Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
Chakkie
Re: Controlicz - Easy Domoticz to Alexa Integration
Post by Chakkie »
Little progress
The temperature sensor is now recognized as thermostat. Alexa responsed with ....does not support that when ask about the temperature
sach
Post by sach »
It's almost working perfectly for me now. Can see both temps and setpoint of my sensor and thermostat via the app. Can query the current temp and setpoint perfectly via voice. Only small thing is when I ask to change setpoint or change via the app it comes up with an error but it works regardless....so not a major.
Madgeni
Post by Madgeni »
hey Sach - working on that right now :) 'WFH' tomorrow, so will nail it.
Hi Chakkie - yep, sorry, sensors are a pain for me, I don't have any, so coding blind :)
sach
Post by sach »
Sounds like a great way for you to receive donations of smart home gear from people so you can get their hardware working. ;)
Scoobydoo
Post by Scoobydoo »
Sorry for the late reply I've been out all day.
Just tried and the temperature is working fine on my system now, the fix you've applied today has certainly worked for me.
Thanks for all the hard work.
Awesome job.
Madgeni
Post by Madgeni »
sach wrote: Thursday 30 November 2017 21:46 Sounds like a great way for you to receive donations of smart home gear from people so you can get their hardware working. ;)
Mrs Madgeni would not be impressed :)
Calzor Suzay
Domoticz version: 4.9700
Post by Calzor Suzay »
Madgeni wrote: Wednesday 29 November 2017 20:50 Hi and welcome :)
So you just need Room plans (at least one), you don't need floor plans. The reason Controlicz uses domoticz Room Plans is just to allow you to filter which devices Alexa sees (I copied this from the HA bridge at someone's request).
Controlicz should know lights are lights, so you should be good. To turn off lights by 'room' in Alexa, I think the best option is to set up Routines in the alexa app.
You can also control the name of the light in Alexa by adding - Controlicz: <nameyouwantalexatouse> in the Domoticz description field.
Thanks I'll have a play :)
SHadley1138
Post by SHadley1138 »
This may have been answered already, but can Alexa/controlicz give feed back on power consumption the is presented in domoticz
For example
“Alexa, how much electricity am I using?”
“Alexa, how much solar power am I generating?”
freijn
Domoticz version: Stable
Post by freijn »
So much to Whish for !!
Power usage is really On my whishlist as well but
Would really like to read /speak the content of a text item too.... ( General text ) :-)
RedRaven
Post by RedRaven »
I have a question or perhaps a feature request.
My ISP does not provide me with a publicly reachable IP so I use my.domoticz.com for managing my Domoticz. Though currently I am using HA Bridge, I would definitely want to switch to Controlicz but since my Domoticz instance is not directly reachable how do I do it?
Is there a way you guys can recommend or something that can be done?
freijn
Post by freijn »
@Madgeni
I am having troubles with the commands of Alexa. Am I the only one??
Switchinh ON/OFF Alexa replies with "OK" but nothing happens and nothing to see in the log's
Asking Temperature Alexa replies that Temp is not possible for device bla bla.
Anything i can check on my end???
Cheers,
Frank
dgilbert2
Domoticz version: 2024.7
Post by dgilbert2 »
@freijn
I'm having the same issues as you since last night also. Alexa says "OK" but Domoticz is not changing.
Madgeni
Post by Madgeni »
Hi there - can you disable and re-enable the skill? I think Amazon have had some issue with handling tokens, not sure it's refreshing them
dgilbert2
Post by dgilbert2 »
Will try this when I get home this evening, thanks.
Alcloud
Post by Alcloud »
Madgeni wrote: Monday 04 December 2017 9:16 Hi there - can you disable and re-enable the skill? I think Amazon have had some issue with handling tokens, not sure it's refreshing them
yes, it works!
Scoobydoo
Post by Scoobydoo »
I can confirm this works. Thanks.
Had to disable and then re enable the skill last night to get the skill working again.
freijn
Post by freijn »
YESS YESS YESS success :-) Alexa behaves again :-)
Thanks Nick !
Frank
freijn
Post by freijn »
Ohhhh Nick , I bought then next Pint for you. THanks for all your work here.
Madgeni
Post by Madgeni »
Hey thanks freijn - that's really generous :D
dgilbert2
Post by dgilbert2 »
Hi, does the enable / disable delete the groups which I have setup or do they remain?
