[120] opentherm gateway
- gizmocuz
Re: [120] opentherm gateway
what happens when you use the monitor application of OTGW :
http://otgw.tclcode.com/download.html#utilities
Sappien
With otmonitor it works fine
- gizmocuz
Is there any logging available fro otmonitor ?
in the above log you see that i send the SH command, so it should work.
the documentation says:
the last line (SH: 39.00) is actually from the OTGW itself, not send to the log by domoticzSH=temperature
Setpoint Heating - Set the maximum central heating setpoint. This command is only available with boilers that support this function.
Examples: SH=72.5, SH=+20
Sappien
20:08:23.523226 Command: SW=54
20:08:23.541157 SW: 54.00
20:08:45.007171 T80190000 Read-Data Boiler water temperature: 0.00
20:08:45.148995 BC0191419 Read-Ack Boiler water temperature: 20.10
20:08:46.010132 T00090000 Read-Data Remote override room setpoint: 0.00
20:08:46.032068 R10383600 Write-Data DHW setpoint: 54.00
20:08:46.145500 BD0383600 Write-Ack DHW setpoint: 54.00
20:08:46.160374 AC0090000 Read-Ack Remote override room setpoint: 0.00
- gizmocuz
Okey....
i use the SH command, you are taling about the SW command
that is the Domestic Hot Water setpoint, not the CH water setpoint ?
Sappien
I've got the issue with the DHW and CH setpoint. Both jump back to the original value
DHW = SW
Max CH = SH
DHW = SW
Max CH = SH
Hello
I try to get the opentherm gateway in combination with the lan/wifi interface working. I have tried to get communication going via port 1001 as the manual tells me. Is there somebody who has this setup (otwg + tplink 703) working in Domoticz? And maybe can confirm i' am using the right port?
- sincze
- Domoticz version: 2024.4
I configured OTGW via TP Link within Domoticz.Sjonnie wrote:Hello
First I received some errors, (OTGW-2) then after one minute the device was recognised (OTGW-1).
What does your domoticz log say?
Did you configure the TPLInk startup script correctly?
Sándor
- OTGW-3
- OTGW-3.png (2.67 KiB) Viewed 5095 times
- Errors
- OTGW-2.PNG (13.48 KiB) Viewed 5095 times
- OTGW
- OTGW-1.PNG (41.13 KiB) Viewed 5095 times
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Hello Sandor
Thanks a lot for your reply! I appreciate it.
I get errors that connection gets refused in Domotiticz log: I'am not entirely sure I configured the TPlink startup script correctly to be honest. I bought it as a kit and I followed the documentation which came along with it. The TPlink had to be flashed with "openWRT" firmware and configured as such.
This is the document: Thanks a lot
John
John
- sincze
Looks okay.
Can you check TPLInk script Under system startup:
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
opkg update
opkg install kmod-usb-serial-pl2303
opkg install ser2net
# Create Connection file for Opentherm Gateway
echo "1001:raw:15:/dev/ttyUSB0:9600,NONE,1STOPBIT,8DATABITS" > /etc/ser2net.conf
ser2net
exit 0
opkg update
ser2net
exit 0
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
In addition you can use a program like putty or bitvise to loging to your TP-Link.sincze wrote:Looks okay.
opkg update
ser2net
exit 0
issue a command dmesg and look if your TTYUSB0 is the one the OTGW is connected to.
dmesg | grep TTYUSB*
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Thanks again. I' am going to try this and will let you know how things turn out. I didn't do the opkg update and installation though, so that probably is the issue then.
John
John
I'am not very succesful yet;
Both the packages are installed ("kmod-usb-serial-pl2303", "ser2net") as the luci webgui of the Openwrt tells me.
Also I can find the ser2net.conf file with the string as you wrote below.
The dmesg grep shows me a connected device PL2303 and when I disconnect the usb connector it shows the PL2303 disconnected. I don't know if this is the right value for the actual OTGW.
I build the gateway myself and I do know that the gateway itself is working OK because the windows application "OTmonitor" works good over USB.
Thanks for your support
Best Regards
John
Best Regards
John
sincze wrote:In addition you can use a program like putty or bitvise to loging to your TP-Link.sincze wrote:Looks okay.
opkg update
ser2net
exit 0
- sincze
10.180000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
10.180000] hub 1-0:1.0: USB hub found
10.450000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
10.530000] usb 1-1: new high-speed USB device number 2 using ehci-platform
10.590000] USB Serial support registered for generic
10.680000] hub 1-1:1.0: USB hub found
10.690000] usbserial: USB Serial Driver core
10.740000] USB Serial support registered for FTDI USB Serial Device
10.750000] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
10.780000] USB Serial support registered for pl2303
10.790000] pl2303: Prolific PL2303 USB to serial adaptor driver
10.980000] usb 1-1.2: new full-speed USB device number 3 using ehci-platform
11.090000] usb 1-1.2: pl2303 converter now attached to ttyUSB0
A well you should be nearly there.
check /etc the ser2net.conf should be there.
if not just create one
touch ser2net.conf
sudo nano ser2net.conf and enter 1 line
save the file and now run ser2net.
Try again in Domoticz.
touch ser2net.conf
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Hi Sincze
Guess what! You got it working! Thanks a lot. The line was already in the ser2net.conf file but the process wasn't running. Domoticz went offline doing so, so that needed a reboot as well and then I got in the log: OTGW now connected! Cool what?
I want to thank you for your support! I'am gonna think about a new project for Domoticz. Maybe we'll talk again some time.
Best Regards
John
Best Regards
John
- sincze
Sjonnie wrote:Hi Sincze
Best Regards
John
Well now the fun part really begins. (building your own thermostat) mine is still running within Domotiga.
btw what firmware did you flash into your OTGW ?
I still have some 0 values.
- Still some 0. values
- John.PNG (23.25 KiB) Viewed 5048 times
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Hello
Well actually i also have some zero values like you do, except for the return water temperature; that one shows an actual value. On top of that I have to deal with another lttle issue; cause when I got home from work I noticed all the OTGW devices in red state. The running log of Domoticz showed me an "end of file" error, don't know where that comes from, but after a restart of the TPlink and the start of the ser2net process things started to work again. Maybe some log which is enabled or so? So still stuff to do I guess
I flashed version 4.0.1 in my OTGW
Cheers
Cheers
- gizmocuz
Suggestion, first get autostart working for ser2net, next maybe a cronjob to restart every 3 hours or reboot?
I also noticed this with this sollution
- sincze
Sjonnie wrote:Hello
Cheers
Hi Sjonnie.
Did you know that the TP Link suffers from an USB issue.
It will stop working if you don't connect OTGW via a HUB. http://wiki.openwrt.org/toh/tp-link/tl-wr703n
"USB 2.0 port (High-Speed only, use an external High-Speed hub for Full/Low-Speed devices)"
This one will work http://www.bol.com/nl/p/belkin-usb-2-0- ... 012517293/ however it seems the price exploded 4 times since I bought it.
It can be fixed by brewing your own build of open-wrt, or DISABLE the Wireless functionality that will also work.
I tested the last solution several months with my smartmeter (also USB) and a friend of mine who had to use the wireless functionality had to build his own open-wrt. That also solved the issue.
Good luck.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
Good idea.gizmocuz wrote:Suggestion, first get autostart working for ser2net, next maybe a cronjob to restart every 3 hours or reboot?
However I think this shouldn't be necessary have been running OTGW for several months now without a cronjob or a crashing Domoticz / Domotiga.
If the TP-Link goes down it seems the client Domotiga (don't know Domoticz) has to be restarted as well, or at least the OTGW service.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
