DAVIZINHO
Post by DAVIZINHO »
jelleeelco wrote: Tuesday 12 December 2017 10:57
jelleeelco wrote: Tuesday 12 December 2017 10:26
corbin wrote: Sunday 10 December 2017 10:54 multiple gateway support is in the beta only
Hi Corbin,
Please see my post below. I got two gateways in my MiHome app, only in domoticz. Devices from both gateways come to domoticz as if it was from one gateway.
This worked on both beta as well as stable versions of domoticz. As far as I could tell, adding a second gateway only has to happen in the MiHome app, nothing needs to be done in Domoticz.
But please let me know in case I'm wrong!
Ahhhh silly me...
It just sees the second Gateway, just as if you would enter a wrong IP/password in the gateway settings. You can see updates when done physically (switch) but not when done from MiHome app. You can also not control the switches from Domoticz.
Is my assumption correct that this setup would work for window sensors, temperature sensors and motion detectors? And then lights/switches on the gateway that is added to Domoticz?
hello,
in first place, sorry for my poor english. is not my natural languaje.
In the past I tried to connect a second gateway to domoticz adding this as "aditional gateway" this not works because only one gateway works.
After this i connect a second domoticz and this second gateway connected in the second domoticz. apears duplicate sensor and was a kaos. :-O
After this i connect a second gateway in a second subnet and configure one as slave and one as master. This works fine, not perfect but fine.
Your idea is connect the second gateway at wifi and configure it in my home. no more? with this the sensor works??? :-O
jelleeelco
Post by jelleeelco »
mvveelen wrote: Tuesday 12 December 2017 20:55 Anyone who has a link to a Xiaomi wall switch which I can use to switch a light with (220V) and which sends a signal to the gateway AND which I can use in Europe in a regular flush-mounted box (about 76mm diameter) ? I see some switches, but they don't seem to fit in the Dutch boxes I think.
I bought one and tried to build it in: doesn't work. It simply does not fit. There is no xiaomi switch that fits in the Dutch boxes, don't waist your money.
jelleeelco
DAVIZINHO wrote: Tuesday 12 December 2017 22:12
Hi Corbin,
Ahhhh silly me...
hello,
Correct. Remember, in wiki it clearly states that even if your ip adres or password is wrong, it will still receive input.from the gateway. Same as for a second one: not even added to domoticz, but one your network..... Domoticz will receive all updates. I have a second one added like that to MiHome without changing anything in domoticz and all the sensors work (even wireless switches work).
After last night though (added second domoticz) nothing worked, wife angry and now getting rid.of it all. Back to manual switching the.lights!
mvveelen
Post by mvveelen »
jelleeelco wrote: Tuesday 12 December 2017 22:20
Thanks. So, partly dismantling the switch also didn't help? Then I have to look for another solution for my 'problem'.
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
jelleeelco
Nope, keeps on coming back
Edit: I meant that for a different question. No you can't modify the switch, you'll break it.
I used a "opbouw" box but not very elegant.
DAVIZINHO
Post by DAVIZINHO »
jelleeelco wrote: Tuesday 12 December 2017 22:25
Ahhhh silly me...
hello,
Great! i will try.
How is fast in notify the events the second gateway. instant like the first?
jelleeelco
Yes, instant
DAVIZINHO
Post by DAVIZINHO »
jelleeelco wrote: Wednesday 13 December 2017 12:31 Yes, instant
perfect! thanks
This weekend i will configure it
welby
Post by welby »
Any tips on how to add a motion sensor? Just received a motion sensor and another 2 door switches which domoticz has added no worries but it won't see the motion sensor.
madrian
Post by madrian »
upgrade to beta
DAVIZINHO
Post by DAVIZINHO »
welby wrote: Thursday 14 December 2017 7:50 Any tips on how to add a motion sensor? Just received a motion sensor and another 2 door switches which domoticz has added no worries but it won't see the motion sensor.
the motion sensor aqara only works in beta :-(
Andree
Post by Andree »
Ahhhh silly me...
hello,
Hi man,can you explain step by step how i can add a second gateway please?update after update i'm not sure witch solution work fine!
corbin
Post by corbin »
jelleeelco wrote: Tuesday 12 December 2017 10:57 Is my assumption correct that this setup would work for window sensors, temperature sensors and motion detectors? And then lights/switches on the gateway that is added to Domoticz?
Yes you are correct, for only reading the values of sensors the 2nd gateway shouldn't need to be added to Domoticz. The only benefit of adding the 2nd gateway in Domoticz is that you can control the gateway light and sounds (but not the mp3) from Domoticz.
corbin
Post by corbin »
Andree wrote: Friday 15 December 2017 16:33 Hi man,can you explain step by step how i can add a second gateway please?update after update i'm not sure witch solution work fine!
Do the steps in the wiki not work for you? I've used a new Domoticz install and adding 2 gateways worked for me.
welby
Post by welby »
madrian wrote: Thursday 14 December 2017 8:11 upgrade to beta
Of course thanks for the tip working great now 8-) 8-)
Schorschi
Post by Schorschi »
is it possible to get direct access to sensor data over JSON command?
For example i want read the state of an Door Switch directly from the Xiaomi Gateway with an LUA script.
Thx
snadwich
Post by snadwich »
Maybe a good place to post here, i made a youtube review of the Gateway and some different sensors. Have fun!
raffiq78
Post by raffiq78 »
Hello.
I dont know if it is only my problem but after last path (few days ago) Aquara Wall Switches stopped to work. When I click them in domoticz to turn them on they seems like turning on but the light stays OFF :(
Please fix it...
corbin
Post by corbin »
wall switches still working here. did you apply the latest gateway update? I haven't on mine.
corbin
Post by corbin »
Schorschi wrote: Monday 18 December 2017 14:43 Hello,
Thx
should be possible from LUA, see https://louiszl.gitbooks.io/lumi-gateway-local-api
eg send a read request to your gateway IP on port 9898:
{"cmd":"read"","sid":"158d000111eed3"}
