Id like to know if this is possible, now the popup window is too large.repoman wrote:Hi. The popup for the camera's work very well.
Can you center the camera image on the popup?
(or make the popup adjust to the size of the image?)
Thanks,
Pascal
Dashticz - Function - Action on status change
- gielie
- Domoticz version: latest β
Re: Dashticz - Function - Action on status change
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- EdwinK
- Domoticz version: BETA
i would like to see the popup from the camera. All I got is a greyish-white.
- gielie
Does the camera popup work when you click on the camera?EdKo66 wrote:i would like to see the popup from the camera. All I got is a greyish-white.
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- EdwinK
In the Cam-setting on Domoticz when I click the 'streaming' button, there is a popup with camera-view.
- gielie
Can you show me your camera code ur using in dashticz? And also the popup code? Ill take a look if i can make something of itEdKo66 wrote:In the Cam-setting on Domoticz when I click the 'streaming' button, there is a popup with camera-view.
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- DewGew
- Domoticz version: V4.10618
Is it possible to play one sound for "on" and a different sound for "off"?
- Domoticz version: 3.7067
Not yet, could you add that request to github?
- DewGew
Function updated in latest beta:
Go to slide
Example: Go to a second or third screen wich if filled with camera when a motionsensor is detected in your yard.
Example: Go to a second or third screen wich is filled with status devices when ping device has lost connection to google.
Go to slide
blocks[110] = {}
blocks[110]['gotoslideOn'] = 2;
blocks[110] = {}
blocks[110]['gotoslideOff'] = 2;
- Domoticz version: 4.10538
Nice!
That should enable me to go to full screen ip cam upon movement
- Domoticz version: 3.8153
hey guys,
nice work ! got it working. the only thing is the playing sound is really delayed. it takes about 10 to 20 seconds before playing sound. is it due to my tablet/network? on the phones using domoticz app for android it comes instantly.
is it possible to save the doorbell sound local on the tablet ?
the tablet is android 4.4 and using 2.4Ghz wifi.
thanks in advance
greetings Regdul
blocks[1043] = {}
blocks[1043]['width'] = 4;
blocks[1043]['title'] = 'Deurbel'; /
blocks[1043]['icon'] = 'fa-bell-o';
blocks[1043]['switch'] = true;
blocks[1043]['hide_data'] = true;
blocks[1043]['show_lastupdate'] = true;
blocks[1043]['playsound'] = 'sounds/doorbell.ogg';
thanks in advance
greetings Regdul
- Domoticz version: stable
Isn't that because dashticz only refreshes every X seconds (depending on you setting in CONFIG.js)? Lowering that should play the sound earlier, but will also make the load on domoticz higher.
just gave it a try. changed it from 60 seconds to 30 seconds. no effect
I would say try setting the domoticz refresh to 5 seconds in config, like this:
Well, I think you misunderstand each other.
My guess is he does see the status change (visually, because of the domoticz refresh) but it just takes time to load the mp3...
I had the same issue on my (old) tablet. Do you load Dashticz through an internal IP or external?
I load dashticz through internal ip.
Is it possible to save the file on the tablet and load it from there?
It seems to me that it has to "buffer".
The only thing is, when manually push the doorbell button,in the interface of dashticz on the. It plays the sound right away.
When i push the doorbell at the frontdoor it takes time before it plays the sound
Got this function working nicely. It would be more useful to me when this would also exit the standby screen? Is that possible?DewGew wrote: ↑Monday 20 November 2017 13:07 Function updated in latest beta:
Go to slide
Example: Go to a second or third screen wich if filled with camera when a motionsensor is detected in your yard.Code: Select all
blocks[110] = {} blocks[110]['gotoslideOn'] = 2;
- DewGew
Thanks for the tip. Now you have this function in the latest beta.pvm wrote: ↑Wednesday 29 November 2017 22:01Got this function working nicely. It would be more useful to me when this would also exit the standby screen? Is that possible?DewGew wrote: ↑Monday 20 November 2017 13:07 Function updated in latest beta:
Go to slide
Integrated this evening and working nicely: Dashticz leaves standby mode after slide switch (motion detection on IP Camera in my case)
Any chance to use own mp3 sound files for change of status? Would be cool to get information by voice e.g. all blinds are closed, humidity is to high open the window.......
I have a friend with a very warm voice I would like to record sentences and use them for notifications.
You can add them to the custom directory, and use something like:
blocks[110] = {}
blocks[110]['playsound'] = 'custom/warmvoice.mp3';
