Broadlink. Is there a way to find out the code for these device.? Without the RM controller.
Broadlink has many great items.
Andre
Andre
kalinkamaen
- Domoticz version: 2022.2
Hello sir.
I have broadlink running with Eventghost with this pluguin:
http://www.eventghost.org/forum/viewtop ... 6f3654b786
The downside is that you need to have a android device. I use my old phone for this. And instal this ap :
http://rm-bridge.fun2code.de/
You can use this code to switch on or off a switch on domoticz!
Forum thread found here:
HOST = "192.168.1.21"
PORT = 80
DEVICE_NUMBER = 10
LIGHTS_ON = True
import urllib2
from urllib2 import HTTPError, URLError
ERROR_REASON = (
"We failed to reach a server.\n"
"Reason: %s"
ERROR_CODE = (
"The server couldn't fulfill the request.\n"
"Error code: %d"
if LIGHTS_ON:
LIGHTS = 'On'
else:
LIGHTS = 'Off'
URL = "http://%s:%d/json.htm?type=command¶m=switchlight&idx=%s&switchcmd=%s" % (HOST, PORT, str(DEVICE_NUMBER), LIGHTS)
try:
urllib2.urlopen(URL)
except HTTPError as httpError:
eg.PrintError(ERROR_REASON % httpError.reason)
eg.PrintError(ERROR_CODE % httpError.code)
except URLError as urlError:
eg.PrintError(ERROR_REASON % urlError.reason)http://www.eventghost.org/forum/viewtop ... 6f3654b786
Windows 10, Domoticz 14784
drbrains
- Domoticz version: v3.6799
I realize this is an old post, but look here to get started:
https://github.com/mjg59/python-broadlink
It should work for the SP2/3 and MP1. Maybe it's compatible.
xxLeoxx93
Hello,drbrains wrote:I realize this is an old post, but look here to get started:
is there any guide how to use the .py script in domoticz?
Thank you!
ijobain
Read thisxxLeoxx93 wrote:Hello,drbrains wrote:I realize this is an old post, but look here to get started:
Thank you!
https://www.domoticz.com/forum/viewtopi ... 40#p108350
levels in between 195 and also 205 levels. After that coffeemachines The Technivorm is hand-built in the Netherlands.
Also the graphical details are amazing as well as you will certainly Nintendo 3DS Emulator You can appreciate Terraria together with your close friends.
