Dashticz - Function - Action on status change
gielie
Domoticz version: latest β
Re: Dashticz - Function - Action on status change
Post by gielie »
repoman wrote:Hi. The popup for the camera's work very well.
Can you center the camera image on the popup?
(or make the popup adjust to the size of the image?)
Thanks,
Pascal
Id like to know if this is possible, now the popup window is too large.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
EdwinK
Post by EdwinK »
i would like to see the popup from the camera. All I got is a greyish-white.
gielie
Post by gielie »
EdKo66 wrote:i would like to see the popup from the camera. All I got is a greyish-white.
Does the camera popup work when you click on the camera?
- FIBARO FGS223
- Toon
- Kodi Media Server
EdwinK
Post by EdwinK »
In the Cam-setting on Domoticz when I click the 'streaming' button, there is a popup with camera-view.
gielie
Post by gielie »
EdKo66 wrote:In the Cam-setting on Domoticz when I click the 'streaming' button, there is a popup with camera-view.
Can you show me your camera code ur using in dashticz? And also the popup code? Ill take a look if i can make something of it
- FIBARO FGS223
- Toon
- Kodi Media Server
DewGew
Domoticz version: V4.10618
Post by DewGew »
Is it possible to play one sound for "on" and a different sound for "off"?
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Not yet, could you add that request to github?
DewGew
Post by DewGew »
Function updated in latest beta:
Go to slide
Example: Go to a second or third screen wich if filled with camera when a motionsensor is detected in your yard.
blocks[110] = {}
blocks[110]['gotoslideOn'] = 2;
Example: Go to a second or third screen wich is filled with status devices when ping device has lost connection to google.
blocks[110] = {}
blocks[110]['gotoslideOff'] = 2;
pvm
Domoticz version: 4.10538
Post by pvm »
Nice!
That should enable me to go to full screen ip cam upon movement
Regdul
Domoticz version: 3.8153
Post by Regdul »
hey guys,
nice work ! got it working. the only thing is the playing sound is really delayed. it takes about 10 to 20 seconds before playing sound. is it due to my tablet/network? on the phones using domoticz app for android it comes instantly.
is it possible to save the doorbell sound local on the tablet ?
blocks[1043] = {}
blocks[1043]['width'] = 4;
blocks[1043]['title'] = 'Deurbel'; /
blocks[1043]['icon'] = 'fa-bell-o';
blocks[1043]['switch'] = true;
blocks[1043]['hide_data'] = true;
blocks[1043]['show_lastupdate'] = true;
blocks[1043]['playsound'] = 'sounds/doorbell.ogg';
the tablet is android 4.4 and using 2.4Ghz wifi.
thanks in advance
greetings Regdul
aiolos
Domoticz version: stable
Post by aiolos »
Isn't that because dashticz only refreshes every X seconds (depending on you setting in CONFIG.js)? Lowering that should play the sound earlier, but will also make the load on domoticz higher.
Contributor to Dashticz
More on my Github profile
Regdul
Post by Regdul »
aiolos wrote: Tuesday 21 November 2017 10:21 Isn't that because dashticz only refreshes every X seconds (depending on you setting in CONFIG.js)? Lowering that should play the sound earlier, but will also make the load on domoticz higher.
just gave it a try. changed it from 60 seconds to 30 seconds. no effect :cry: still it takes about 10-20 seconds before playing the sound
aiolos
Post by aiolos »
Regdul wrote: Tuesday 21 November 2017 11:08
I would say try setting the domoticz refresh to 5 seconds in config, like this:
Then every 5 seconds the devices are fetched from domoticz, and it should only take max 5 seconds before the sound is played. Dashticz does not get a 'push' from domoticz, and the connection is not open all the time, so the status change is only known after a new fetch of data.
robgeerts
Post by robgeerts »
Well, I think you misunderstand each other.
My guess is he does see the status change (visually, because of the domoticz refresh) but it just takes time to load the mp3...
I had the same issue on my (old) tablet. Do you load Dashticz through an internal IP or external?
Regdul
Post by Regdul »
I load dashticz through internal ip.
Is it possible to save the file on the tablet and load it from there?
It seems to me that it has to "buffer".
The only thing is, when manually push the doorbell button,in the interface of dashticz on the. It plays the sound right away.
When i push the doorbell at the frontdoor it takes time before it plays the sound
pvm
Post by pvm »
DewGew wrote: Monday 20 November 2017 13:07 Function updated in latest beta:
Go to slide
blocks[110] = {}
Got this function working nicely. It would be more useful to me when this would also exit the standby screen? Is that possible?
DewGew
Post by DewGew »
pvm wrote: Wednesday 29 November 2017 22:01
Go to slide
blocks[110] = {}
Thanks for the tip. Now you have this function in the latest beta.
pvm
Post by pvm »
Integrated this evening and working nicely: Dashticz leaves standby mode after slide switch (motion detection on IP Camera in my case)
sailmich
Post by sailmich »
Any chance to use own mp3 sound files for change of status? Would be cool to get information by voice e.g. all blinds are closed, humidity is to high open the window.......
I have a friend with a very warm voice I would like to record sentences and use them for notifications. :D
robgeerts
Post by robgeerts »
You can add them to the custom directory, and use something like:
blocks[110] = {}
blocks[110]['playsound'] = 'custom/warmvoice.mp3';
