Alexa, Google Home and Siri
deennoo
Re: Google assistant/Google home integration
Post by deennoo »
Madgeni wrote:
flav wrote: Wednesday 22 November 2017 23:52
deennoo wrote: Wednesday 22 November 2017 23:42 Did you use the same account that the one who register your Google Home ?
@Madgeni , I still have some probleme to show all my device, only 6 are show from 96 i have, it can be perfect if we can manage which one to drive with google home/Alexa, i don't care about PIR, or door sensor...Unfortunaly, choosing device in Domoticz user interface doesn't work...any idea on this ?
As far as i understand, devices needs to be assigned to a plan in domoticz, and light switch "picture" in domoticz should be set to "generic"
You can assign the devices you want to control via Alexa/Google to the user that Controlicz uses. If you have 96 devices in room plans, and you're not seeing them, then there's a problem. I'll take a look :)
The probleme isn't from you (maybe) :
If i use API order to Ask about all device using spécifique user login who only have accès to 10 devices, Domoticz show all the device who are available, not only the one of the user.
http://domo-attitude.fr
Madgeni
Post by Madgeni »
Hi -
i've just tested it, and that's not true. I have an account I use for testing (it only has access to a set out dummy devices of the various types).
If i use its credentials to perform (it's ok, not real details :) )
https://test:test@madgeni:443/json.htm? ... order=Name
those are the only devices it returns. If i use my normal admin account, all my devices are returned
Wob76
Post by Wob76 »
Limiting the devices on my Controlicz account in Domoticz definitely worked for me.
Sent from my SM-G935F using Tapatalk
deennoo
Post by deennoo »
Madgeni wrote:Hi -
OK i will test more and more
ultratoto14
Post by ultratoto14 »
Hi Madgeni,
i have a quick question. I have a lot of different switches and temperature sensors in my home.
If i ask for a temp, google returned me the temp and the thermostat is off.
Could it be possible to add something to link a temperature sensor in domoticz to a switch to have a real thermostat ?
Your work is awesome.
Thanks a lot.
Madgeni
Post by Madgeni »
Hi ultratoto -
i'm not sure what you're asking? Do you mean if a sensor reaches a temperature, the switch does something (turns the heating on/up/down?)
Thomasdc
Post by Thomasdc »
I think Ultratoto means:
you: 'whats the room temperature?'
Google: ' the temperatures is x degrees and the room temperatures is off'
the part of the answer: 'the room temperatrues is off'
i think he wants to link this to the actual state of the heating --> if the heating is on or not
Madgeni
Post by Madgeni »
yes, it's on my list - i do return the correct state, but Google just ignores me :)
Just a quick update on the review of Controlicz. It's not going well. Google want me to provide every possible type of hardware that Domoticz supports, by every type of manufacturer.
I've explained how Domoticz works, and how Controlicz works with it, and that I don't control the hardware, i interact via the Domoticz API, and Domoticz controls the hardware. I've pointed out that there are plenty of similar solutions listed as certified apps for Google Home, but they either want me to provide them with a full list, or i'll have to rewrite it all, and we'll lose alot of the functionality. It's not looking good.
ultratoto14
Yes, Thomasdc is on the right way, i tried to translate the french message, talking about a thermostat.
It seems that the google home temperature device is not only a temperature sensor but a temperature sensor and a heating status.
flav
Post by flav »
Madgeni wrote: Friday 24 November 2017 13:09 Just a quick update on the review of Controlicz. It's not going well. Google want me to provide every possible type of hardware that Domoticz supports, by every type of manufacturer.
That would be just so lame...
Shame Google, Shame !
Madgeni
Post by Madgeni »
and when i say provide, they literally want me to ship them all of the devices. madness.
mark.sellwood
Post by mark.sellwood »
This is total madness by Google.
It also explains why Hive heating isn't integrated, are Hive going to send every type of boiler the Hive controls to Google? Me thinks not.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Thomasdc
Post by Thomasdc »
Madgeni,
I really hope that google will understand your/our point of view. I really like using controlicz!
if there is anything we can do to help you out with the google guys.. let me know!
I really want to keep using controlicz!
Madgeni
Post by Madgeni »
i've challenged back, i've offered them access to my Domoticz instance to verify that when they say something, something else happens.
We'll see - completely different set of behaviours to Amazon
Nicoo
Post by Nicoo »
Hello Madgeni,
I am interested for test, can you add me ?
I registered on controlitz, my email is [email protected].
Thank you
frenchyyii
Post by frenchyyii »
Hi Madgeni,
May I also ask you to add me to your list and test your work ?
Eric
I was already registered with that adress
frenchyyii[at]hotmail[dot]com
edit: hummm i'll create a new account with my GH account
cavabienspasser[at]gmail[dot]com
robbierobin1
Post by robbierobin1 »
Hi Madgeni,
Can you add me to your test project?
Registred as Robbierobin1[at]gmail[dot]com
thanks
deennoo
Post by deennoo »
robbierobin1 wrote:Hi Madgeni,
thanks
On my side i still have some problème on device liste.
I created an user (simple user) with only 1 device :
À dimmer lightning who is on a roomplan.
I update my controlicz account with this user.
Erase controlicz account from Home app, Clear app cache.
Reloggin on it, and controlicz continu to show me 5 devices (of course the spécifique one is here).
I didn't Saw on domoticz log, m'y spécial user connecting to domoticz.
Maybe can be good if on controlicz WE can have a "log" with connection and device discovering, is this on Real Time, or once / twice a day ?
Last edited by deennoo on Saturday 25 November 2017 16:50, edited 1 time in total.
Madgeni
Post by Madgeni »
PM me what the problem is.
I've added you 3 to the beta, should have an email
Madgeni
Post by Madgeni »
deennoo wrote: Saturday 25 November 2017 16:50 On my side i still have some problème on device liste.
Every time you make a query, it rediscovers your devices. I'll take a look..
