I am interested in installing light switches.
Is Funry has support RFLink.
I know that Livolo works, but they also look very good and are much cheaper.
For example, such a set, with remote control, two-way, less than 20usd such a set, with remote control, two-way, less than 20usd
Has anyone tested?
Best
gebir
FUNRY Home Touch Switch - support
Re: FUNRY Home Touch Switch - support
I don't know if it will work with RFLink, but it works with RFXcom + Domoticz. The switch has to be manually added as Switch Type "IT" and paired.
HINT: If you want to be able to switch it to ON or OFF state (instead of just toggle), you have to pair it for ON (two beeps) when you add it as Blinds Inverted. Then, after you already have the blinds switch added to Domoticz, enter the pairing mode again for OFF function (three beeps) and press the Off button of the blinds switch in Domoticz. Now you can change the switch type to On/Off and the icon to Light/Switch.
I just ordered one including remote for < 10$ at Geekbuying. I'll check if I can get it to work with RFLink.
- Domoticz version: Beta Ch
you wont get any feedback from that switch. I suggest you use few $ more to buy wifi sonoff
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
there is also 433mhz+wifi sonoff available, if it updates its state, that i do not know
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
