Broadlink SP mini switch
pabmardo
Domoticz version: 2.3530
Post by pabmardo »
Hi all, I have received a wifi switch from broadlink and wanted to control it as I am doing with the Orvibo S20 from domoticz... the problem is I can not find anything outside Android to control them... HAve found the SDK for IOS and Android and some githubs projects... but nothing I can use from the raspberry pi... Any ideas?? any intention to integrate broadlink products?? they are quality and cheap and seems to me there will be plenty of people using them.
Thanks a lot
Jonkerfrisjes
Domoticz version: V3.5877
Re: Broadlink SP mini switch
Post by Jonkerfrisjes »
I have the same question for a TC2 switch from Broadlink. Is there a way to find out the code for these device.? Without the RM controller.
Broadlink has many great items.
Andre
kalinkamaen
Domoticz version: 2022.2
Post by kalinkamaen »
Hello sir.
I have broadlink running with Eventghost with this pluguin:
http://www.eventghost.org/forum/viewtop ... 6f3654b786
The downside is that you need to have a android device. I use my old phone for this. And instal this ap :
http://rm-bridge.fun2code.de/
You can use this code to switch on or off a switch on domoticz!
HOST = "192.168.1.21"
PORT = 80
DEVICE_NUMBER = 10
LIGHTS_ON = True
import urllib2
from urllib2 import HTTPError, URLError
ERROR_REASON = (
    "We failed to reach a server.\n"
    "Reason: %s"
ERROR_CODE = (
    "The server couldn't fulfill the request.\n"
    "Error code: %d"
if LIGHTS_ON:
    LIGHTS = 'On'
else:
    LIGHTS = 'Off'
URL = "http://%s:%d/json.htm?type=command&param=switchlight&idx=%s&switchcmd=%s" % (HOST, PORT, str(DEVICE_NUMBER), LIGHTS)
try:
    urllib2.urlopen(URL)
except HTTPError as httpError:
    eg.PrintError(ERROR_REASON % httpError.reason)
    eg.PrintError(ERROR_CODE % httpError.code)
except URLError as urlError:
    eg.PrintError(ERROR_REASON % urlError.reason)
Forum thread found here:
Windows 10, Domoticz 14784
drbrains
Domoticz version: v3.6799
Post by drbrains »
I realize this is an old post, but look here to get started:
https://github.com/mjg59/python-broadlink
It should work for the SP2/3 and MP1. Maybe it's compatible.
xxLeoxx93
Post by xxLeoxx93 »
drbrains wrote:I realize this is an old post, but look here to get started:
is there any guide how to use the .py script in domoticz?
Thank you!
ijobain
Post by ijobain »
Thank you!
Read this
https://www.domoticz.com/forum/viewtopi ... 40#p108350
Logan923
Post by Logan923 »
levels in between 195 and also 205 levels. After that coffeemachines The Technivorm is hand-built in the Netherlands.
Winsor421
Post by Winsor421 »
Also the graphical details are amazing as well as you will certainly Nintendo 3DS Emulator You can appreciate Terraria together with your close friends.
