Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
waow29
Hi Madgeni,
I register on Controlicz, my email start marc.l
Could you add me?
Could you add me?
- gijsje
- Domoticz version: Stable
i did add 2 new switches for the Christmas tree and i did change the icon in domoticz to the Christmas tree.
If you change the icon it shows it like this in home
You can ask google to turn them on individual and that works but if you put them in a room in home they will not work
If you change the icon back the normal light bulb in domoticz they show up like this
Then you can put them in a room and they will work as a group
So i made a room called Christmas and that works.
Maybe have a look at this issue
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
I got it working now, thanks! But also have a problem with some thermostats in a particular room. I can get the status and temperature from other devices, but for these it wil say "Unable to reach TV room stat". How can I debug this message?
- gijsje
Also a strange thing is if you ask for the outside temperature it will tell you it is 6.6°C and the garden is off
How can it be off??
How can it be off??
markjgabb
- Domoticz version: 3.8153
i noticed this too..it always tells me that the temp sensor is off...i figured it was just reporting on the state as known by domoticz.....
+1 for an awesome product....absolutely love whats been done and cant believe how well it intergrates so easily...ill definatly be giving tangible support for this product
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
Madgeni
Hi there -
Email addresses and domains must be associated with an active Google Account or Google Apps account
Madgeni
*sigh* it isn't. Honestly i've no idea how it's getting that state - i pass back 'on', but it has decided that it's 'off'. I'll add it to my list to look at.gijsje wrote: Tuesday 05 December 2017 22:33 Also a strange thing is if you ask for the outside temperature it will tell you it is 6.6°C and the garden is off
How can it be off??
Madgeni
Yeah a common theme is that Domoticz allows for a large amount of customisation, but Alexa and Google don't, so I have to find ways of deciding what's a light, what's a switch, when they both have Type of Light and Subtype of light. I decided on the image - if it's a bulb, it's a light. if it isn't a bulb, well..you can work that outgijsje wrote: Tuesday 05 December 2017 22:08 i did add 2 new switches for the Christmas tree and i did change the icon in domoticz to the Christmas tree.
FCJean
- Domoticz version: 3.7649
Hi Madgeni,
I have just registered on Controlicz, my email starts with fcjean7...
Could you please add me?
Thanks a lot
Thanks a lot
quirk
Hi Madgeni,
I just registered on Controlicz, my email start david.leb*****@gmail.com
Can you add me?
Thanks a lot!
David
Can you add me?
Thanks a lot!
David
Madgeni
All done
planetf1
Thanks for me setting up. I registered my google email on controlicz, setup port forwarding etc, have a new user, and have run through the google beta test setup.
When I go into add devices, I see [test] Home Controlicz. If I click I get prompted for user/pass , to accept, then user/pass. After doing this I just get 'something went wrong' . How do I debug?
Madgeni
can you double check your domoticz username/password?
weirdly, i can see controlicz is getting a http 503 error, which usually means the Domoticz service is not available - have you done any whitelisting/blacklisting on a firewall?
planetf1
I can do 'telnet A.B.C 10443' and connect
I can browse to https://A.B.C.D:10443 and get into domoticz - though without userid/password... looking at that now....
(I'm using a non-standard port to not clash with other https stuff I may expose)
Madgeni
non-standard is fine
fergalom
Could I get added also?
fer****m at gmail
fer****m at gmail
mikejclark
Hi Madgeni
If I query my lounge temperature it returns a different number to that shown in Domoticz. It seems no matter what the temperature is in Domoticz, Google home returns 17.5. Any idea what's happening?
Sent from my GT-I9505 using Tapatalk
Madgeni
ok, that's weird!
if you use this - https://yourhost:port/json.htm?type=devices&rid=IDXOFLOUNGETEMPERATURE - what does 'temp' say?
mikejclark
{ "ActTime" : 1512748152, "ServerTime" : "2017-12-08 15:49:12", "Sunrise" : "08:05", "Sunset" : "15:53", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "17.8 C, 56 %", "Description" : "", "DewPoint" : "8.90", "Favorite" : 1, "HardwareID" : 4, "HardwareName" : "Virtual Switch", "HardwareType" : "Dummy (Does nothing, use for virtual switches only)", "HardwareTypeVal" : 15, "HaveTimeout" : false, "Humidity" : 56, "HumidityStatus" : "Comfortable", "ID" : "140EA", "LastUpdate" : "2017-12-08 15:48:57", "Name" : "Lounge Temperature", "Notifications" : "false", "PlanID" : "2", "PlanIDs" : [ 2 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "THGN122/123, THGN132, THGR122/228/238/268", "Temp" : 17.800000000000001, "Timers" : "false", "Type" : "Temp + Humidity", "TypeImg" : "temperature", "Unit" : 1, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "154" } ], "status" : "OK", "title" : "Devices" }Madgeni wrote:ok, that's weird!
It's now changed to 18. Is it rounding up?
Lyrex
Hey Madgeni,
can you leave a message if your selector switch impelentation is finished? Im happy to try it out!
