MrDee wrote: ↑Sunday 26 November 2017 13:35
If there's still room I would like to help with the beta as well ... running Domoticz @ Pi2
Already registered with Controlicz on Friday
E-mail starts with domi
Thanks in advance!
I can't see you - need a bit more i'm afraid
My bad ... i've updated my e-mailadress! You should now be able to find [email protected]
Domoticz v3 - Beta Channel @ Pi2 | RFXtrx433e | MiLight Box2 | Google Home (1) | Google Home Mini (2)
Thanks,
When i try to link Controlicz to home control, after I have allowed fill access to my accont, I get
"could not update the settings. check your connection."
Any suggestions ?
usual checklist:
Is your host accessible over the internet? Are you using an https port? Are your devices in Room Plans? In Controlicz, you don't need to specify https:// in your hostname, if you have, please remove it.
Yes, Its accessible over internet. using 8443 as port that's is nat:ed to https on domoticz box.
ex https://url.domain.com:8443
Yes has devoces in room plans.
No https in hostname in Controlitcz,
Host : domain.com
Port : 8443
Use the built in certificate in Domoticz if that can be a problem ?
Briliant stuff, repect Geni! Finally light in the end of the tunnel to combine Google Home/Assistant with Domoticz!
Some feedback/an issue:
After i cleaned-up my Rooms and added new MiLights (in Domoticz) i wasn't able to see them in 'Home Automation'. So 2-hours later i decided to unlink/link again (Google Home-App), except now i see only 3-devices. All the other ones aren't comming back anymore? Please advice.
tohn wrote: ↑Sunday 26 November 2017 21:54
Host : domain.com
Port : 8443
Hi - can you PM me your email address, i'll take a look
I would like to use controlicz with my domoticz and google assistant. I am registred on controlicz with email vers***ete.ro***[email protected].
Could you please send me the email with the instructions ?
Host : domain.com
Port : 8443
plasmagun86 wrote: ↑Sunday 26 November 2017 23:44
Thank you
Added - you should have an email with instructions
