homebridge-edomoticz Plugin
BuddyRich
Re: homebridge-edomoticz Plugin
What I have works, but Im wondering how I can change the "type" of an item in either Domo or homekit.
I use a mimolite via ZWave for Garage Door control. The contact switch is on/off and I feed a dry contact sensor into 2nd mimolite connect.
Even within Domoticz the switch is on/off... but the contact shows as opened/closed.
When I port it over to Homekit via eDomoticz and Homebridge, I get the the switch as on/off but the contact sensor is yes/no. Is there anyway I could relay this to a device type where I could say "hey siri, open the garage door" and the sensor show opened/closed rather than yes/no?
I can say "hey siri, turn on the garage door" but...
fennec62
In domoticz you must create virtual device Door lock, search the IDX of door lockBuddyRich wrote: Saturday 30 September 2017 16:17 What I have works, but Im wondering how I can change the "type" of an item in either Domo or homekit.
in the device switch on /off you have
action on : http://ip:8080/json.htm?type=command&pa ... X&nvalue=0
action off : http://ip:8080/json.htm?type=command&pa ... X&nvalue=1
You can adjust 0 and 1 to have a good open or closed door
And in homebridge add virtual device door lock
And if you wan't see a real garage door in home app just name "garage" for virtual device door lock
and use modify git edomoticz
https://github.com/fennec622/homebridge-edomoticz
and if you change icon light in domoticz homekit add light in auto not switch
same with fan same with outlet
- Capture d’écran 2017-09-30 à 20.55.53.png (32.12 KiB) Viewed 6526 times
- IMG_E0F0D355846A-1.jpeg (103.7 KiB) Viewed 6528 times
BuddyRich
I pulled your fork and got it working. Thanks.
I created a dummy switch and named it garage. I don't use the Home app, as I am using an ipad 3 which tops out at ios9 so no Home app. I am using the Eve app for ios9. It shows an actual Door for the switch and Open and Close as status, but does detect the homekit type as a "garage door opener". I guess its down to that app what it shows as an icon. Another app does show a garage.
This does bring up another issue. I also use a manual garage door opener sometimes, how do you handle keeping the virtual switches' state in sync with "reality" (so to speak). For now I am still showing the garage door contact so I can see if its actually open/or closed but I would love to keep the states in sync.
fennec62
For command my garage i use a ESP8266 connect to domoticz
And i have a local command
For know real door statut i use this
https://www.amazon.fr/Monoprice-Z-Wave- ... B00V5IQ8E8
When action on i switch virtual switch to open
and action off to closed
Gravityz
- Domoticz version: 2025.1
have the Edomoticz plugin running by using a docker instance on my synology.
https://hub.docker.com/r/marcoraddatz/homebridge/
everything seems to work and all the devices i put in roomplan 2 are visible in homekit.
i have however 2 problems
1: some modules do not always seem to react from homekit while they perfectly react from domoticz(so zwave connection is goed)
1:i put devices as favorite in homekit where they all appear.
however when i swipe up from my iphone and select the homekit icon one device(temp sensor) seems missing from thre favorite screen.
So there is a difference between homekit app-favorites and swipe up-homekit-favorites
also i noticed in al the config files is see address 127.0.0.1(loopback) which did not work in my case.
i changed it to the ip address of my domoticz server. is this how it is supposed to do or do i need to set it back to 127.0.0.1?
config.json
"bridge": {
"name": "Homebridge",
"username": "CC:21:3E:E4:DE:33",
"port": 51826,
"pin": "031-45-154"
"description": "Configuration file for (e)xtended Domoticz platform.",
"platforms": [
"platform": "eDomoticz",
"name": "eDomoticz",
"server": "192.168.1.50",
"port": "8084",
"ssl": 0,
"roomid": 2,
"mqtt": 1
"accessories": []
alveman
I have an Apple TV 4 at home (WiFi connected). I supposes that the TV will work as a bridge for external Connections, and if I look at it, it's connected to Raspberry and everything work as long I'm at the local network. But from the outside I don't get any Connection to all my devices.
This is very strange because it has worked before and as far as I know I have not changed anything. Do you have any suggestions where I will start looking for this error?
I think maybe this started when I updated the iPhone to iOS 11.0.3
Gravityz
try a simple logout and login on the appletv
worked for me serveral times and i have an appletv3 which is not even supposed to work as a bridge
and yes i changed address back to 127.0.0.1 8084
thanks al for pointing this out(people with knowledge should help other people)
BuddyRich
One thing Ive noticed is that my door statuses are all reversed.
I have a Schlage Connect and when its locked, it shows unlocked, and vice-versa.
Similarly using the a contact sensor for a garage switch using fennecs fork, and as a door it gets interpereted as contact sensor yes = open door, when contact = yes should be closed.
The door icon on domoticz for both my schalge connect and garage switch does showed locked when locked, homekit looks to be flipping it.
I do remember for a while on a prior version of domo this actually was reversed as well.
Pobes
Hi !
Is there any instruction how to use excludeddevice? I want to exclude some device from home, but homebridge ignore my config.
matv
- Domoticz version: 3.5877
None of my accessoires are showing up. What are the recommended troubleshooting steps?
Everything used to work perfectly fine but my Raspberry has been offline for the last 3 months (and I upgraded to iOS 11).
I already:
- Updated Domoticz
- Updated homebridge
- Updated edomoticz
- Rebooted Raspberry Pi
config.json:
I already:
- Updated Domoticz
- Updated edomoticz
config.json:
- Spoiler: show
Toyman
From edomoticz-GITHUB:Pobes wrote: Monday 23 October 2017 19:45 Hi !
Therefore, to reduce the number of devices exposed from Domoticz, create a roomplan within Domoticz via Setup > More Options > Plans > roomplan. Add only the devices you wish to be exposed to HomeKit to this new roomplan within Domoticz, and then get it's roomidx number. Set "roomid" in your config.json file to this room number.
harrykausl
- Domoticz version: 2021.1
I have one more problem. I changed some devices in domoticz (name of switches and scenes). In home and eve, I could only see the old names. So I restartet my pi and deleted homebride in the home app and reinsertet it. But I only got the old devices. Perhaps it has something to do with the storing on the apple tv. What can I do? Thanks
harrykausl
I think I could help myself. I restored my pi-image. Then updated homebridge to newest version. Then I defined a room homebridge where I only put the devices I want to see in home. Then changed config.json to the new roomid (instead of 0) and now it seems to work. I change the name of a switch in domoticz and when it is correct, I link it to the room homebridge.
edwin1234
In homebridge i only see the status of the devices i cant switch lights on and off there
In domoticz it works fine. Ii did worked before
What could be wrong
Where must i look for?
What could be wrong
rope
matv wrote: Wednesday 25 October 2017 14:53 None of my accessoires are showing up. What are the recommended troubleshooting steps?
I already:
- Updated Domoticz
- Updated edomoticz
config.json:Thanks in advance!
- Spoiler: show
I had the same problem and was looking for a way to debug but everything seemed ok on the homebridge/domoticz side. It used to work but at some point in time (possible an upgrade) homebridge did not show up in Homekit anymore ("Woning" App in IOS).
I found the solution on the homebridge "Common Issues" section on https://github.com/nfarina/homebridge :
Two reasons why Homebridge may not be discoverable:
1. Homebridge server thinks it's been paired with, but iOS thinks otherwise. Fix: deleted persist/ directory which is next to your config.json.
So I deleted the persist/ directory and after a restart of homebridge my IOS devices found the Homebridge again (and switches etc. in Domoticz).
Still wonder if I would have been able to find this out by looking at some logs, but hey it work now!
edwin1234
I get this error:
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-153 │
events.js:141
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51825
at Object.exports._errnoException (util.js:837:11)
at exports._exceptionWithHostPort (util.js:860:20)
at Server._listen2 (net.js:1231:14)
at listen (net.js:1267:10)
at Server.listen (net.js:1363:5)
at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:496:16)
at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:114:16)
at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.
What does it mean?
And what to do to solve this
Edwin
│ 031-45-153 │
events.js:141
What does it mean?
Edwin
schulpr
My last digits are 154
Xperimental
I am reinstalling my Domoticz and this time I am stuck with Homebridge.
I followed this guide: https://www.domoticz.com/wiki/Homekit_Siri
my Json config looks like this:
This is the error I get:
I am running the Beta version of Domotica, created a Roomplan and I config local network ip in Domoticz' setup.
Could someone help me out?
TIA!
"bridge": {
"port": 51826,
"pin": "031-45-154"
"platforms": [
"server": "127.0.0.1",
"port": "8080",
"ssl": 0,
"roomid": <Input Domoticz IDX-value>,
"mqtt": 1
"accessories": []
[11/18/2017, 2:05:26 PM] Homebridge is running on port 51826.
[11/18/2017, 2:05:26 PM] [eDomoticz] There was a problem connecting to Domoticz.
- Error: connect ECONNREFUSED 127.0.0.1:8080
[11/18/2017, 2:15:26 PM] [eDomoticz] There was a problem connecting to Domoticz.
TIA!
Raspberry Pi 3B (Domoticz v3.9269)
Razberry Z-Wave 2.me
Fibaro switches
Fibaro switches
pinda
I got homebridge running on my rpi jessie stretch. It's working and i see homebridge and my Harmony en Nest devices in the homekit app.
In Domoticz i created a roomID 2 en added some switches to it.
There aren't any Domoticz switches showing up in the app
Dont know how to troubleshoot this any further. Any help would be great!
"bridge": {
"port": 51826,
"pin": "031-45-154"
"platforms": [
"port": "8080",
"ssl": 0,
"roomid": 2,
"mqtt": 0
"platform": "Nest",
"token": "",
"clientId": "",
"clientSecret": "",
"code": "",
"username": "username",
"password": "password"
"platform": "HarmonyHub",
"name": "Harmony Hub"
"accessories": []
}Who is online
