domoticz in synology as package! Available now.
jumbotroll
Post by jumbotroll »
pwet wrote: Saturday 09 December 2017 8:22 Hi,
I installed domoticz from Jumbotroll on my ds718 +, and I have a problem with the drivers.
I have the following messages in dmesg
[57.968180] cp210x: magic version '4.4.15 SMP preempt mod_unload' should be '4.4.15+ SMP preempt mod_unload'
[59.599291] pl2303: magic version '4.4.15 SMP preempt mod_unload' should be '4.4.15+ SMP preempt mod_unload'
[59.673039] ch341: magic version '4.4.15 SMP preempt mod_unload' should be '4.4.15+ SMP preempt mod_unload'
[59.686792] ti_usb_3410_5052: magic version '4.4.15 SMP preempt mod_unload' should be '4.4.15+ SMP preempt mod_unload'
Could you help me please ?
thank you in advance
You have to give us more info!
What DSM version do you installed on your NAS DSM6.1 or DSM6.2 beta?
What Domoticz package/version did you test?
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
pwet
Post by pwet »
Dsm 6.1 , test two package/ version
Envoyé de mon ASUS_Z00AD en utilisant Tapatalk
pwet
Post by pwet »
jumbotroll wrote: Saturday 09 December 2017 10:58
I am in 6.1 dsm
I tried the following four versions:
Domoticz Stable V3.8153 for DSM 6.1
Domoticz Stable for V3.8153 for DSM 6.1 with Python
Domoticz Beta for DSM 6.1
Domoticz Beta for DSM 6.1 with Python
I use the following materials:
RfxCom RFXtrx433E Ext usb
rflink gateway usb
openzwave z-stick s2
I have that rfxcom that works
jumbotroll
pwet wrote: Sunday 10 December 2017 13:18
I am in 6.1 dsm
rflink gateway usb
I am trying to fix this for you and recompiled the kernel.
Can you please test the latest beta and see if that fixed the problem!
domoticz_apollolake-6.1_3.0.8775-7.spk
http://www.jadahl.com/domoticz_beta_6.1 ... 8775-7.spk
Jumbotroll
jumbotroll
@pwet
I have also compiled a modified version with vermagic: 4.4.15+ SMP preempt mod_unload.
domoticz_apollolake-6.1_3.0.8775-7-test.spk
http://www.jadahl.com/domoticz_beta_6.1 ... 7-test.spk
Please test and report back if one of them working.
Jumbotroll
pwet
Post by pwet »
jumbotroll wrote: Sunday 10 December 2017 15:05 @pwet
thank you very much
The test version works
Another big thank you for everything
jumbotroll
pwet wrote: Sunday 10 December 2017 18:59
thank you very much
Ok.
Thanks for testing!
Have renamed domoticz_apollolake-6.1_3.0.8775-7-test.spk to domoticz_apollolake-6.1_3.0.8775-7.spk
I have also rebuild stable 8153 and python version with vermagic: 4.4.15+ SMP preempt mod_unload fix.
Jumbotroll
Gravityz
Domoticz version: 2022.2
Post by Gravityz »
does this have any impact on users who are not using rfxcom an rflink stuff?
jumbotroll
Gravityz wrote: Monday 11 December 2017 8:59 does this have any impact on users who are not using rfxcom an rflink stuff?
No, this is only changes in the USB drivers. The kernel version on arch-apollolake DSM 6.1 has a bug.
Jumbotroll
Gravityz
Post by Gravityz »
ok thanks.
no problems here with 8720
had problems with usb connectivity which resulted in loosing every zwave device after some time but this seems to have solved itself.
Maybe this was also usb driver related.
PhilippeDom
Domoticz version: 3.0.8770
Post by PhilippeDom »
Hi Jumbotroll,
I have the same vermagic: 4.4.15+ problems as pwet. Could you compile the files for Realtek RTD1296 SoC?
Thanks in advance for your support !!
Domoticz 3.0.8770-7
Realtek RTD1296 SoC
DSM 6.1.4-15217 Update 2
jumbotroll
PhilippeDom wrote: Tuesday 12 December 2017 18:49 Hi Jumbotroll,
Domoticz 3.0.8770-7
Realtek RTD1296 SoC
Sure ;)
Give me 20 minutes and I will update a link here for you to test.
Jumbotroll
jumbotroll
@PhillipeDom
http://www.jadahl.com/domoticz_beta_6.1/
domoticz_rtd1296-6.1_3.0.8777-7.spk with fix for "should be '4.4.15+ SMP preempt mod_unload"
http://www.jadahl.com/domoticz_beta_6.1 ... 8777-7.spk
Jumbotroll
PhilippeDom
jumbotroll wrote: Tuesday 12 December 2017 19:39 @PhillipeDom
Thanks a lot, it's finally working... Great support !!!
jumbotroll
PhilippeDom wrote: Tuesday 12 December 2017 19:46
Great!
This I think is an error from synology when they compiled the kernel for rtd1296 and apollolake.
I have also updated the python version http://www.jadahl.com/domoticz_beta_6.1_python/
Jumbotroll
Sandman79
Post by Sandman79 »
Hi Jumbrotroll, this might be a crosspost, but i was just wondering if the Evohome Web Api is or will be supported in your build? As I'm having some issues, it is not showing the option to input the credentials to the eveohome website.
Edit: Fixed with renewing the browser cache
Aad3229
Post by Aad3229 »
Hi, I used to run Domoticz on a Pi. I now installed the latest Apollolake version package on my Synology DS218+. I understand that there is no domoticz.sh in Synology but on the Pi I could change the Loglevel there in order to get only status or error messages. Where can I do this in the Synology package? (could not find it in the start-stop-status file).
Domoticz V4.10717 on Synology, RFXtrx433E USB 433.92MHz Transceiver, 9 x KAKU Switch (APA3-1500R), 1 x ABST-604 KAKU Dusk sensor, MiLight iBox V6, OpenZwave USB-stick Aeon LabS, Zwave PIR, Zwave door sensors, Zwave powerplugs
ednl
Domoticz version: 3.8875
Post by ednl »
Aad3229 wrote: Tuesday 19 December 2017 12:09 Hi, I used to run Domoticz on a Pi. I now installed the latest Apollolake version package on my Synology DS218+. I understand that there is no domoticz.sh in Synology but on the Pi I could change the Loglevel there in order to get only status or error messages. Where can I do this in the Synology package? (could not find it in the start-stop-status file).
Right file to edit.. but you need to add it to the startline ;)
Go to /var/packages/domoticz/scripts
edit start-stop-status
like this:
su ${USER} -c "${DOMOTICZ} -www ${PORT} -wwwroot ${WWWROOT} -loglevel 1 -sslwww ${RSSLPORT} -sslcert ${RSSLCERT} -approot ${INSTALL_DIR}/ userdata ${INSTALL_DIR}/var/ -dbase ${DB_FILE} &> $LOGFILE & echo \$! > ${PID_FILE}"
You'll need to add this with every update.
MaM100
Post by MaM100 »
jumbotroll wrote: Tuesday 14 November 2017 20:09
Jumper3126 wrote: Tuesday 14 November 2017 19:36 Just bought a DS218play. Its not on the list yet. Can I install another package, or have to wait till it is released?
Hi.
I have compiled domoticz for DS218play.
You have to use the arch-rtd1296 version.
I have also added this version in the stable version list now.
DS218play= arch-rtd1292
Hi, i also bought a ds218play. I can't find the Domoticz package you mention.
When i select ds218play at 'Domoticz Stable V3.8153 for DSM 6.1' (same for version with python), I can only download MyDomoAtHome v0.2.36 and no option to download domoticz. Am I doing something wrong?
jumbotroll
MaM100 wrote: Tuesday 02 January 2018 8:10
Sorry, but I deleted the stable version because of a driver bug.
Compiled new version for you with fixed driver here:
http://www.jadahl.com/domoticz_stable_6.1/?arch=rtd1296
Beta:
http://www.jadahl.com/domoticz_beta_6.1 ... 8797-7.spk
Manual download and install.
Jumbotroll
