It thought that it would be better to do this in an own topic.
The problem: script for room heating is editted and works fine with old version dzventz. Then the 2.x version came intergrated in domoticz and I changed the lines that needed to be compatible for the 2.x version to work.
That part I have figured out i hope , but the temp reading has some issues i think or some code is not as it should now to work with the 2.x version.
the code
-- assumptions:
-- the setpoint is set by a selector dummy device where the values are numeric temperatures
-- but you can easily change it to a setpoint device
local BOILER_DEVICE = 'State-CV-Badkamer' -- switch device
local SETPOINT_DEVICE = 'Thermostaat Badkamer' -- selector dummy device
local TEMPERATURE_SENSOR = 'TH-Badkamer'
local HYSTERESIS = 0.1 -- temp has to drop this value below setpoint before boiler is on again
local SMOOTH_FACTOR = 3
local LOGGING = true
local OVERRIDE_SWITCH = 'CV-Badkamer-Override' -- override switch
timer = { 'every minute'},
device = { TEMPERATURE_SENSOR, SETPOINT_DEVICE}
data = {
temperatureReadings = { history = true, maxItems = SMOOTH_FACTOR }
active = true,
execute = function(domoticz, device, triggerInfo)
local avgTemp
local temperatureReadings = domoticz.data.temperatureReadings
-- first check if the sensor got a new reading or the setpoint was changed:
if (triggerInfo.type == domoticz.EVENT_TYPE_DEVICE) then
local sensor = domoticz.devices(TEMPERATURE_SENSOR)
if (sensor.changed and sensor.attributeChanged('temperature')) then
-- sensor just reported a new reading
-- add it to the readings table
local current = sensor.temperature
if (current ~= 0 and current ~= nil) then
temperatureReadings.add(current)
-- no need to be here, weird state detected
domoticz.log('Strange sensor reading.. skiping', domoticz.LOG_ERROR)
return
elseif (domoticz.devices(SETPOINT_DEVICE).changed) then
-- a new setpoint was set
if LOGGING then domoticz.log('Setpoint was set to ' .. device.state) end
-- no business here, bail out...
return
-- now determine what to do
local boiler = domoticz.devices(BOILER_DEVICE)
local setpoint = domoticz.devices(SETPOINT_DEVICE)
local override = domoticz.devices(OVERRIDE_SWITCH)
if (setpoint.state == nil or setpoint.state == 'Off') then
boiler.switchOff()
return -- we're done here
local setpointValue = tonumber(setpoint.state)
-- determine at which temperature the boiler should be
-- switched on
local switchOnTemp = setpointValue - HYSTERESIS
-- don't use the current reading but average it out over
-- the past <SMOOTH_FACTOR> readings (data smoothing) to get rid of noise, wrong readings etc
--local avgTemp = temperatureReadings.avg(1, SMOOTH_FACTOR)
local avgTemp = temperatureReadings.avg(1, SMOOTH_FACTOR, 0) -- when there's no average, return 0 (or whatever you want it to return)
if LOGGING then
domoticz.log('Average: ' .. avgTemp, domoticz.LOG_INFO)
domoticz.log('Setpoint: ' .. setpointValue, domoticz.LOG_INFO)
domoticz.log('Current boiler state: ' .. boiler.state, domoticz.LOG_INFO)
domoticz.log('Switch-on temperature: ' .. switchOnTemp, domoticz.LOG_INFO)
if (avgTemp >= setpointValue and boiler.state == 'On') then
if LOGGING then domoticz.log('Target temperature reached, boiler off') end
boiler.switchOff()
boiler.switchOff().afterMin(2)
if (avgTemp < setpointValue and boiler.state == 'Off' and override.state == 'Off') then
if (avgTemp < switchOnTemp) then
if LOGGING then domoticz.log('Heating is required, boiler switched on') end
boiler.switchOn()
boiler.switchOn().afterMin(2)
if LOGGING then domoticz.log('Average temperature below setpoint but within hysteresis range, waiting for temperature to drop to ' .. switchOnTemp) end
if (boiler.state == 'On' and override.state == 'On') then
if LOGGING then domoticz.log('Override is aan, CV Badkamer UIT') end
boiler.switchOff()
With the line you gave me to try, the avg is now 0 so the "temp" in the room is 0 so the heating always keeps turning on even though the setpoint is low.
Hope you can help out here
