Alexa, Google Home and Siri
Madgeni
Post by Madgeni »
MrDee wrote: Sunday 26 November 2017 13:35 If there's still room I would like to help with the beta as well ... running Domoticz @ Pi2
Already registered with Controlicz on Friday :)
E-mail starts with domi
Thanks in advance!
I can't see you - need a bit more i'm afraid :)
MrDee
Domoticz version: v3-Beta
Post by MrDee »
Madgeni wrote: Sunday 26 November 2017 14:49
Thanks in advance!
My bad ... i've updated my e-mailadress! You should now be able to find [email protected]
Domoticz v3 - Beta Channel @ Pi2 | RFXtrx433e | MiLight Box2 | Google Home (1) | Google Home Mini (2)
ledje
Post by ledje »
And while you are at it.. mine is [email protected] . I am really itching to five my Google home mini a try heheh
Madgeni
Post by Madgeni »
Both of you have been added - you should have email :)
tohn
Post by tohn »
Can also help with beta testing.
has registred with controlicz with email tony.b...............
Best Regards
Tony
Madgeni
Post by Madgeni »
Added :)
tohn
Post by tohn »
Thanks,
When i try to link Controlicz to home control, after I have allowed fill access to my accont, I get
"could not update the settings. check your connection."
Any suggestions ?
Failure404
Post by Failure404 »
I also have registered myself, look for failure.
I used my proxy settings, hoping that it will work - eventually :-)
Thx alot!
ledje
Post by ledje »
Just had that problem myself. Your account in domoticz does not have the proper permissions. Try it with your domoticz admin account as a test first.
tohn
Post by tohn »
Does not help with Domoticz admin account.
Madgeni
Post by Madgeni »
usual checklist:
Is your host accessible over the internet? Are you using an https port? Are your devices in Room Plans? In Controlicz, you don't need to specify https:// in your hostname, if you have, please remove it.
tohn
Post by tohn »
Yes, Its accessible over internet. using 8443 as port that's is nat:ed to https on domoticz box.
ex https://url.domain.com:8443
Yes has devoces in room plans.
No https in hostname in Controlitcz,
Host : domain.com
Port : 8443
Use the built in certificate in Domoticz if that can be a problem ?
MrDee
Post by MrDee »
Briliant stuff, repect Geni! Finally light in the end of the tunnel to combine Google Home/Assistant with Domoticz!
Some feedback/an issue:
After i cleaned-up my Rooms and added new MiLights (in Domoticz) i wasn't able to see them in 'Home Automation'. So 2-hours later i decided to unlink/link again (Google Home-App), except now i see only 3-devices. All the other ones aren't comming back anymore? Please advice.
Madgeni
Post by Madgeni »
tohn wrote: Sunday 26 November 2017 21:54 Yes, Its accessible over internet. using 8443 as port that's is nat:ed to https on domoticz box.
Host : domain.com
Port : 8443
Hi - can you PM me your email address, i'll take a look :)
plasmagun86
Post by plasmagun86 »
I would like to use controlicz with my domoticz and google assistant. I am registred on controlicz with email vers***ete.ro***[email protected].
Could you please send me the email with the instructions ?
Thank you
Madgeni
Post by Madgeni »
Madgeni wrote: Sunday 26 November 2017 22:02
Host : domain.com
Port : 8443
This got fixed :)
Madgeni
Post by Madgeni »
plasmagun86 wrote: Sunday 26 November 2017 23:44 Hi,
Thank you
Added - you should have an email with instructions
mottola
Post by mottola »
Bonjour,
Je suis bien,enregistré sur controlicz.
Comment faire,pour utiliser google home avec?
Merci,
knacki123
Post by knacki123 »
Hi Madgeni
i would like to test it too.
Can you add me ,please? My Mail starts with christia.schm......... and I´m registered in controlicz.
thanks
Madgeni
Post by Madgeni »
mottola wrote: Monday 27 November 2017 8:06 Bonjour,
Merci,
Bonjour :)
Pouvez-vous PM votre email address svp, ou les premiere quattre lettres du votre email ici?
Merci!
