kaku not going off
DaWauZ
kaku not going off
Post by DaWauZ »
I have a kaku light switch which is working fine with a kaku remote, but less with domoticz. I don't know exactly why.
The kaku is near the rfxcom about 1,5 meters, could that be the problem?
When doing on command in domoticz, it goes on, when clicking off, it wont go off. Sometimes it does, but that will be 1 of the 20 times i try.
When light is on, by domoticz or remote, then doing off with remote, in domoticz it is also going off. But when clicking the switch in domoticz to turn off, the ligtht doesn't go off, in domoticz it is showing then off.
I already tried to delete it, and add it again. Maybe trying to change the channel on the remote and then add again in domoticz?
Raspberry Pi 2 model B with domoticz
OMV NAS installed on thin client HP T610
Openelec Kodi Mediaplayer on thin client HP T520 (and with multiboot windows 10)
Siewert308SW
Domoticz version: Stable
Re: kaku not going off
Post by Siewert308SW »
Sounds like a typical case of RF Noise.
Hard to track down, could be in your home or a neighbor has something that causes RF Noise.
Try to seek for any device like microwave, chromecast, modem/router, tv ect that could cause the issue.
Or if you have battery powered sensors one of them could be empty.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
DaWauZ
Post by DaWauZ »
I have 2 temp sensors, and took the batterys off but no difference.
Resettet the kaku and added on another channel of the remote, also no luck.
My router is the range of 1,5 metres, powered off no difference.
My microwave is on the other side of the wall of the switch about 20cm higher, cant take him really out but thing is doing nothing right now.
Neighbours, I dont know. If I take the remote near to the rfxcom, it works fine. RFXcom is doing same thing though?
going crazy on this.
Maybe there is a better solution, I dont know exactly but I am using now the kaku awmr-300 so I can use the common wall switch and a remote to do the switch it. No matter what way the common wall switch is.
Is there maybe a wifi solution for this like sonoff?
b_weijenberg
Post by b_weijenberg »
Which device is connected to the KAKU?
KAKU modules should not be placed close together (< 25cm)
Try the KAKU modul on another location.
Some devices produce RF noise, for example a LED lamp.
Try with an incandescent light bulb.
RFX-433, RFX-433EMC, RFX-868
DaWauZ
Post by DaWauZ »
It's a led bulb. But still then the remote should do the same thing as the rfxcom right?
Tried another bulb halogene and it was about the same behaviour, suddenly the thing started to react normal again. Switched to led bulb and it's working till now.
Strange, I am not fully convinced if it's working oke by now.
Verstuurd vanaf mijn XT1562 met Tapatalk
b_weijenberg
The difference between the remote and the RFXtrx433 is the number of RF packets transmitted.
Try with a very short press on the remote to simulate the RFXtrx433E transmit.
DaWauZ
Post by DaWauZ »
did nothing special, now it aint :oops: working again...
Siewert308SW
DaWauZ wrote: Saturday 11 November 2017 21:45 did nothing special, now it aint :oops: working again...
Yep...
As mentioned earlier, typical RF Noise behaviour.
Seen it here a lot and after searching for two week in noticed my Chromcast (although different freq) was the cause.
But also saw it happen when a batery was empty in other 433mhz devices like Temp sensors, motion ect.
Setup:
- DS923+ Docker
DaWauZ
Post by DaWauZ »
Hmm. How can I send more than one on signal or off signal per switch?
Milifax
Domoticz version: 2024.4
Post by Milifax »
DaWauZ wrote: Monday 13 November 2017 10:24 Hmm. How can I send more than one on signal or off signal per switch?
Use a script e.g. in Dzvents. Create a dummyswitch which you use to switch on and off.
Then use a script like the following to switch your devices multiple times.
    active = true,
        devices = {
            'Huiskamer Lampen'
    execute = function(domoticz, switch)
        domoticz.log(switch.state)
        if (switch.state == 'On') then
            domoticz.devices('Lamp Achterkamer').switchOn()
            domoticz.devices('Lamp Achterkamer').switchOn().afterSec(3)
            domoticz.devices('Lamp Achterkamer').switchOn().afterSec(6)
            domoticz.devices('Lamp Achterkamer').switchOn().afterSec(9)
            domoticz.devices('Lamp Dressoir').switchOn()
            domoticz.devices('Lamp Dressoir').switchOn().afterSec(3)
            domoticz.devices('Lamp Dressoir').switchOn().afterSec(6)
            domoticz.devices('Lamp Dressoir').switchOn().afterSec(9)
            domoticz.devices('Lamp TV').switchOn()
            domoticz.devices('Lamp TV').switchOn().afterSec(3)
            domoticz.devices('Lamp TV').switchOn().afterSec(6)
            domoticz.devices('Lamp TV').switchOn().afterSec(9)
            domoticz.devices('Lamp Erker Wit Dim').switchOn()
            domoticz.devices('Lamp Erker Wit Dim').switchOn().afterSec(10)
            domoticz.devices('Lamp Erker Wit Dim').switchOn().afterSec(20)
            domoticz.devices('Lamp Erker Wit Dim').switchOn().afterSec(30)
       if (switch.state == 'Off') then
            domoticz.devices('Lamp Achterkamer').switchOff()
            domoticz.devices('Lamp Achterkamer').switchOff().afterSec(3)
            domoticz.devices('Lamp Achterkamer').switchOff().afterSec(6)
            domoticz.devices('Lamp Achterkamer').switchOff().afterSec(9)
            domoticz.devices('Lamp Dressoir').switchOff()
            domoticz.devices('Lamp Dressoir').switchOff().afterSec(3)
            domoticz.devices('Lamp Dressoir').switchOff().afterSec(6)
            domoticz.devices('Lamp Dressoir').switchOff().afterSec(9)
            domoticz.devices('Lamp TV').switchOff()
            domoticz.devices('Lamp TV').switchOff().afterSec(3)
            domoticz.devices('Lamp TV').switchOff().afterSec(6)
            domoticz.devices('Lamp TV').switchOff().afterSec(9)
            domoticz.devices('Lamp Erker Wit Dim').switchOff()
            domoticz.devices('Lamp Erker Wit Dim').switchOff().afterSec(10)
            domoticz.devices('Lamp Erker Wit Dim').switchOff().afterSec(20)
            domoticz.devices('Lamp Erker Wit Dim').switchOff().afterSec(30)
Siewert308SW
In normal Lua...
commandArray['MyDeviceName']=On REPEAT 3 INTERVAL 3'
repeat means how many times to repeat the signal.
Interval means the time between each signal command.
Setup:
- DS923+ Docker
DaWauZ
Post by DaWauZ »
Siewert308SW wrote: Monday 13 November 2017 11:39
In normal Lua...
Can I use it here like this?
13-11-2017 12-30-09.jpg (91.53 KiB) Viewed 2511 times
If yes, and want it to use the switch in a blockly, will it use this as above?
