FUNRY Home Touch Switch - support
Gebir
Post by Gebir »
I am interested in installing light switches.
Is Funry has support RFLink.
I know that Livolo works, but they also look very good and are much cheaper.
For example, such a set, with remote control, two-way, less than 20usd such a set, with remote control, two-way, less than 20usd
Has anyone tested?
Best
gebir
mitkodotcom
Re: FUNRY Home Touch Switch - support
Post by mitkodotcom »
I don't know if it will work with RFLink, but it works with RFXcom + Domoticz. The switch has to be manually added as Switch Type "IT" and paired.
HINT: If you want to be able to switch it to ON or OFF state (instead of just toggle), you have to pair it for ON (two beeps) when you add it as Blinds Inverted. Then, after you already have the blinds switch added to Domoticz, enter the pairing mode again for OFF function (three beeps) and press the Off button of the blinds switch in Domoticz. Now you can change the switch type to On/Off and the icon to Light/Switch.
Hesmink
Post by Hesmink »
I just ordered one including remote for < 10$ at Geekbuying. I'll check if I can get it to work with RFLink.
Hesmink
Post by Hesmink »
Hesmink wrote: Saturday 28 October 2017 13:06 I just ordered one including remote for < 10$ at Geekbuying. I'll check if I can get it to work with RFLink.
Works out of the box with RFLink, the remote is detected as EV1527.
tontze
Domoticz version: Beta Ch
Post by tontze »
you wont get any feedback from that switch. I suggest you use few $ more to buy wifi sonoff :)
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Hesmink
Post by Hesmink »
tontze wrote: Sunday 03 December 2017 16:53 you wont get any feedback from that switch. I suggest you use few $ more to buy wifi sonoff :)
True, but it's really cheap and looks nice.
If you have a RFLink/RFXCom, it's just like any other remote controlled lamp.
tontze
Post by tontze »
there is also 433mhz+wifi sonoff available, if it updates its state, that i do not know :)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
