Domoticz interfaced with alarm
ge1984
I would like to activate my alarm from domoticz, now to be able to activate internally I have to press a button and turn it on.
What piece of zwave should i buy to emulate the same service?
Also, a 12V led light comes on when an alarm is switched on, can I part interfacing to check the on / off state?
thank you so much
thank you so much
mosjonathan
Re: Domoticz interfaced with alarm
i think a bit more information is needed
what kind of alarm system is it and is it a seperate button or is it a button on a keypad?
ge1984
is a wired alarm, the button I installed is Bticino of living international.
The button just does short of the 2 wires.
Thank you
Thank you
mosjonathan
does it stay shorted or is it a pulse?
ge1984
it a pulse
mosjonathan
and the same button turns alarm off?
ge1984
Yes exactly.
mosjonathan
i think you can do that with a quibino relay so that the status is updated when you fysicly press the button and you can also switch it from within domoticz
ge1984
can you give me the correct quibino code, in odo not to mistake the purchase?
Thanks so much
Thanks so much
mosjonathan
ge1984
not having power on the wires of the button, the links on how much do I have to do them?
L = LINE 220V
N = NEUTRO 220V
What are the wires of the button in which clamps should I put them?
L = LINE 220V
N = NEUTRO 220V
