KERUI P829 Motion sensor
iLLiac4
Post by iLLiac4 »
Just tested Kerui P829 motion sensor.
https://www.aliexpress.com/item/KERUI-P ... 26404.html
Some additional photos:
https://fccid.io/2AGNGKR-P829
It works with domoticz. It reports also with X10 and lightning4 enabled.
It sends two statuses: one Motion and if you remove the battery cover it sends Alarm + Tamper.
This is the log from manager:
7. 09. 2017 07:53:57
Packettype = Security1
subtype = X10 security
Sequence nbr = 48
id1-3 = 833B00 decimal:8600320
status = Motion
battery level = OK
Signal level = 6 -72dBm
7. 09. 2017 07:54:00
Sequence nbr = 49
status = Alarm + Tamper
battery level = OK
Signal level = 7 -64dBm
Dirk
Re: KERUI P829 Motion sensor
Post by Dirk »
Would you recommend these? I had these before https://www.intellihome.be/nl/x10-ms13- ... eugen.html but they are out of stock.
Phriso
Post by Phriso »
I have bought the same sensor but cannot detect the sensor with Domoticz
- X10 is enabled
- device detection is enabled
- Sensor is on and blinking
- latest 1022 firmware used for RFXcom
- latest 3.8153 Domoticz used
Please can you tell me how you add the sensor to Domoticz? Doing something special?
b_weijenberg
Post by b_weijenberg »
Enable also lighting4
RFX-433, RFX-433EMC, RFX-868
Phriso
Post by Phriso »
Lightning4 is also enabled.
Without any result
Phriso
Post by Phriso »
Problem is solved!
1. Use only the protocols you need. Don't enable all :-(
2. Use the latest EXT2 firmware.
After that the sensor is detected as X10 security and can be used in Domoticz.
Fleshi
Post by Fleshi »
Phriso wrote: Wednesday 29 November 2017 20:45 Problem is solved!
Question, can you tell which protocols you have selected?
b_weijenberg
With Lighting4 + X10 enabled the Kerui sensors will be decoded as X10 security sensors in Ext2 firmware.
See also chapter 2.2.2 in the RFXtrx User Guide.
