The probleme isn't from you (maybe) :Madgeni wrote:You can assign the devices you want to control via Alexa/Google to the user that Controlicz uses. If you have 96 devices in room plans, and you're not seeing them, then there's a problem. I'll take a lookflav wrote: Wednesday 22 November 2017 23:52deennoo wrote: Wednesday 22 November 2017 23:42 Did you use the same account that the one who register your Google Home ?
@Madgeni , I still have some probleme to show all my device, only 6 are show from 96 i have, it can be perfect if we can manage which one to drive with google home/Alexa, i don't care about PIR, or door sensor...Unfortunaly, choosing device in Domoticz user interface doesn't work...any idea on this ?
As far as i understand, devices needs to be assigned to a plan in domoticz, and light switch "picture" in domoticz should be set to "generic"
If i use API order to Ask about all device using spécifique user login who only have accès to 10 devices, Domoticz show all the device who are available, not only the one of the user.
