Domoticz interfaced with alarm
ge1984
Post by ge1984 »
I would like to activate my alarm from domoticz, now to be able to activate internally I have to press a button and turn it on.
What piece of zwave should i buy to emulate the same service?
Also, a 12V led light comes on when an alarm is switched on, can I part interfacing to check the on / off state?
thank you so much
mosjonathan
Re: Domoticz interfaced with alarm
Post by mosjonathan »
i think a bit more information is needed
what kind of alarm system is it and is it a seperate button or is it a button on a keypad?
ge1984
Post by ge1984 »
is a wired alarm, the button I installed is Bticino of living international.
The button just does short of the 2 wires.
Thank you
mosjonathan
does it stay shorted or is it a pulse?
ge1984
Post by ge1984 »
it a pulse
mosjonathan
and the same button turns alarm off?
ge1984
Post by ge1984 »
Yes exactly.
mosjonathan
i think you can do that with a quibino relay so that the status is updated when you fysicly press the button and you can also switch it from within domoticz
ge1984
Post by ge1984 »
can you give me the correct quibino code, in odo not to mistake the purchase?
Thanks so much
mosjonathan
ge1984
Post by ge1984 »
not having power on the wires of the button, the links on how much do I have to do them?
L = LINE 220V
N = NEUTRO 220V
What are the wires of the button in which clamps should I put them?
