Backup and restore - implications
mcwieger
Domoticz version: 2020.1
Post by mcwieger »
I'm experiencing issues with Domoticz - MyDomoAtHome - Imperihome integration. I was advised to do a clean install of Domoticz. Since I have A LOT running on Domoticz, I'm quite reluctant to do a backup and restore, but am willing to give it a try if it means I can keep using Imperihome on my wall tablet.
So asking for your experiences: is it safe to do a backup/restore? Anything that is not restored (e.g. scripts, I assume I have to put these back separately)? Any issues with assignment of new device ID's or anything?
Any feedback appreciated.
I moved to HomeAssistant. It was fun while it lasted!
freijn
Domoticz version: Stable
Re: Backup and restore - implications
Post by freijn »
Some thoughts....
I see you are running Domoticz on your synology ?
I not sure how, but must be possible too.
I have RaspberryPi , I shutdown my system, make an image of the SDcard and store it somewhere save.
Start messing around with the config. . if something breaks.. easy and yes, I will loose by database entries of the time I am testing but that is all.
Could such be possible running on a Sygnology?
Long time ago I did a db restore and it worked perfectly :-)
Be aware any .sh perl python scripts are NOT stored in the DB.
If you use the lua interface on Domoticz it is stored in the DB , as far as I know, But some Lua can also be stored on the drive itself..
Hope this does help you a little...
Frank
gijsje
Post by gijsje »
What d o you use to make the image file?
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
mcwieger
Post by mcwieger »
Good point I did not mention indeed: I'm on Synology. This means I remove the package (comparable with an app on your phone) and reinstall it and then do a db restore. That's it, no image or SD cards.
I can place lua scripts etc back in thr right places, no problem, mainly need to know if my hardware, devices, scenes etc come back exactly the same as they were...
