notification with light on
ge1984
Hello to all,
I'm trying to schedule a notification so that at a certain time, if I turn on the light I get a notification.
The problem that when configuring it as a photo, when the light is on, I receive the notifications, but I would like the notification to arrive only by lighting it up.
Where am I wrong?
Thank you
Where am I wrong?
Thank you
- Schermata 2017-11-12 alle 10.10.41.png (53.79 KiB) Viewed 2191 times
mosjonathan
Re: notification with light on
your second if block is wrong you need the one without the blue cog
ge1984
how do I enter camera blocks and notify me? what other block should i add?
- Schermata 2017-11-12 alle 10.40.41 copia.png (124.96 KiB) Viewed 2179 times
mosjonathan
i think you need to do it like this
ge1984
I did as you told me, but if the light stays on, it keeps sending me notifications.
is there no way that notifications come to me only when I hit the button?
- gizmocuz
Why don't you add the notification directly on the switch ? (switches tab, press the notification button)
ge1984
because I would only be notified at certain times and not all day.
can I set the times directly from the switch?
- kuifje
- Domoticz version: latest
Maybe this will get you in the right direction. You have to get an user variable in to get things done.
Replace TVlamp with camera etc.etc.
You get it done. Good luck.
Greetsz,
Kuifje
Greetsz,
Kuifje
ge1984
how do I program a variable? what kind of data should I enter?
- kuifje
At settings-more options-user variables
ge1984
ok, but what data do I have to include in the variable inmode that risked in my intent?
- kuifje
Float and 0
ge1984
Okay, I just did the programming and it looks like it works. I have to do some tests to check it out.
Thank you so much, you've been really helpful and kind
