Weekly programming
bigpea
Re: Weekly programming
Post by bigpea »
I love you! :mrgreen:
Thanks Thanks Thanks!
Unfortunatelly I updated to the last version of Domoticz Beta and the timers doesn't work! But you work is fantastic!
syrhus
Domoticz version: 2021.1
Post by syrhus »
Good! Happy to know it's working.
Just one point, on css part, I created only 4 colors. In your case, edit the style.css file, at the end there are classes .m0 .m1.. so add a .m4 and may be a .m5 class with the required color.
bigpea
Post by bigpea »
oh ok perfect ;) thanks
Eoreh
Post by Eoreh »
This can be a very interesting solution for me in conjunction with the dzVents script. for heating control.
https://www.domoticz.com/forum/viewtopi ... 59&t=21422
renerene
Post by renerene »
Just found this page after looking for a time table option to use with my new Smart Virtual Thermostat
viewtopic.php?f=34&t=19418
Can you please explain how to install? I have copied / replaced all the files in the ZIP file, but now what? Where is html5 file? Do I need to manually add a switch in Domoticz?
syrhus
Post by syrhus »
Hi @renerene
I've updated files and manual on following link:
https://gist.github.com/syrhus/8fbb01fb ... be210993c8
Actually, it's working for Setpoints and swtiches planning.
Feel free to contact me if you still have some issues
pjsgsy
Domoticz version: 3.8153
Post by pjsgsy »
Fantastic work! Yet to get it setup, but just what I was looking for and adds considerable value to Domoticz. Thank you for sharing with the community.
syrhus
Post by syrhus »
I forgot to specify it is working with ON/OFF switch and switch selector levels for instance with "electric heating":
renerene
Post by renerene »
syrhus wrote: Friday 19 January 2018 7:33 I've updated files and manual on following link:
Sorry, still no clue. Done the adjustement within the files. Now what? Back to domoticz and 'add hardware' or 'manually add device' in switches? What to select from the pull-down list?
I have manually added a dummy test switch, type selector. I does not look like the screenshots above, just the nomal domoticz fields.
syrhus
Post by syrhus »
@renerene once you have your swith device or SetPoint device, did you click on planning button to access to the planning window?
Else, think to clear the application cache of your browser to force the domoticz application to reload files or change the html.appcache value
renerene
Post by renerene »
syrhus wrote: Saturday 20 January 2018 9:10 @renerene once you have your swith device or SetPoint device, did you click on planning button to access to the planning window?
Thank you. It works!
syrhus
Post by syrhus »
Good news ;)
Play with it and if you have some troubles or suggestions, feel free to send its to me :)
Patricen
Domoticz version: Beta rel
Post by Patricen »
That's definitely great!
Is it planned to be pulled in the next beta versions?
giribaldo
Post by giribaldo »
Hi, i'm new to forum and to domoticz, first i must say thanks to syrhus for this program that i think is very very useful!!
i installed just yesterday domoticz on windows and today on linux (mint) just for evaluating and testing purpose...
and i feel so stupid becaus i tried all today to make work this program in domoticz but without success... :(
whatever i do, it dos not come out the planning button or menu, just the usual timer of domoticz...
this on windows and also on linux.
the domoticz version is Domoticz version: 3.8153
i will still try to make it work because at first look i like domoticz, just i would like a program like this to simplify the scheduling of my heating sistem that is drived by a PLC and i would like to control it in Modbus RTU and domoticz (on raspberry).
if someone as some advice to make it work thanks a lot!!
syrhus
Post by syrhus »
giribaldo wrote: Sunday 11 February 2018 21:53 Hi, i'm new to forum and to domoticz, first i must say thanks to syrhus for this program that i think is very very useful!!
Hi @giribaldo
Just to be sure, on your device, do you see the planning button? Are you able to create a planning on your device?
As I exposed, it works on Measures device and Switches device.
Else, try to force to refresh the application cache of your web browser. You can either upgrade the number in the html.appcache version or delete the application cache of your browser.
bigpea
Post by bigpea »
Hi Syrhus,
I'm creating a tablet dashboard for domoticz and I would like to insert your scheduler in this dashboard.
I'm not very practical in javascript, so I kindly ask you: you started from an example (you can give me the link) or you created it completely from zero (I'm dead :D )?
syrhus
Post by syrhus »
Hi @bigpea
First, I searched some widget or jquery plugin but no one was like I wanted. So I made it from scratch.
If you need more help to adjust or improve my "plugin" feel free to contact me, it would be a pleasure to help.
bigpea
Post by bigpea »
Yes, I also searched but I did not find anything that could be right.
I try to ask you some help.. thanks.
As told, I'm creating a new dashbord, I'm almost at the end:
I want to integrate your timer because I think that is a great idea!
But.. I copied your file in my project:
- planning.js
- style.css
and i inserted in my page the code for the table:
<div id="timesheetcontainer" style="display:none">
        <div class="modes">
        </div>
        <table id="timesheet" >
            <thead></thead>
            <tbody></tbody>
        </table>
		<div class="actions">
			<div class="btnstyle3" id="clearTimeSheet" data-i18n="Clear">Clear</div>
			<div class="btnstyle3" id="updateSetPoints" data-i18n="Update">Update</div>
		</div>
 </div>
At this point I have to retrieve all scheduled timers for all device (doesn't exist a filter for idx) with a request at domoticz (https://www.domoticz.com/wiki/Domoticz_ ... or_Devices) and i receive a json like this:
         "Active" : "true",
         "Date" : "",
         "Days" : 128,
         "DevName" : "Set Point Camera",
         "DeviceRowID" : 154,
         "Hue" : 0,
         "IsThermostat" : "false",
         "Level" : 20,
         "MDay" : 0,
         "Month" : 0,
         "Occurence" : 0,
         "Randomness" : "false",
         "ScheduleDate" : "2018-02-14 00:00:00",
         "Time" : "00:00",
         "TimerCmd" : 0,
         "TimerID" : 101,
         "TimerType" : 2,
         "TimerTypeStr" : "On Time",
         "Type" : "Device"
At this point I have to filter the timers received for my device (by name, no idx returned) in order to have all timers for only my device interested.
Up to here, I can do it without any problem (ajax call and javascript filter).
But, how I can call your javascript in order to create your timer table?
Which information and in which format I have to pass it?
I hope that I was clear.. :)
syrhus
Post by syrhus »
I will try to reply tomorrow evening but first point, on github, I changed the code. No more html code required; the entire table is created from javascript file (planning.js)
Look at my github manual, you "just have" to call the initialisation of the timer somewhere in your code to create the html table after a container id and another call to "fill" the table with the timers ajax response.
Send me your javascript file for your dashboard if you want to explain where to put the javascript calls.
About your dashboard, it look like very nice!! Nice job!
bigpea
Post by bigpea »
ok, perfect. as soon as possible I will implement the new code, I will let you know, thanks.
