Logitech Media Server (LMS) dzVents adapter
Eoreh
Post by Eoreh »
Hi !
I have made very simple custom dzVents' adapter for Logitech Media Server (LMS) based on adapter for "Kodi". Its look like this.
	baseType = 'device',
	name = 'lms device',
	matches = function (device, adapterManager)
		local res = (device.hardwareType == 'Logitech Media Server')
		if (not res) then
			adapterManager.addDummyMethod(device, 'lmsSwitchOff')
			adapterManager.addDummyMethod(device, 'lmsStop')
			adapterManager.addDummyMethod(device, 'lmsPlay')
			adapterManager.addDummyMethod(device, 'lmsPause')
			adapterManager.addDummyMethod(device, 'lmsSetVolume')
			adapterManager.addDummyMethod(device, 'lmsPlayPlaylist')
			adapterManager.addDummyMethod(device, 'lmsPlayFavorites')
		return res
	end,
	process = function (device, data, domoticz, utils, adapterManager)
		function device.lmsSwitchOff()
			--return TimedCommand(domoticz, device.name, 'Off')
			domoticz.sendCommand(device.name, 'Off')
		function device.lmsStop()
			--return TimedCommand(domoticz, device.name, 'Stop')
			domoticz.sendCommand(device.name, 'Stop')
		function device.lmsPlay()
			--return TimedCommand(domoticz, device.name, 'Play')
			domoticz.sendCommand(device.name, 'Play')
		function device.lmsPause()
			--return TimedCommand(domoticz, device.name, 'Pause')
			domoticz.sendCommand(device.name, 'Pause')
		function device.lmsSetVolume(value)
			if (value < 0 or value > 100) then
				utils.log('Volume must be between 0 and 100. Value = ' .. tostring(value), utils.LOG_ERROR)
				domoticz.sendCommand(device.name, 'Set Volume ' .. tostring(value))
		function device.lmsPlayPlaylist(name)
			if (position == nil) then
				position = ''
			domoticz.sendCommand(device.name, 'Play Playlist ' .. tostring(name))
		function device.lmsPlayFavorites(position)
				position = 0
			domoticz.sendCommand(device.name, 'Play Favorites ' .. tostring(position))
Without changed in code Domoticz (only add adapter) I can play song in mp3 from "playlist" Favorites and my own defined (Test1 and Test2) from LMS (Synlogy) on my phone (android) with very cheap apps "Squeeze player".
(LMS and domoticz -> https://www.domoticz.com/wiki/Logitech_Media_Server)
My example of dzVents script looks like this (1 device to play song and 1 switch dummy for action):
local lmsDevice='samsung SM-J500FN'   -- lms devices to play songs.
		devices = {
			'test1'  -- dummy switch devices
	execute = function(domoticz, mySwitch)
    	local lms = domoticz.devices(lmsDevice)
       --lms.lmsSetVolume(20)
        if mySwitch.state=='On'  then
         lms.lmsPlayPlaylist('Test2')    -- play playlist with name "Test2"
           --lms.lmsPlay()
        if mySwitch.state=='Off'  then
            lms.lmsPlayPlaylist('Test1')    -- play playlist with name "Test1"
            --lms.lmsPlayFavorites(4)
            --lms.lmsPause()
            --lms.lmsStop()
            --lms.lmsSwitchOff()
Ok. Now problems.
1. First -For some reason I can do only One (last one !) valid command with lms for One period of script. (so that's reason I commented on other commands in the example)
When i try do 2 command for example SetVolume() and PlayPlayList() only one command is made by eventhandler.
I dont know how this fix.
2017-11-12 22:54:31.599 dzVents: Info: Handling events for: "test1", value: "On"
2017-11-12 22:54:31.599 dzVents: Info: ------ Start internal script: lms: Device: "test1 (Dummy)", Index: 2
2017-11-12 22:54:31.600 dzVents: Info: ------ Finished lms
2017-11-12 22:54:31.601 Command=Set Volume 20, FOR=0.00, AFTER=0.00, RANDOM=0.00, REPEAT=1 INTERVAL 0.00
2017-11-12 22:54:31.602 EventSystem: Scheduled Set Volume after 0.00.
2017-11-12 22:54:31.602 Command=Play Playlist Test2, FOR=0.00, AFTER=0.00, RANDOM=0.00, REPEAT=1 INTERVAL 0.00
2017-11-12 22:54:31.603 EventSystem: Scheduled Play Playlist after 0.00.
2017-11-12 22:54:31.603 EventSystem: Script event triggered: dzVents\runtime\dzVents.lua
2017-11-12 22:54:32.026  EventSystem: {"id":1,"method":"slim.request","params":["8c:27:6e:f9:ab:d2",["playlist", "play", "Test2"]]}
2. Unfortunately, the command "afterSec(x)" does not work for this device so i cant do lms.lmsSetVolume(20) and next lms.lmsPlayFavorites(4).afterSec(5)
3. If I want to choose a song from my favorite list, little change in EventSystem.cpp in function CEventSystem::ScheduleEvent is needed like this.
if (pBaseHardware == NULL)  // if not handled try Logitech
			pBaseHardware = m_mainworker.GetHardwareByType(HTYPE_LogitechMediaServer);
			if (pBaseHardware == NULL) return false;
			CLogitechMediaServer *pHardware = reinterpret_cast<CLogitechMediaServer*>(pBaseHardware);
			if (sParams.length() > 0)
				level = atoi(sParams.c_str());
but without bigger changed in domoticz its not possible choose song from "custom list" (Test1 or Test2).
Can anyone help me with this problems ?.
dannybloe
Re: LMS dzVents adapter
Post by dannybloe »
I will contact you soon to have this added to the codebase somehow.
I think that there is a limitation on how sendCommand works for a specific device in that if you send multiple commands back to Domoticz it only executes the last one.
If you want to use command options like afterSec() you have to wrap the command in a TimedCommand class. See any of the other adapters for examples.
Eoreh
Post by Eoreh »
1. Thank You for your replay. I will wait for your contact.
2. I'll try make afterSec() for this adapter. Maybe this will be solution to "limitation sendCommand.
Eoreh
Re: Logitech Media Server (LMS) dzVents adapter
Post by Eoreh »
Wow, it was so easy and "afterSec()" works.
Now in scripts i can use many commands for LMS. I know this is only workaround but its work. Thx again.
eg. script:
		devices = {
			'test1'  -- dummy switch devices to do any action
            lms.lmsPlayPlaylist('Test2').afterSec(5)    -- play playlist with name "Test2"
            lms.lmsSetVolume(50).afterSec(10)
            lms.lmsPause().afterSec(12)
            lms.lmsPlay().afterSec(20)
            lms.lmsSetVolume(100).afterSec(22)
            lms.lmsPlayPlaylist('Test1').afterSec(2)    -- play playlist with name "Test1"
            lms.lmsSetVolume(50).afterSec(8)
            lms.lmsPlayFavorites(4).afterSec(10)       -- play favorite list song 4  (required change in domoticz code).
            --lms.lmsPause()
            lms.lmsPlayPlaylist('Test2').afterSec(20)    -- play playlist with name "Test2"
            lms.lmsSetVolume(100).afterSec(28)
            lms.lmsStop().afterSec(30)
            lms.lmsSetVolume(80).afterSec(38)
            lms.lmsSwitchOff().afterSec(40)
dzVents - LMS adapter code:
local TimedCommand = require('TimedCommand')
		if (not res) then
		return res
	end,
			return TimedCommand(domoticz, device.name, 'Off', 'device', device.state)
		--	domoticz.sendCommand(device.name, 'Off')
			return TimedCommand(domoticz, device.name, 'Stop', 'device', device.state)
		--	domoticz.sendCommand(device.name, 'Stop')
			return TimedCommand(domoticz, device.name, 'Play', 'device', device.state)
			--domoticz.sendCommand(device.name, 'Play')
			return TimedCommand(domoticz, device.name, 'Pause', 'device', device.state)
--			domoticz.sendCommand(device.name, 'Pause')
				return TimedCommand(domoticz, device.name, 'Set Volume ' .. tostring(value), 'device', device.state)
--				domoticz.sendCommand(device.name, 'Set Volume ' .. tostring(value))
				position = ''
			return TimedCommand(domoticz, device.name, 'Play Playlist ' .. tostring(name), 'device', device.state)
--			domoticz.sendCommand(device.name, 'Play Playlist ' .. tostring(name))
				position = 0
			return TimedCommand(domoticz, device.name, 'Play Favorites ' .. tostring(position), 'device', device.state)
--			domoticz.sendCommand(device.name, 'Play Favorites ' .. tostring(position))
dannybloe
Post by dannybloe »
Does this device have any specific state information? Can you check this? Put dzVents in debug mode and locate the file scripts/dzVents/domoticzData.lua. Copy/paste the part for the LMS in here.
dannybloe
Post by dannybloe »
I changed the function names a bit as you can see below.
Could you write some piece of the documentation here:
#### Logitech Media Server
 - **switchOff()**: *Function*.  todo.
 - **stop()**: *Function*.  todo.
 - **play()**: *Function*.  todo.
 - **pause()**: *Function*.  todo.
 - **setVolume()**: *Function*.  todo.
 - **startPlaylist()**: *Function*.  todo.
 - **playFavorites()**: *Function*.  todo.
We also have to check if all the commands support all the TimedCommand options (like afterXXX(), forXXX(), withinXXX(), repeatAfterXXX(), checkState()).
dannybloe
Post by dannybloe »
Eoreh?
Eoreh
Post by Eoreh »
Sorry for delay. Today I'm returning from a weekly delegation at work.
Tomorrow, I will try all things you ask me.
Eoreh
Post by Eoreh »
dannybloe wrote: Friday 17 November 2017 8:27 Does this device have any specific state information? Can you check this? Put dzVents in debug mode and locate the file scripts/dzVents/domoticzData.lua. Copy/paste the part for the LMS in here.
[96] = {
		["data"] = {
			["unit"] = 1;
			["_nValue"] = 22;
			["usedByCamera"] = false;
			["protected"] = false;
			["levelVal"] = 147;
			["maxDimLevel"] = 15;
			["_state"] = "Unknown";
			["hardwareName"] = "LMS";
			["hardwareType"] = "Logitech Media Server";
			["hardwareID"] = 22;
			["hardwareTypeValue"] = 60;
			["icon"] = "LogitechMediaServer";
		["timedOut"] = false;
		["switchType"] = "Media Player";
		["baseType"] = "device";
		["lastLevel"] = 0;
		["subType"] = "AC";
		["description"] = "";
		["changed"] = false;
		["deviceType"] = "Lighting 2";
		["signalLevel"] = 12;
		["rawData"] = {
			[1] = "147";
		["deviceID"] = "0000015";
		["batteryLevel"] = 255;
		["lastUpdate"] = "2017-11-23 22:46:57";
		["switchTypeValue"] = 17;
		["id"] = 441;
		["name"] = "samsung SM-J500FN";
Eoreh
Post by Eoreh »
dannybloe wrote: Friday 17 November 2017 8:45 I changed the function names a bit as you can see below.
My primary name based on "kodi" (cos' lms is internally very similar) but "short" name will be better.
dannybloe wrote: Friday 17 November 2017 8:45 Could you write some piece of the documentation here:
 - **switchOff()**: *Function*.  Will turn the device off.
 - **stop()**: *Function*.  Will send a Stop command, only effective if the device is streaming.
 - **play()**: *Function*.  Will send a Play command. If defice was off, it's  turning on and device is streming
 - **pause()**: *Function*.  Will send a Pause command, only effective if the device is streaming.
 - **setVolume()**: *Function*.  Set the volume for a LMS device, 0 <= level <= 100.
 - **startPlaylist(name)**: *Function*.  Will playlist with "name".
 - **playFavorites([position])**: *Function*.  Will playlist with name "Favorites", optionally starting at position. Favorite positions start from 0 which is the default.
dannybloe wrote: Friday 17 November 2017 8:45 We also have to check if all the commands support all the TimedCommand options (like afterXXX(), forXXX(), withinXXX(), repeatAfterXXX(), checkState()).
- afterXXX() - support - and its necessary if two or more function will play in one scripts, one after one.
- repeatAfterXXX() - support.
rest function i have to do more test. I will do them in saturday.
dannybloe
Post by dannybloe »
Eoreh wrote: Thursday 23 November 2017 22:54
[96] = {
		["data"] = {
			["levelVal"] = 147;
			["_nValue"] = 22;
		["rawData"] = {
			[1] = "147";
I wonder what levelVal/rawData is here. Any idea? If you say that the volume is from 0-100 then what is this? And what about the _nValue? Given this information I'd say at this moment you don't know what the current volume level is right?
Eoreh
Post by Eoreh »
dannybloe wrote: Friday 17 November 2017 8:27 I wonder what levelVal/rawData is here. Any idea? If you say that the volume is from 0-100 then what is this? And what about the _nValue? Given this information I'd say at this moment you don't know what the current volume level is right?
[96] = {
		["data"] = {
			["levelVal"] = 147;
			["_nValue"] = 22;
		["rawData"] = {
			[1] = "147";
147 - it's uniq id playlist from LMS
22 - it's idx of hardware (LMS).
Correct. I dont have information of volume level in current moment from device hardware. LMS have very extended API but in this moment domoticz is used limited implementation.
dannybloe
Post by dannybloe »
Ok, so would it help to add a property playlistID?
EdwinK
Post by EdwinK »
Waht is the difference with the build-in LMS plugin?
dannybloe
Post by dannybloe »
Eoreh wrote: Friday 24 November 2017 11:27
[96] = {
		["data"] = {
			["levelVal"] = 147;
			["_nValue"] = 22;
		["rawData"] = {
			[1] = "147";
uniq id playlist? Is that the current playlist being played?
Eoreh
Post by Eoreh »
EdwinK wrote: Friday 24 November 2017 13:09 Waht is the difference with the build-in LMS plugin?
"Plugin" or rather "hardwar"e becouse LMS is implemented in domoticz just give You device to play or stop play from LMS server (with broken, not implemented pilot). dzVents lets you do things that only it can do :)
Eoreh
Post by Eoreh »
Yep. Its just implementation domoticz. if i would play list I just pass "name playlist" (not id list). I dont see id playlist in LMS. I thing its some like bug domoticz.
Eoreh
Post by Eoreh »
Ok, i do little more test with timedCommand:
- withinXXX() - support.
no support: forXXX(), checkState()
EdwinK
Post by EdwinK »
Eoreh wrote: Friday 24 November 2017 21:54
Okay. i will wait till this product is finished :)
stephanvdplas
Domoticz version: 2023.1
Post by stephanvdplas »
Hello, I use the LMS DZVents adapter with much pleasure. I've only got a small feature request.
domoticz.devices(<name>).setvolume(<0<=x<=100) sets the volume of the LMS player.
Is it possible to expand this function with VolumeUp and VolumeDown?
In JSON, this is already possible: https://<serverFQDN>/json.htm?type=command&param=lmsmediacommand&idx=29&action=VolumeDown sets the volume of this specific LMS player 2 down.
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
Users browsing this forum: hemant5400z and 1 guest
