Python plugin: Daikin BRP069A42 WiFi adapter
videodrome
Re: Python plugin: Daikin BRP069A42 WiFi adapter
Anyone could help me?
Inviato dal mio HUAWEI CRR-L09 utilizzando Tapatalk
spiderjn
- Domoticz version: 3.8834
hi,
first thank's for this good job.
it is a very interesting plugin for my installation, I tried to install it on my raspberry and unfortunately as soon as I configure a new hardware, it crashes Domoticz and I must go remove the python file in plugin folder.
i search any information on how investigate this point without success.
Any help for start this configuration or how to test this plugin outside of domoticz ?
i've installed domoticz beta.
Best regards
Best regards
spiderjn
hi all
finally i prefer update hardware plugin.
See : https://www.domoticz.com/forum/viewtopi ... 34&t=21126
best regards
best regards
leejoow
Updated the git plugin to work with new Domoticz version. Stability seems to be improved after removing some imports.
Prutsium
Just installed it and works great. Added the first Aircon (1 of 3) and no issues with setup.
Prutsium
Seems some settings always revert back to some previous settings for example i set Airco to FAN but jumps back to cool after a minute.Prutsium wrote: Saturday 07 July 2018 10:38 Just installed it and works great. Added the first Aircon (1 of 3) and no issues with setup.
Whats wrong here ?
Prutsium
Seems with the new firmware of the Wifi adapter some commands are not accepted anymore.
Below i try to switch to FAN mode got the following result:
2018-07-18 10:39:22.576 (Airco - Living) Processing 'ReadEvent' message
2018-07-18 10:39:22.576 (Airco - Living) Received 84 bytes of data
2018-07-18 10:39:22.576 (Airco - Living) 48 54 54 50 2f 31 2e 30 20 32 30 30 20 4f 4b 0d 0a 43 6f 6e HTTP/1.0.200.OK..Con
2018-07-18 10:39:22.576 (Airco - Living) 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 31 39 0d 0a 43 6f 6e tent-Length:.19..Con
2018-07-18 10:39:22.576 (Airco - Living) 74 65 6e 74 2d 54 79 70 65 3a 20 74 65 78 74 2f 70 6c 61 69 tent-Type:.text/plai
2018-07-18 10:39:22.576 (Airco - Living) 6e 0d 0a 0d 0a 72 65 74 3d 50 41 52 41 4d 20 4e 47 2c 61 64 n....ret=PARAM.NG,ad
2018-07-18 10:39:22.576 (Airco - Living) 76 3d 31 33 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. v=13
2018-07-18 10:39:22.576 (Airco - Living) Pushing 'onMessageCallback' on to queue
2018-07-18 10:39:22.576 (Airco - Living) Processing 'DisconnectedEvent' message
2018-07-18 10:39:22.576 (Airco - Living) Disconnect event received for '192.168.199.106:80'.
2018-07-18 10:39:22.577 (Airco - Living) Pushing 'onDisconnectCallback' on to queue
2018-07-18 10:39:22.577 (Airco - Living) Processing 'onMessageCallback' message
2018-07-18 10:39:22.577 (Airco - Living) Calling message handler 'onMessage'.
2018-07-18 10:39:22.577 (Airco - Living) onMessage called
2018-07-18 10:39:22.577 (Airco - Living) Received data from connection Set Control: ret=PARAM NG,adv=13
Prutsium
After digging in your Python script i found the whole FAN mode missing.Prutsium wrote: Wednesday 18 July 2018 9:44 Seems with the new firmware of the Wifi adapter some commands are not accepted anymore.
Below i try to switch to FAN mode got the following result:Code: Select all
2018-07-18 10:39:22.576 (Airco - Living) Processing 'ReadEvent' message 2018-07-18 10:39:22.576 (Airco - Living) Received 84 bytes of data 2018-07-18 10:39:22.576 (Airco - Living) 48 54 54 50 2f 31 2e 30 20 32 30 30 20 4f 4b 0d 0a 43 6f 6e HTTP/1.0.200.OK..Con 2018-07-18 10:39:22.576 (Airco - Living) 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 31 39 0d 0a 43 6f 6e tent-Length:.19..Con 2018-07-18 10:39:22.576 (Airco - Living) 74 65 6e 74 2d 54 79 70 65 3a 20 74 65 78 74 2f 70 6c 61 69 tent-Type:.text/plai 2018-07-18 10:39:22.576 (Airco - Living) 6e 0d 0a 0d 0a 72 65 74 3d 50 41 52 41 4d 20 4e 47 2c 61 64 n....ret=PARAM.NG,ad 2018-07-18 10:39:22.576 (Airco - Living) 76 3d 31 33 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. v=13 2018-07-18 10:39:22.576 (Airco - Living) Pushing 'onMessageCallback' on to queue 2018-07-18 10:39:22.576 (Airco - Living) Processing 'DisconnectedEvent' message 2018-07-18 10:39:22.576 (Airco - Living) Disconnect event received for '192.168.199.106:80'. 2018-07-18 10:39:22.577 (Airco - Living) Pushing 'onDisconnectCallback' on to queue 2018-07-18 10:39:22.577 (Airco - Living) Processing 'onMessageCallback' message 2018-07-18 10:39:22.577 (Airco - Living) Calling message handler 'onMessage'. 2018-07-18 10:39:22.577 (Airco - Living) onMessage called 2018-07-18 10:39:22.577 (Airco - Living) Received data from connection Set Control: ret=PARAM NG,adv=13
After adding:
elif (mode == "6"):
sValueNew = "40" #Fan
elif (Devices[4].sValue == "40"):
requestUrl = requestUrl + "6"
(Ps me proud of myself never worked with Python but just looked at the logic and noticed something missing
Prutsium
I noticed that also the calculation of the FAN levels did not work perfectly as often a setting above L3 reverted back to Auto.
So added all the fan levels manually and now it also works normal again.
Still figuring out how to implement the Wind Direction got some ideas but as the f_dir is also a mandatory command in the string i fixed it now on 3 (hor / ver)
# Basic Python Plugin Example
# Author: GizMoCuz
<plugin key="BRP069A42" name="Daikin Airconditioning (BRP069A42)" author="leejoow" version="1.1.0" externallink="https://www.daikin.nl/nl_nl/products/BRP069A42.html">
<params>
<param field="Address" label="IP Address" width="200px" required="true" default=""/>
<param field="Port" label="Port" width="30px" required="true" default="80"/>
<param field="Mode1" label="Update every x seconds" width="75px">
<options>
<option label="30" value="3" />
<option label="60" value="6" default="true" />
<option label="90" value="9" />
<option label="120" value="12" />
<option label="150" value="15" />
<option label="180" value="18" />
<option label="210" value="21" />
<option label="240" value="24" />
</options>
</param>
<param field="Mode2" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
from datetime import datetime
class BasePlugin:
enabled = True
powerOn = 0
runCounter = 0
httpConnSensorInfo = None
httpConnControlInfo = None
httpConnSetControl = None
def __init__(self):
#self.var = 123
return
def onStart(self):
Domoticz.Log("onStart called")
if Parameters["Mode2"] == "Debug":
Domoticz.Debugging(1)
if (len(Devices) == 0):
Domoticz.Device(Name="Power", Unit=1, Image=16, TypeName="Switch", Used=1).Create()
Domoticz.Device(Name="Temp IN", Unit=2, TypeName="Temperature", Used=1).Create()
Domoticz.Device(Name="Temp OUT", Unit=3, TypeName="Temperature",Used=1).Create()
Options = {"LevelActions" : "|||||",
"LevelNames" : "|Auto|Cool|Heat|Fan|Dry",
"LevelOffHidden" : "true",
"SelectorStyle" : "1"}
Domoticz.Device(Name="Mode", Unit=4, TypeName="Selector Switch", Image=16, Options=Options, Used=1).Create()
Options = {"LevelActions" : "|||||||",
"LevelNames" : "|Auto|Silent|L1|L2|L3|L4|L5",
Domoticz.Device(Name="Fan Rate", Unit=5, TypeName="Selector Switch", Image=7, Options=Options, Used=1).Create()
Domoticz.Device(Name="Temp TARGET", Unit=6, Type=242, Subtype=1, Image=16, Used=1).Create()
Domoticz.Log("Device created.")
DumpConfigToLog()
Domoticz.Heartbeat(10)
self.httpConnSensorInfo = Domoticz.Connection(Name="Sensor Info", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"])
self.httpConnSensorInfo.Connect()
self.httpConnControlInfo = Domoticz.Connection(Name="Control Info", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"])
self.httpConnControlInfo.Connect()
self.httpConnSetControl = Domoticz.Connection(Name="Set Control", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"])
self.runCounter = int(Parameters["Mode1"])
def onStop(self):
Domoticz.Log("onStop called")
def onConnect(self, Connection, Status, Description):
if (Status == 0):
Domoticz.Debug("Connection successful")
data = ''
headers = { 'Content-Type': 'text/xml; charset=utf-8', \
'Connection': 'keep-alive', \
'Accept': 'Content-Type: text/html; charset=UTF-8', \
'Host': Parameters["Address"]+":"+Parameters["Port"], \
'User-Agent':'Domoticz/1.0', \
'Content-Length' : "%d"%(len(data)) }
if (Connection == self.httpConnSensorInfo):
Domoticz.Debug("Sensor connection created")
requestUrl = "/aircon/get_sensor_info"
elif (Connection == self.httpConnControlInfo):
Domoticz.Debug("Control connection created")
requestUrl = "/aircon/get_control_info"
elif (Connection == self.httpConnSetControl):
Domoticz.Debug("Set connection created")
requestUrl = self.buildCommandString()
Connection.Send({"Verb":"GET", "URL":requestUrl, "Headers": headers})
else:
Domoticz.Debug("Connection failed")
def onMessage(self, Connection, Data):
Domoticz.Log("onMessage called")
dataDecoded = Data["Data"].decode("utf-8", "ignore")
Domoticz.Debug("Received data from connection " + Connection.Name + ": " + dataDecoded)
position = dataDecoded.find("pow=")
power = dataDecoded[position + 4 : position + 5]
position = dataDecoded.find("mode=")
mode = dataDecoded[position + 5 : position + 6]
position = dataDecoded.find("f_rate=")
f_rate = dataDecoded[position + 7 : position + 8]
position = dataDecoded.find("stemp=")
stemp = dataDecoded[position + 6 : position + 8]
Domoticz.Debug("Power: " + power + "; Mode: " + mode + "; FanRate: " + f_rate + "; Target temperature: " + stemp)
self.powerOn = int(power)
# Power
if (power == "0"):
if (Devices[1].nValue != 0):
Devices[1].Update(nValue = 0, sValue ="0")
else:
if (Devices[1].nValue != 1):
Devices[1].Update(nValue = 1, sValue ="100")
# Mode
if (mode == "0"):
sValueNew = "10" #Auto
elif (mode == "2"):
sValueNew = "50" #Dry
elif (mode == "3"):
sValueNew = "20" #Cool
elif (mode == "4"):
sValueNew = "30" #Warm
elif (mode == "6"):
if (Devices[4].nValue != self.powerOn or Devices[4].sValue != sValueNew):
Devices[4].Update(nValue = self.powerOn, sValue = sValueNew)
# Fan rate
if (f_rate == "A"):
sValueNew = "10" # Auto
elif (f_rate == "B"):
sValueNew = "20" # Silent
#Manual f_rate
elif (f_rate == "3"):
sValueNew = "30" # L1
elif (f_rate == "4"):
sValueNew = "40" # L2
elif (f_rate == "5"):
sValueNew = "50" # L3
elif (f_rate == "6"):
sValueNew = "60" # L4
elif (f_rate == "7"):
sValueNew = "70" # L5
# else:
# sValueNew = str(int(f_rate) * 10)
if (Devices[5].nValue != self.powerOn or Devices[5].sValue != sValueNew):
Devices[5].Update(nValue = self.powerOn, sValue = sValueNew)
#lastUpdate = datetime.strptime(Devices[6].LastUpdate, "%Y-%m-%d %H:%M:%S")
#delta = datetime.now() - lastUpdate
# Setpoint temperature, update once per 30 minutes if no changes
#if (Devices[6].nValue != self.powerOn or Devices[6].sValue != stemp or delta.total_seconds() > 1800):
# Devices[6].Update(nValue = self.powerOn, sValue = stemp)
elif (Connection == self.httpConnSensorInfo):
position = dataDecoded.find("htemp=")
htemp = dataDecoded[position + 6 : position + 10]
position = dataDecoded.find("otemp=")
otemp = dataDecoded[position + 6 : position + 10]
Domoticz.Debug("Internal temperature: " + htemp + "; Outside temperature: " + otemp)
Devices[2].Update(nValue = 0, sValue = htemp)
Devices[3].Update(nValue = 0, sValue = otemp)
#Force disconnect, in case the Daikin unit doesn't disconnect
if (Connection.Connected()):
Domoticz.Debug("Close connection")
Connection.Disconnect()
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Debug("Command received U="+str(Unit)+" C="+str(Command)+" L= "+str(Level)+" H= "+str(Hue))
if (Unit == 1):
if(Command == "On"):
self.powerOn = 1
else:
self.powerOn = 0
#Update state of all other devices
Devices[4].Update(nValue = self.powerOn, sValue = Devices[4].sValue)
Devices[5].Update(nValue = self.powerOn, sValue = Devices[5].sValue)
Devices[6].Update(nValue = self.powerOn, sValue = Devices[6].sValue)
if (Unit == 4):
Devices[4].Update(nValue = self.powerOn, sValue = str(Level))
if (Unit == 5):
Devices[5].Update(nValue = self.powerOn, sValue = str(Level))
if (Unit == 6):
Devices[6].Update(nValue = self.powerOn, sValue = str(Level))
self.httpConnSetControl.Connect()
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Debug("Connection " + Connection.Name + " closed.")
def onHeartbeat(self):
self.runCounter = self.runCounter - 1
if self.runCounter <= 0:
Domoticz.Debug("Poll unit")
if (self.httpConnSensorInfo.Connected() == False):
if (self.httpConnControlInfo.Connected() == False):
else:
Domoticz.Debug("Polling unit in " + str(self.runCounter) + " heartbeats.")
def buildCommandString(self):
#Minimal string: pow=1&mode=1&stemp=26&shum=0&f_rate=B&f_dir=3
requestUrl = "/aircon/set_control_info?shum=0&f_dir=3&pow="
if (self.powerOn):
requestUrl = requestUrl + "1"
else:
requestUrl = requestUrl + "0"
requestUrl = requestUrl + "&mode="
if (Devices[4].sValue == "10"):
elif (Devices[4].sValue == "20"):
requestUrl = requestUrl + "3"
elif (Devices[4].sValue == "30"):
requestUrl = requestUrl + "4"
elif (Devices[4].sValue == "50"):
requestUrl = requestUrl + "2"
requestUrl = requestUrl + "&f_rate="
if (Devices[5].sValue == "10"):
requestUrl = requestUrl + "A"
elif (Devices[5].sValue == "20"):
requestUrl = requestUrl + "B"
elif (Devices[5].sValue == "30"):
elif (Devices[5].sValue == "40"):
elif (Devices[5].sValue == "50"):
requestUrl = requestUrl + "5"
elif (Devices[5].sValue == "60"):
elif (Devices[5].sValue == "70"):
requestUrl = requestUrl + "7"
# else:
# requestUrl = requestUrl + str(int(int(Devices[5].sValue) / 10))
requestUrl = requestUrl + "&stemp=" + Devices[6].sValue
return requestUrl
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
- bueno79
- Domoticz version: 4.9700
I have 2 wifi for daikin in version BRP069A42. Both set with domoticz with integrated plugin. Just get a new wifi adaptator and the ref is now BRP069B42. It is not working anymore. It seems something has change.
Someone is able to check the plugin ? Impossible to find the old version of the adaptator on internet. So Domoticz should support this now asap. Pleease
regards
Bueno
regards
Bueno
spiderjn
Asap means someone have to check and modify existing plugin, i've made evolution for support natively those plugin in Domoticz.
You have to find a person who has development skills and especially a new generation box (BRP069B42).
sorry I can not help
- Bospieper
- Domoticz version: 2022.1
I need your help in understanding the following errors. The first attachment appears in the log when my Daikin event runs. Every evening around the same time the first error appears one or several times followed by the second error causes domoticz to stop.
- Domoticz_Daikin fout4.JPG (50.72 KiB) Viewed 1022 times
- Domoticz fout.JPG (292.05 KiB) Viewed 1022 times
