I am using Domoticz for a while and I want to make it more clever with scripts, in this case Lua scripts. What I miss is a step by step tutorial Lua for Domoticz for beginners.
If somebody places a question on the forum than mostly there comes an answer for profs, too difficult. At the end of the day a lot of people are searching through the forum topics in the hope to find something that can help. I have the idea that a lot of beginners have these struggle and that can end in that he can solve his problem/question or that he thinks, I just leave it like that, I don’t want that struggle. That’s a pitty.
This situation is not only with Domoticz. I have also used Nodo and Cayenne. Both have the same problems. Experienced users can help each other, but the beginners are walking through the amount of topics on the forums without finding the proper answer.
Is it possible that we start making that tutorial for beginners in a very practical step by step way?
For now I have the following situation:
On my dashboard I want to have a slider to give in the desirable temperature. In that room I want to have a wireless temperature sensor. In a script I want to compare the desirable temperature with the measured temperature. The outcome of this gives a signal to a wireless relais board that switch a actuator on a floor heating distributer. I want to do this low cost, so no expensive thermostate or control box. Just a temperature sensor like DHT22, a ESP8266 Wifi board, a relais board and so on.
In Domoticz I made a slider.
How can I change the lowest value, the highest value and the startup value? Let say: the slider totally to the left is 10 ’C, the slider totally to the right is 30 ‘C.
How can I change the % symbol into ‘C symbol?
How do I read out the value of the slider?
Please an answer in beginners language.
DomoticaRob
- Domoticz version: V4.9700
Nautilus
Re: Lua for Domoticz for beginners
I think the wiki is our beginners guide - which as such can and should be improved in various ways (kept up-to-date at least). But also in its current form it serves as a good starting point also for beginners, e.g. https://www.domoticz.com/wiki/Events#Lu ... _Interface
For you specific questions, I'm afraid these aren't to Lua in any way:
I think this can be just:
They are attributes fixed to the user interface and unfortunately not something you can change, with or without scripting. As for the last question (and something that solves also the two questions above), I think you are actually looking for a virtual thermostat device. I don't use any myself but there should be a lot of threads about it already. And as for the "beginners guide", I hope this helps a bit: https://www.domoticz.com/wiki/Thermostat_control But note, there might be some outdated parts, e.g.How can I change the lowest value, the highest value and the startup value? Let say: the slider totally to the left is 10 ’C, the slider totally to the right is 30 ‘C.
if (devicechanged[sonde]) then
local temperature = devicechanged[string.format('%s_Temperature', sonde)]Code: Select all
if devicechanged[sonde..'_Temperature'] then- emme
- Domoticz version: latest
my opinion is that if you want to start scripting in Domoticz, you'd better give a try to dzVents
here's a quick start guide that you will find interesting
http://domoticz.com/forum/viewtopic.php?f=59&t=18143
good luck
M
good luck
M
"We always done this way"
DomoticaRob
Hello Emme,
Thank you for your suggestion about dzVents. I gave it a quick look and will take some time to figger it out.
