I have a funny problem.
I have a PIR sensor, that turns on the light.
Some time it works and sometime it dosen't
local lux_device = 265
active = true,
devices = {
263
execute = function(domoticz, mySensor)
domoticz.log('Start af script' , domoticz.PRIORITY_INFO)
domoticz.log('Last update:' , domoticz.PRIORITY_INFO)
domoticz.log(domoticz.devices(263).lastUpdate.minutesAgo , domoticz.PRIORITY_INFO)
domoticz.log('263 State:' , domoticz.PRIORITY_INFO)
domoticz.log(domoticz.devices(263).state , domoticz.PRIORITY_INFO)
domoticz.log('175 State:' , domoticz.PRIORITY_INFO)
domoticz.log(domoticz.devices(175).state , domoticz.PRIORITY_INFO)
if (domoticz.devices(263).lastUpdate.minutesAgo<1 and domoticz.devices(263).state == 'On' and domoticz.devices(175).state == 'Off') then
domoticz.devices(175).switchOn()
domoticz.devices(175).dimTo(30)
domoticz.devices(175).dimTo(50).afterSec(2)
domoticz.devices(175).dimTo(100).afterSec(4)
domoticz.log('light on' , domoticz.PRIORITY_INFO)
if (domoticz.devices(175).lastUpdate.minutesAgo>15 and domoticz.devices(263).state == 'Off' and domoticz.devices(175).state == 'On') then
domoticz.devices(175).switchOff()
domoticz.log('light off' , domoticz.PRIORITY_INFO)
domoticz.log('Slut af script' , domoticz.PRIORITY_INFO)
}The 263 is the pir sensor and trigger of the script.
When its not working the lastupdate.minutesAgo is not updating even that the 263 device is the trigger and goes from Off to On.
2017-10-23 20:41:47.674 dzVents: Info: Handling events for: "BadStort | Sensor", value: "On"
2017-10-23 20:41:47.674 dzVents: Info: ------ Start external script: badstort_pir_light.lua: Device: "BadStort | Sensor (PiTeknikskab)", Index: 263
2017-10-23 20:41:47.674 dzVents: Info: Start af script
2017-10-23 20:41:47.674 dzVents: Info: Last update:
2017-10-23 20:41:47.674 dzVents: Info: 3
2017-10-23 20:41:47.674 dzVents: Info: 263 State:
2017-10-23 20:41:47.674 dzVents: Info: On
2017-10-23 20:41:47.674 dzVents: Info: 175 State:
2017-10-23 20:41:47.674 dzVents: Info: Off
2017-10-23 20:41:47.674 dzVents: Info: Slut af script
2017-10-23 20:41:47.674 dzVents: Info: ------ Finished badstort_pir_light.lua2017-10-23 20:41:47.674 dzVents: Info: Last update:
And of cause when its working the minutes ago are updating correctly.
2017-10-23 20:34:26.125 dzVents: Info: Handling events for: "BadStort | Sensor", value: "On"
2017-10-23 20:34:26.125 dzVents: Info: ------ Start external script: badstort_pir_light.lua: Device: "BadStort | Sensor (PiTeknikskab)", Index: 263
2017-10-23 20:34:26.125 dzVents: Info: Start af script
2017-10-23 20:34:26.125 dzVents: Info: Last update:
2017-10-23 20:34:26.125 dzVents: Info: 0
2017-10-23 20:34:26.125 dzVents: Info: 263 State:
2017-10-23 20:34:26.125 dzVents: Info: On
2017-10-23 20:34:26.125 dzVents: Info: 175 State:
2017-10-23 20:34:26.125 dzVents: Info: Off
2017-10-23 20:34:26.125 dzVents: Info: light on
2017-10-23 20:34:26.125 dzVents: Info: Slut af script
2017-10-23 20:34:26.125 dzVents: Info: ------ Finished badstort_pir_light.luaThe device is correctly changing the status Any ideas?
