Not sure as you can leave the web page open and that updates itself as it goes
Read British Gas Hive Heating temperature
Calzor Suzay
- Target OS: -
- Domoticz version: 4.9700
Re: Read British Gas Hive Heating temperature
Every five minutes is good for me as I just use it as a reporting tool, making it a continuous feed would obviously benefit people who want to act upon it via Domoticz. The only thing I can think might be an issue would BGas feel their servers are being spammed and limit connections over time.
Calzor Suzay
- Target OS: -
I can see the logic in the code but I still get the 0° blips so not sure how it's getting them.MikeF wrote:I guess you could do something like:Haven't tried it though.Code: Select all
if [ $temp != "0" ]; then domoTemp=$(curl -s "http://<DOMO IP:PORT>/json.htm?type=command¶m=udevice&nvalue=0&idx=<IDX>&svalue=${temp}") fi
aturi83
Hi just installed this into my new setup. When running the python script i get the following error:
I think some of the URL's have changed from the original ones posted. Any tips on where to start? I have Hive mk2 (the shiny one!)
File "/home/pi/domoticz/scripts/hive2domo.py", line 70, in <module>
makeRequest(url,payload)
File "/home/pi/domoticz/scripts/hive2domo.py", line 41, in makeRequest
print e.code
AttributeError: 'URLError' object has no attribute 'code'-
MikeF
- Domoticz version: V2022.2
Yep, Hive API / URLs changed a while back.
Try this (replace <XXXX>'s with your values):
- Spoiler: show
aturi83
I must have some kind of bash config problem. Added the configs into it and now have:MikeF wrote: Tuesday 07 November 2017 23:42 Yep, Hive API / URLs changed a while back.
-bash: $'\nPython script to send data from Hive to Domoticz.\n\nReplace XXXs with your values.\n': command not found
-bash: import: command not found
-bash: insideIdx: command not found
-bash: targetIdx: command not found
-bash: thermIdx: command not found
-bash: heatingIdx: command not found
-bash: DomoReadURL: command not found
-bash: DomoWriteURL: command not found
-bash: DomoSwitchURL: command not found
-bash: hive.bash: line 25: syntax error near unexpected token `def'
-bash: hive.bash: line 25: `def domoticzread(idx, var):''
aturi83
Ok after working through some things - had to install module "requests" I now have the following error
File "./hive.sh", line 58, in <module>
temp = r.json()["nodes"][2]["attributes"]["temperature"]["reportedValue"]
KeyError: 'temperature'
MikeF
Hi @aturi83,
The problem with this script is that I never worked out how to detect which node corresponds to the Hive receiver. For me, it's node 2, but it depends on what else is on your Hive system.
In the 3 lines following '# get values from Hive', try changing the number [2] (e.g., to [1] or [3]) - it's a little bit hit and miss, I'm afraid.
aturi83
Took a few attempts but managed to track down the correct ID. Dont make it easy this stuff do they...
A new set of error messages at the end. However got lots more data now, including schedule, frost protection temp settings etc.
File "./hive.sh", line 71, in <module>
last_temp = domoticzread(insideIdx, 'Temp')
File "./hive.sh", line 28, in domoticzread
jsonData = json.loads(response.text)
File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
MikeF
I think the problem here may be that you have not set up dummy devices in Domoticz to receive the values from this script - see lines 13 to 16. The first two are temperature devices, the third is a thermostat / setpoint, and the last is an on/off switch. (I may have mentioned this originally - it was a while ago when I first published this script.)
aturi83
Setup as described, in fact i removed the dummy device and set it up from scratch.MikeF wrote: Tuesday 14 November 2017 19:59 I think the problem here may be that you have not set up dummy devices in Domoticz to receive the values from this script - see lines 13 to 16. The first two are temperature devices, the third is a thermostat / setpoint, and the last is an on/off switch. (I may have mentioned this originally - it was a while ago when I first published this script.)
The data above the error is correct
"targetHeatTemperature": {
"targetExpiryTime": 1510697424984,
"reportReceivedTime": 1510698605897,
"propertyStatus": "COMPLETE",
"targetSetTXId": "e56e60fa-0d45-4c52-9f76-7029377109ae",
"reportedValue": 11.5,
"targetSetTime": 1510697124984,
"displayValue": 11.5,
"targetValue": 11.5,
"reportChangedTime": 1510697125488
"minHeatTemperature": {
"displayValue": 5.0,
"reportChangedTime": 1508372857836,
"reportedValue": 5.0
"holidayMode": {
"displayValue": {
"targetHeatTemperature": 1.0
"reportChangedTime": 1509790193862,
"reportedValue": {
"failureStatus": {
"displayValue": "NORMAL",
"reportChangedTime": 1509633035417,
"reportedValue": "NORMAL"
"nodeType": {
"displayValue": "http://alertme.com/schema/json/node.class.thermostat.json#",
"reportReceivedTime": 1510699203908,
"reportChangedTime": 1508372853584,
"reportedValue": "http://alertme.com/schema/json/node.class.thermostat.json#"
"activeScheduleLock": {
"targetExpiryTime": 1510605381449,
"targetSetTXId": "7cbb4270-0380-4963-b7ed-2fdef9de06ea",
"reportedValue": true,
"targetSetTime": 1510605081449,
"displayValue": true,
"targetValue": true,
"reportChangedTime": 1510656121698
"activeHeatCoolMode": {
"reportedValue": "HEAT",
"displayValue": "HEAT",
"targetValue": "BOOST",
"reportChangedTime": 1510608681517
"frostProtectTemperature": {
"displayValue": 7.0,
"reportedValue": 7.0
imcfarla
I have updated the script so that it will search for the Hive node instead of you having to guess it (mine was 8!)
#!/usr/bin/env python
Replace XXX's with your values.
import requests
import json
import sys
# Replace with your Domoticz idx's
domoHost = 'XXX'
domoPort = 'XXX'
insideIdx = 'XXX'
targetIdx = 'XXX'
thermIdx = 'XXX'
heatingIdx = 'XXX'
# Replace with your Hive credentials
hiveUser = 'XXX'
hivePass = 'XXX'
# Domoticz URL & port
DomoReadURL = 'http://'+domoHost+':'+domoPort+'/json.htm?type=devices&rid='
DomoWriteURL = 'http://'+domoHost+':'+domoPort+'/json.htm?type=command¶m=udevice&nvalue=0&idx='
DomoSwitchURL = 'http://'+domoHost+':'+domoPort+'/json.htm?type=command¶m=switchlight&idx='
requests.packages.urllib3.disable_warnings()
url = DomoReadURL + idx
response = requests.get(url)
result = jsonData['result'][0][var]
return result;
def find_key_in_list(d, value):
if isinstance(d, list):
t = list(d)
for v in d:
if isinstance(v, dict):
p = find_key(v, value)
if not p:
t.remove(v)
return t
def find_key(d, value):
for k,v in d.items():
if p:
return [k] + p
elif v == value:
return [k]
# Hive
# log on to Hive
payload = {'username':hiveUser, 'password':hivePass}
headers = {'Content-Type': 'application/json', 'Accept': 'application/json'}
url = 'https://beekeeper-uk.hivehome.com/1.0/gateway/login'
r = requests.post(url, headers=headers, data=json.dumps(payload), verify=False)
sessionId = r.json()["token"]
headers = {'Content-Type': 'application/vnd.alertme.zoo-6.2+json', 'Accept': 'application/vnd.alertme.zoo-6.2+json', \
'X-AlertMe-Client': 'swagger', 'X-Omnia-Access-Token': sessionId}
url = 'https://api.prod.bgchprod.info:443/omnia/nodes'
r = requests.get(url, headers=headers, verify=False)
# Find thermostat node
d = r.json()["nodes"]
x = find_key_in_list(d,"http://alertme.com/schema/json/node.class.thermostat.json#")
if x:
if x[0]["id"] == x[1]["parentNodeId"]:
thermostat = x[1]
elif x[1]["id"] == x[0]["parentNodeId"]:
thermostat = x[0]
else:
print("No thermostat found")
thermostat = False
if thermostat:
temp = thermostat["attributes"]["temperature"]["reportedValue"]
targetTemp = thermostat["attributes"]["targetHeatTemperature"]["reportedValue"]
heating = thermostat["attributes"]["stateHeatingRelay"]["reportedValue"]
# log out from Hive
headers = {'Content-Type': 'application/vnd.alertme.zoo-6.1+json', 'Accept': 'application/vnd.alertme.zoo-6.2+json', \
'X-AlertMe-Client': 'Hive Web Dashboard', 'X-Omnia-Access-Token': sessionId}
url = 'https://api.prod.bgchprod.info:443/omnia/auth/sessions/' + sessionId
r = requests.delete(url, headers=headers, verify=False)
if not thermostat:
sys.exit() # Quit if there is no thermostat found
# Domoticz
# get last values from Domoticz
last_target = domoticzread(targetIdx, 'Temp')
last_heating = domoticzread(heatingIdx, 'Status')
# change some values
temp = round(temp, 1)
if targetTemp < 7.0: targetTemp = 7.0
if heating == "ON":
heating="On"
else:
heating="Off"
print 'new','old'
print temp, last_temp
print targetTemp, last_target
print heating, last_heating
# send values to Domoticz (only send some if changed)
url = DomoWriteURL + insideIdx + '&svalue=' + str(temp)
r = requests.get(url)
url = DomoWriteURL + targetIdx + '&svalue=' + str(targetTemp)
if targetTemp != last_target:
url = DomoWriteURL + thermIdx + '&svalue=' + str(targetTemp)
if heating != last_heating:
url = DomoSwitchURL + heatingIdx + '&switchcmd=' + heating
MikeF
Hi imcfarla,
Thanks for this - I never got round to it!
However, it's not working for me, as I get 'NameError: name 'thermostat' is not defined'. This because neither of these tests is true:
x[0]["parentNodeId"] and x[1]["parentNodeId"] have the same value; x[0]["id"] & x[1]["id"] are different.
Any ideas?
thermostat = x[1]
thermostat = x[0]Any ideas?
imcfarla
No - can you send me the json data?
I have 2 thermostat devices listed in the json, one of which is the child and that one has the temperatures.
I have spent tonight adding lights into the script
I have only got the simple dimmable ones so that is all that is catered for
To use it just add a new virtual device of type switch to the dummy hardware. Then go to the switches page and edit the new switch and change the type to dimmer.
WIP:
I have also tried to send throught the battery and signal state if the thermostat but it does not show in my devices list
WIP:
import requests
import json
import sys
domoHost = 'XXX'
domoPort = 'XXX'
insideIdx = 'XXX'
targetIdx = 'XXX'
thermIdx = 'XXX'
heatingIdx = 'XXX'
# Dictionary of on/off light names and idx's don't include dimmers
lights = {}
# Dictionary of dimmable light names and idx's
# e.g. dimmers = {"Bedroom":5,"Porch":6,"Stairwell":7}
dimmers = {}
hiveUser = 'XXX'
hivePass = 'XXX'
return result;
t = list(d)
for v in d:
if not p:
t.remove(v)
return t
if p:
return [k] + p
elif v == value:
return [k]
def merge_dicts(*dict_args):
Given any number of dicts, shallow copy and merge into a new dict,
precedence goes to key value pairs in latter dicts.
result = {}
for dictionary in dict_args:
result.update(dictionary)
return result
# Hive
# log on to Hive
if x:
thermostat = x[1]
thermostat = x[0]
else:
thermostat = False
if thermostat:
x = find_key_in_list(d,"http://alertme.com/schema/json/node.class.thermostatui.json#")
if x:
battery = x[0]["attributes"]["batteryLevel"]["reportedValue"]
rawRssi = 0-x[0]["attributes"]["RSSI"]["reportedValue"]
rssi = 12*rawRssi/100
state = {}
brightness = {}
x = find_key_in_list(d,"http://alertme.com/schema/json/node.class.light.json#")
if x:
for l in x:
# On/Off
try:
idx = merge_dicts(lights, dimmers)[l["name"]]
except:
idx = False
if idx:
state[idx] = "O" + l["attributes"]["state"]["reportedValue"][1:3].lower()
# Brightness
try:
idx = dimmers[l["name"]]
except:
idx = False
if idx:
if state[idx] == "Off":
brightness[idx] = 0
else:
brightness[idx] = l["attributes"]["brightness"]["reportedValue"]
else:
print("No lights found")
# log out from Hive
if not thermostat:
#sys.exit()
# Domoticz
if heating == "ON":
heating="On"
else:
heating="Off"
print 'new','old'
print 'battery: ' + str(battery)
print 'rssi: ' + str(rssi)
print state
print brightness
url = DomoWriteURL + thermIdx + '&svalue=' + str(targetTemp) + '&battery=' + str(battery) + '&rssi=' + str(rssi)
print url
for k,v in brightness.items():
url = DomoSwitchURL + str(k) + '&switchcmd=Set%20Level&level=' + str(v)
for k,v in state.items():
url = DomoSwitchURL + str(k) + '&switchcmd=' + v
MikeF
OK, solved my earlier 'problem'
- I also have 2 thermostat devices listed in the json, but these both have id's which are different to both of the parentNodeId's.
Instead, I look in 'attributes' for a key which I know is only in the child device (the one that has the temperatures) - in this case, 'stateHeatingRelay':
(and remove ["attributes"] in the subsequent lines).
Works for me!
if x:
z = x[1]["attributes"]
k = "stateHeatingRelay"
if k in y:
thermostat = y
elif k in z:
thermostat = z
else:
thermostat = False
Works for me!
MikeF
In my system, these can be found under ["nodes"][1] - where "name" = "Hive2".imcfarla wrote: Monday 04 December 2017 23:53 I have also tried to send through the battery and signal state of the thermostat but it does not show in my devices list
I can get the values using this:
x = find_key_in_list(d,"Hive2")
if x:
print x[0]["attributes"]["batteryVoltage"]["reportedValue"]
print x[0]["attributes"]["RSSI"]["reportedValue"]
imcfarla
Ok change in tack...
I now have a proper plugin that detects (thermostat only) and adds all the devices for you!
place this code in a folder called plugin.py in a folder called Hive in the plugins directory in your domoticz folder.
i.e.
.../domoticz/plugins/Hive/plugin.py
restart domoticz <- important otherwise the plugin will not be detected.
Then go to setup and you should be able to choose Hive plugin in the Type dropdown.
Add your Hive username and password and click Add at the bottom.
i.e.
<plugin key="HivePlug" name="Hive Plugin" author="imcfarla and mikef" version="0.1" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://www.google.com/">
<params>
<param field="Username" label="Hive Username" width="200px" required="true" default=""/>
<param field="Password" label="Hive Password" width="200px" required="true" default=""/>
<param field="Mode1" label="Heartbeat Multiplier" width="30px" required="true" default="6"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
import sys
import json
sys.path.append('/usr/lib/python3/dist-packages')
from urllib.request import Request, urlopen
from urllib.parse import urlencode
t = list(d)
for v in d:
if not p:
t.remove(v)
return t
for (k, v) in d.items():
if p:
return [k] + p
elif v == value:
return [k]
result = { }
return result
class BasePlugin:
enabled = False
def __init__(self):
self.sessionId = ''
self.counter = 0
self.multiplier = 10
def onStart(self):
Domoticz.Log('Staring')
if Parameters["Mode6"] == "Debug":
Domoticz.Debugging(1)
self.multiplier = int(Parameters['Mode1'])
self.counter = self.multiplier #update immediately
if self.sessionId == '':
Domoticz.Debug('Creating Session')
payload = {'username':Parameters["Username"], 'password':Parameters["Password"]}
print(urlencode(payload).encode('ascii'))
req = Request(url, data = json.dumps(payload).encode('ascii'), headers = headers, unverifiable = True)
r = urlopen(req).read().decode('utf-8')
self.sessionId = json.loads(r)['token']
Domoticz.Debug(self.sessionId)
d = self.GetDevices()
thermostat = self.GetThermostat(d)
if len(Devices) == 0:
Domoticz.Log('Creating Devices')
if thermostat:
Domoticz.Device(Name = 'Thermostat', Unit = 1, Type = 242, Subtype = 1, DeviceID = thermostat['id']).Create()
Domoticz.Device(Name = 'Heating', Unit = 2, TypeName = 'Switch', Switchtype = 0, DeviceID ='Hive_Heating').Create()
Domoticz.Device(Name = 'Inside', Unit = 3, TypeName = 'Temperature', DeviceID = 'Hive_Inside').Create()
Domoticz.Device(Name = 'Target', Unit = 6, TypeName = 'Temperature', DeviceID = 'Hive_Target').Create()
else:
Domoticz.Log(str(len(Devices)) + ' Devices')
for unit in Devices:
Domoticz.Debug(Devices[unit].Name)
def onStop(self):
Domoticz.Log('Stop')
'X-AlertMe-Client': 'Hive Web Dashboard', 'X-Omnia-Access-Token': self.sessionId }
url = 'https://api.prod.bgchprod.info:443/omnia/auth/sessions/' + self.sessionId
req = Request(url, headers = headers)
req.get_method = lambda : 'PUT'
try:
except Exception as e:
Domoticz.Debug(str(e))
def onConnect(self, Connection, Status, Description):
Domoticz.Debug('onConnect called')
def onMessage(self, Connection, Data, Status, Extra):
Domoticz.Debug('onMessage called')
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Debug('onCommand called for Unit ' + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Debug('Notification: ' + Name + ',' + Subject + ',' + Text + ',' + Status + ',' + str(Priority) + ',' + Sound + ',' + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Debug('onDisconnect called')
def onHeartbeat(self):
Domoticz.Debug('onHeartbeat called')
if self.counter >= self.multiplier:
Domoticz.Log('Getting Data')
self.counter = 0
Domoticz.Debug('Getting Temperatures')
# get the temperature and heating states
Domoticz.Debug('Temp = ' + str(temp))
Domoticz.Debug('Target = ' + str(targetTemp))
Domoticz.Debug('Heating = ' + heating)
Domoticz.Debug('Getting Battery Status')
thermostatui = self.GetThermostatUI(d)
# get the battery and rssi values
thermostat_battery = thermostatui["attributes"]["batteryLevel"]["reportedValue"]
Domoticz.Debug('Battery = ' + str(thermostat_battery))
thermostat_rssi = 12*((0 - thermostatui["attributes"]["RSSI"]["reportedValue"])/100)
Domoticz.Debug('RSSI = ' + str(thermostat_rssi))
# Loop through the devices and update temperatures
Domoticz.Debug('Updating Devices')
if Devices[unit].DeviceID == "Hive_Inside":
Devices[unit].Update(nValue=int(temp), sValue=str(temp))
if Devices[unit].DeviceID == "Hive_Target":
Devices[unit].Update(nValue=int(targetTemp), sValue=str(targetTemp))
if Devices[unit].DeviceID == "Hive_Heating":
if heating == 'ON':
if Devices[unit].nValue == 0:
Devices[unit].Update(nValue=1, sValue='On')
else:
if Devices[unit].nValue == 1:
Devices[unit].Update(nValue=0, sValue='Off')
# Loop through the devices from Hive and update statuses where appropriate
Domoticz.Debug('Checking Nodes')
for node in d:
#Domoticz.Debug('Node = ' + node['id'])
for unit in Devices.keys():
#Domoticz.Debug('Unit ' + str(unit))
#Domoticz.Debug('Device ' + Devices[unit].DeviceID)
if node['id'] == Devices[unit].DeviceID:
Domoticz.Debug('Found ' + Devices[unit].Name)
if Devices[unit].Type == 242: #Thermostat
Devices[unit].Update(nValue = int(targetTemp), sValue = str(targetTemp), BatteryLevel = int(thermostat_battery), SignalLevel = int(thermostat_rssi))
else:
self.counter += 1
Domoticz.Debug('Counter = ' + str(self.counter))
def GetDevices(self):
'X-AlertMe-Client': 'swagger', 'X-Omnia-Access-Token': self.sessionId}
req = Request(url, headers = headers, unverifiable = True)
try:
except Exception:
print('Exception')
return json.loads(r)['nodes']
def GetThermostat(self, d):
x = find_key_in_list(d, 'http://alertme.com/schema/json/node.class.thermostat.json#')
if x:
k = 'stateHeatingRelay'
if k in x[0]['attributes']:
thermostat = x[0]
elif k in x[1]['attributes']:
thermostat = x[1]
else:
thermostat = False
else:
thermostat = False
return thermostat
def GetThermostatUI(self, d):
thermostatui = False
x = find_key_in_list(d, 'http://alertme.com/schema/json/node.class.thermostatui.json#')
if x:
thermostatui = x[0]
else: # Try a Hive2 thermostat
if x:
thermostatui = x[0]
return thermostatui
_plugin = BasePlugin()
def onStart():
_plugin.onStart()
def onStop():
_plugin.onStop()
def onConnect(Connection, Status, Description):
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data, Status, Extra):
_plugin.onMessage(Connection, Data, Status, Extra)
def onCommand(Unit, Command, Level, Hue):
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
_plugin.onDisconnect(Connection)
def onHeartbeat():
_plugin.onHeartbeat()
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != '':
Domoticz.Debug("'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug('Device count: ' + str(len(Devices)))
for x in Devices:
Domoticz.Debug('Device: ' + str(x) + ' - ' + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug('Device nValue: ' + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug('Device LastLevel: ' + str(Devices[x].LastLevel))
sach
Nice work.....looking forward to trying this out.
imcfarla
Added in lights, plugs and control of the devices. Setting the temperature in Domoticz now updates Hive.
A side effect is that you can now set a light to be any percentage rather than just a multiple of 5 - wake up light here we come...
Note:
Only works for Active Light Dimmable as I haven't got any Cool to Warm or Colour Changing
ActivePlug should work but again I haven't got any so I can't test.
The Heartbeat multiplier defines how many heartbeats before it processes the data from Hive - I started off with 6 (60s) as the default but now I have added in control this really should just be 1 (10s) otherwise you wait too long before the dashboard updates to say you have switched on a light.
Same instructions apply:
i.e.
Note:
i.e.
<plugin key="HivePlug" name="Hive Plugin" author="imcfarla and mikef" version="0.2" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://www.google.com/">
<params>
<param field="Mode1" label="Heartbeat Multiplier" width="30px" required="true" default="1"/>
<options>
</options>
</param>
</params>
</plugin>
import Domoticz
import sys
import json
t = list(d)
for v in d:
if not p:
t.remove(v)
return t
if p:
return [k] + p
elif v == value:
return [k]
result = { }
return result
class BasePlugin:
enabled = False
def __init__(self):
self.sessionId = ''
self.counter = 0
self.lightsSet = set()
def onStart(self):
Domoticz.Log('Starting')
Domoticz.Log('Creating Session')
def onStop(self):
Domoticz.Log('Deleting Session')
req.get_method = lambda : 'DELETE'
try:
Domoticz.Log(str(e))
Domoticz.Log('onCommand called for Unit ' + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
Domoticz.Debug(str(Devices[Unit].Type))
Domoticz.Debug(str(Devices[Unit].SubType))
Domoticz.Debug(Devices[Unit].DeviceID)
Domoticz.Debug(str(Devices[Unit].sValue))
url = 'https://api.prod.bgchprod.info:443/omnia/nodes/' + Devices[Unit].DeviceID
if self.isLight(Unit):
Domoticz.Log("Setting Light Parameters")
if str(Command) == "Set Level":
payload = self.CreateLightPayload("ON", Level)
if str(Command) == "On":
payload = self.CreateLightPayload("ON", Devices[Unit].LastLevel)
if str(Command) == "Off":
payload = self.CreateLightPayload("OFF", Devices[Unit].LastLevel)
elif self.isThermostat(Unit):
payload = self.CreateThermostatPayload(Level)
elif self.isActivePlug(Unit):
payload = self.CreateActivePlugPayload(Level)
else:
payload = ""
Domoticz.Log("Unknown Device Type")
if payload != "":
try:
foundInsideDevice = False
foundTargetDevice = False
foundHeatingDevice = False
foundThermostatDevice = False
Domoticz.Debug('Getting Data')
self.counter = 1
if thermostat:
foundInsideDevice = True
foundTargetDevice = True
foundHeatingDevice = True
if heating == 'ON':
else:
if Devices[unit].DeviceID == thermostat['id']:
foundThermostatDevice = True
if foundInsideDevice == False:
Domoticz.Device(Name = 'Inside', Unit = self.GetNextUnit(False), TypeName = 'Temperature', DeviceID = 'Hive_Inside').Create()
if foundTargetDevice == False:
Domoticz.Device(Name = 'Target', Unit = self.GetNextUnit(False), TypeName = 'Temperature', DeviceID = 'Hive_Target').Create()
if foundHeatingDevice == False:
Domoticz.Device(Name = 'Heating', Unit = self.GetNextUnit(False), TypeName = 'Switch', Switchtype = 0, DeviceID ='Hive_Heating').Create()
if foundThermostatDevice == False:
Domoticz.Device(Name = 'Thermostat', Unit = self.GetNextUnit(False), Type = 242, Subtype = 1, DeviceID = thermostat['id']).Create()
lights = self.GetLights(d)
if lights:
for node in lights:
if unit not in set(self.lightsSet):
self.lightsSet.add(unit)
if node["attributes"]["state"]["reportedValue"] == "OFF":
if Devices[unit].nValue != 0:
else:
Domoticz.Debug("State: " + Devices[unit].sValue)
Domoticz.Debug("Brightness Target: " + str(Devices[unit].LastLevel))
Domoticz.Debug("Brightness: " + str(node["attributes"]["brightness"]["reportedValue"]))
if Devices[unit].LastLevel != int(node["attributes"]["brightness"]["reportedValue"]) or Devices[unit].sValue == 'Off':
Devices[unit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"])) # 2 = Set Level
break
else:
Domoticz.Log("Light not found " + node["name"])
newUnit = self.GetNextUnit(False)
Domoticz.Device(Name = node["name"], Unit = newUnit, Type=244, Subtype=73, Switchtype=7, DeviceID = node['id']).Create()
Devices[newUnit].Update(nValue=0, sValue='Off')
else:
Devices[newUnit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"])) # 2 = Set Level
activeplugs = self.GetActivePlugs(d)
if activeplugs:
for node in activeplugs:
else:
if Devices[unit].nValue != 1:
break
else:
Domoticz.Log("ActivePlug not found " + node["name"])
Domoticz.Device(Name = node["name"], Unit = newUnit, Type=244, Subtype=73, Switchtype=0, DeviceID = node['id']).Create()
else:
else:
self.counter += 1
try:
if x:
thermostat = x[0]
thermostat = x[1]
else:
thermostat = False
else:
thermostat = False
return thermostat
if x:
thermostatui = x[0]
if x:
thermostatui = x[0]
return thermostatui
def GetLights(self, d):
lights = False
if x:
lights = x
return lights
def GetActivePlugs(self, d):
plugs = False
x = find_key_in_list(d,"http://alertme.com/schema/json/node.class.smartplug.json#")
if x:
lights = x
return plugs
def GetNextUnit(self, unit):
if not unit:
nextUnit = len(Devices) + 1
else:
nextUnit = unit +1
if nextUnit in Devices or nextUnit <= 1:
nextUnit = self.GetNextUnit(nextUnit)
return nextUnit
def CreateLightPayload(self, State, Brightness):
response = {}
nodes = []
attributes = {}
state = {}
brightness = {}
brightness["targetValue"] = Brightness
state["targetValue"] = State
attributes["attributes"] = {"brightness":brightness,"state":state}
nodes.append(attributes)
response["nodes"] = nodes
return response
def CreateThermostatPayload(self, Temperature):
response = {}
nodes = []
attributes = {}
targetHeatTemperature = {}
targetHeatTemperature["targetValue"] = Temperature
attributes["attributes"] = {"targetHeatTemperature":targetHeatTemperature}
return response
def CreateActivePlugPayload(self, State):
response = {}
nodes = []
attributes = {}
state = {}
attributes["attributes"] = {"state":state}
return response
def isLight(self, Unit):
Domoticz.Debug(str(self.lightsSet))
if Devices[Unit].Type == 244 and Devices[Unit].SubType == 73 and Unit in self.lightsSet:
return True
else:
return False
def isThermostat(self, Unit):
if Devices[Unit].Type == 242:
return True
else:
return False
def isActivePlug(self, Unit):
if Devices[Unit].Type == 244 and Devices[Unit].SubType == 73 and Unit not in self.lightsSet and Devices[Unit].DeviceID != "Hive_Heating":
return True
else:
return False
def onStart():
_plugin.onStart()
def onStop():
_plugin.onStop()
def onHeartbeat():
for x in Devices:
sach
Just got some bulbs in last week. Should hopefully have some time tomorrow to try this out.
sach
This is brilliant.....works great for heating. Not had a chance to try lights just yet.
You should get this added to the Python Plugins list and maybe setup a separate thread for it.
With Hive launching in Europe soon I'm sure it's going to get popular.
Excellent work sir!
Excellent work sir!
